Question about Panasonic PT-47WX49 47" Rear Projection Television
3d effect about a month ago my tv shut down and when i tried to turned it on , it turned on for afew second and then off. finaly it stayed on (after afew tries).but now i have an arch on the bottom and top of the picture with green line on the back ground (like 3D effect).Tried the convrgance setting but no luck
  • Ahmad behzadipoor Jul 06, 2007
    Thank you for your help but unfurtunatly i have no servicce manual or schematic. any suggestion where i can get a coppy of these?
    Thanks in advace for all the help
    [email protected]
    Sergeant:
    Champion:
  • 326 Answers
Hello, please replace convergence output IC`s and R7048 (2,2R). If you need more info please contact me at LIVE Expert Assistance. Best regards, Arpi
Posted on Jul 01, 2007
SOURCE:
Diagnosing problem
Hi. Yes you could replace if you are not in a position to trouble shoot the problem on the power board.
Feb 26, 2016 | LG 47lw5300 47-inch 1080p 120hz Cinema 3d...
Samsung UN46ES6500FXZA turns off by itself
I can not acces my Facebook deos not recognize or mail or password,how I can restart t.v to install and to atarte again please help me , thank you
Feb 10, 2014 | Samsung UN46ES6500 - 46" 3D LED-backlit...
When i turn my tv on the screen just stays black. You can hear the volume. I just replaced my bulb about a month ago. I took the bulb out again to see if it was blown and it wasnt. Does anyone know wh
send me a email [email protected] and I will send you the info to retreve the error code to find out why the set is shutting down. Be sure to include the moodle number and symptoms with your email
Feb 10, 2013 | Mitsubishi WD-65C9 65" DLP HDTV
"TV will shut-down in afew seconds. Please check
Thia is a indication that the unit is overheating. Now the causes of this can be a cople things... the fan may have slowed or may be cloged.. In the past there have been instances were a faulty temperture sensor or thermal switch might cause this. I have replace many of these sensors at the shop. Mitsubishi has issued service bulletens on this problem. THere not difficult to get replace and are about 75 dollars to replace(at our shop)
Mar 06, 2011 | Mitsubishi WD-52525 52" Rear Projection...
The TV turns on but cannot find a signal (as has been normal when swictching to HDMI inputs). Usually it takes a second and the Cable or FIOS signal shows on screen. As of today, the images never comes...
Tries tv and cables boxes uplug,replug it back like about an hour later for the tv resetting itself back to the factory setting and those pay boxes updated it softwares.Take the HDMI cable plug it in into another tv HDMI hub.Tv should have signal and work again.
Feb 17, 2011 | InFocus ScreenPlay 61" Rear Projection...
I turn on the tv and it shuts off after a couple seconds
if you unlpug your tv and plug back is the green ligth blinks for one minute?
let me know so i csn help you
Jul 29, 2009 | Mitsubishi WS-55807 TV
Samsung DLP TV HL-R5667W shuts off intermittently
Afraid there is no simple answer to this. This set has multiple things that could shut it down, one may be the balest needs a upgrade , this could be why it seems to be eating lamps. Another is what sounds like a fan is a color wheel , these have known problems of failing, and when this happens sometimes they shut down the set. And finaly does the set have good ventalation, overheating can cause huge problems with this set
Feb 13, 2008 | Samsung DLP HL-P5663W 56" TV
Sony KDF-E55A20 shuts off for 30 seconds, then comes back on for 30 more
Do just as the others said pull out the bulb and clen the screens on top and bottom of bulb. BUT you can also prevent this from happening as soon the next time. You need to take off the back of your sony tv. On the right rear as you are looking at it there is a black blower on top that is on top of where your bulb fits in. you need a ninety degree phillups head screw driver. take the driver and take out the 3 screws... use a can of air to clean it out... You would not believe the holy hell dust stuck up in that blower!!!! Like I said, take the back of your tv off. If you are not sure where the bulb is once you get it off just turn it on. It's not going to hurt ya. If you are lazy about taking the blower off you can turn it on and shoot the can of air while the bulb is on but you are going to have to take the bulb out ALOT of times to get the dust out of the screens over and over until no more dust collects
Oct 26, 2007 | Sony KDF-E55A20 55 in. LCD Television
Panasonic PT-47WX49 47" Rear Projection Television Logo
69 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
