Question about Rolex Submariner 16618 Wristwatch
Submariner water under crystal
I went in a hot tub with my submariner on and later realized that the stem was open and subsequently steamed up the crystal. I left it open and put the watch in a zip lock bag full of rice hoping to draw the moisture out of it. It worked well but seems to need more. Do you think this will work over time or should I get it to a pro asap?
Thanks a bunch.......
  • skijump1 Jan 22, 2009
    I appreciate the feedback.
    Problem Solver:
  • 12 Answers
This is a simple problem, one of the seals has failed and water has entered the watch.The watch has a two seals on the stem/crown which should be screwed down, the back cover has an "O" ring and of course the crystal has a seal. The watch has been wet and this displaces the oil, only way to get it clean is to completlt disassemble, put in an ultrasonic cleaner, oil, set beat and rate install new seals and water resistance test and probably replace crystal. The sooner you do this the better, there are very delicate parts in this type of watch, I usually reconnend getting it to a watchmaker within 1 day to limit damage. On my customers I will do an emergency dry out for free up to two years after overhaul unless the crystal is cracked.
Posted on Jun 14, 2009
  • 2,334 Answers
You definetely have to ask for watchmakers help to dry out your watch properly. Moisture may not be visible to your eye, but it's still in the watch case and ruins your watch movement permanently and quite quick.
Sooner or later your watch will stop or show some other faults, but by that time the price for repair can be sky-high.
I've been replacing whole movements, just because the owners thought it's not a big deal or didn't want to pay for such a job. It just sounds 'drying out', but actually it's not, as watch must be disassembled completely (incl. movement), cleaned, oiled and properly re-adjusted.
Rolex repairs has never been cheap, but better do it as soon as possible.
Do not forget to rate, please.
Posted on Jan 22, 2009
Submariner-how do I open it? I dropped it, and one of the dots(#'s) dislodged on the face.
If it is a true Rolex they require a special wrench that grips the tiny serrations around the base of the back. You will need to take it to a watch repairman, the tool is very costly.
Feb 13, 2011 | Rolex Oyster Perpetual Submariner Date...
I have submariner Rolex watch and when I unscrewed the winding stem where I can manually wind it, I started to wind it and all of a sudden it was like something snapped and there was no more tension when I...
These watches are selfwinding so you should not have to use the crown to wind it up. (Although some watches have this as an alternative).
To wind it up shake it gently from side to side for some minutes and it should start.
No tension on the crown wheel is worrying. If you pull it further out and can adjust the time in position 3 (fully out) and the date (half way out), then it may be that no damage has been done. If you cannot adjust the time, then it looks like a trip to the dealer is required for repair.
Feb 10, 2011 | Rolex Submariner 16618 Wristwatch
THE MARKERS AND POINTERS OF MY ROLEX SUBMARINER ARE NO LONGER LUMINOUS IN THE DARK. CAN THEY BE RE-COATED? ANY IDEA OF COSTS INVOLVED
They can be re coated or replaced.The watch will need to be re sealed after so now may be a good time to service the watch as this is advised every 4/5 years.
A service will cost £275.00/£325.00 and takes 2/3 weeks at www.rolexrepairs.co.uk
Regards
Aug 09, 2010 | Rolex Submariner 16618 Wristwatch
I have a rolex submariner and it occaisonally vibrates. What is the problem with this.
Sounds like mainspring is not holding in place and getting undone (unrolls by itself), that what usually causes the vibration.
W-Precision
Mar 19, 2010 | Rolex Daytona 116520 Wrist Watch
No action when I pull the stem out to adjust time
There may be more than one "out" position.
Typically there are three positions 1) home 2) 1st adjusting position, 3) 2nd adjusting position.
If you haven't got the instructions, you can get a download from their web site, (Rolex.com). You go to the bottom of the screen and there is a menu. Select "downloads" and you will see a list of downloads, choose yours.
Feb 08, 2010 | Rolex Submariner 16618 Wristwatch
I have an old Rolex Geneve Cellini watch gold 12 jewls.. how can i say if its original, not fake.. jan norway
The quickest way to spot a fake Rolex is by the second hand. Is the second hand ticking or sweeping. If it's ticking it's fake. A real Rolex's second hand moves around the dial in one continuous movement.
Check for a small engraved crown on the crystal at 6 o'clock. Most fakes will have something similar. The difference is that the crown on a real one is almost impossible to see by just your eye.
Look for the word "Rolex" and the watch's serial number engraved at 6 o'clock under the crystal on the area between the crystal and the dial. While many fake Rolex watches post-2005 have this feature, they're usually printed, not engraved.
Most other ways relate to newer Rolex watches.
Hope this helps and hope it's the real deal.
Jan 01, 2010 | Rolex Submariner 16618 Wristwatch
How can I change the time and date on my wife's Rolex? The stem will pop out but nothing happens when I turn it either way. No change of date or time.
RECOMENDATION:
Contact a local official Rolex dealer to address the problem.
GOTO:
http://www.rolex.com
To find a local dealer.
Hope this tip helps.
R/
David
Nov 25, 2009 | Rolex Submariner 16618 Wristwatch
How to shorten band on Rolex submariner
on mine I removed a couple links using a jeweler's screwdriver(flat-blade). Look for the screws in a hole along the narrow edge of the links nearest to the clasp. Use care in removing/replacing these screws, you do not want to break or strip them using excessive force. If you need to remove more than one link, take additional links from the opposite side of the clasp, so the clasp stays centered on your wrist.
Nov 06, 2009 | Rolex Submariner 16618 Wristwatch
Submariner 16610 M Model has 40 seconds faster
I don't know if I can help you out, but I can tell you that even a low quality Daytona, or Submariner copy can be adjusted. My 1992 Daytona copy is at about 10 sec a month fast. I read a **** load about the movement, and did the adjustment myself. Any watch shop that tunes watches can do it.
I don't know what year your Submariner is, but today Rolex is using a new main spring (it is now blue). I would think a replacement spring would be the most you might need, but a good tune-up should do the trick. If it is real, I would think about sending it to Rolex for cleaning and a tune-up ($$$).
Jan 27, 2009 | Rolex Daytona 116520 Wrist Watch
Submariner Winding Slips
crowbar040, you may have a problem with your mainspring click, which is supposed to keep the spring coiled as it winds. What might be happening is it is sticking and coming undone instead of winding. Or you could have a bad gear in your automatic.
Apr 28, 2008 | Rolex Daytona 116520 Wrist Watch
Rolex Submariner 16618 Wristwatch Logo
510 people viewed this question
Top Rolex Watches Experts
Samyfam
Samyfam
Are you a Rolex Watch Expert? Answer questions, earn points and help others
