SOURCE: Need the remote control code/s
I google'd remote codes for this device. code 1007 seems to work as far as volume controls and the off/on switch goes.
SOURCE: CANT GET SUB WOOFER TO WORK WITH MY RECIEVER!!!!!
See step 9 for turning the subwoofer output ON
HERE
Part of the original link i gave you to your online manual.
Thanks for using FixYa - a FixYa rating is appreciated!!
SOURCE: i have a sherwood RD-6108 receiver that shuts off after 30 sec. of use
This is the overload protection circuit. Make sure not alot of dust build up inside and make sure no speaker connections are touching. Most likely being that it a sherwood you will want to consider replacement.
Thank you,
Lee
http://www.retrevo.com/support/Sherwood-RD-6108-Receivers-manual/id/516ci958/t/2/
My preference is to send the BEST version of any medium (audio or video) directly from it's original source to the BEST ELECTRONICS that uses it; then send minimalist versions across for convenience and lo-fi watching/listening.
Any self-respecting modern TV has multiple hi-def video inputs, so run the Bluray, DVD, cable box video straight in and run the audio from those devices to the Sherwood.
Fewer expensive cables, no excessive connections to go bad, no unnecessary handling of the material.
I'm pleased to see the manual for this one (and the product's limited video capabilities) don't tempt the user to route everything through it on the way to the TV.
