Question about Food Mixers
Kitchenaide Mixer Attachment Gear Seized Up
I was using my Kitchenaide Mixer to grind turkey and the motor seemed to be slowing until it finally would not turn at all. We have taken the mixer apart and ordered part #9705130 (#12 on the parts list) thinking it would replace the one that seized up. However, the drive gear hub did not come with what appears to be a bushing around it. The parts guide does not show that you can order the bushing separately. Is it part of the top housing so we would have to replace that as well?
SOURCE: kitchenaid mixer k45ss slow gear
If you look into the brush holder you will see a stopper at the botom ,(this is so when brushes are wore the spring is not driven into armature) .. the brushes have to be inserted so the groove is lined up , try that
Posted on Apr 07, 2008
  • 152 Answers
SOURCE: Broken blender attachment
Wolfgang Puck Housewares Customer Service
Monday - Friday
9:00 am - 4:30 pm Eastern Time
I would call the number above they should be able to help you out.
Posted on Aug 04, 2008
  • 4 Answers
SOURCE: Kitchen aid 300 watt counter mixer model ksm90
Here is a link to the instruction manual:
Quick summary:
Tilt back the head of your mixer. Look at the joint between the head/body of the mixer. A flat-head (standard) screw will now be visible. Turn this screw counter-clockwise to raise the attachments, clockwise to lower them. Don't turn the screw too much, it is pretty sensitive.
Posted on Jan 24, 2009
  • 135 Answers
SOURCE: Kitchenaid mixer makes a clanging noise
Hi. If your mixer is under warranty, call Kitchenaid. They are very good at replacing mixers under warranty.
If you are out of warranty, this is where the fun begins, NOT!
Remove the silver band from around the top of mixer. Remove 4 screws that secure the top cover, remove cover and at the front top of the machine locate the transmission cover. Inspect this cover carefully for cracks. If you find cracks in it...You have just discovered Kitchenaid's dirty little secret. A cheap plastic transmission housing! The failure of this cheap part is the cause of all of the rest of the damage inside the mixer, which may include a destroyed worm gear and shaft, destroyed bearings and their seats. You're not alone. I estimate that thousands of these plastic parts have failed causing great damage to the rest of the mixer
Kitchenaid's replacement housing is made out of metal. If you feel up to the task of repairing the mixer yourself goto the Kitchenaid website and do a search for the parts catalog for your mixer model, these will assist you with disassembly, reassembly and parts ordering.
If you're not up to the task, take it to an authorized repair place once you have put the cover back on.
Even if you're out of warranty, you may be able to have Kitchenaid pay for the replacement parts, they did for my mixer. Be persistent with them and try to get to a manager with your complaint. This cheap piece of plastic has no business being installed on a high-priced machine.
If this solution has assisted you, please rate it. ricardok45
Posted on Mar 20, 2009
  • 135 Answers
SOURCE: I suspect my D300T Hobart Mixer has a broken shaft
Hi. Go to, register for free. This will allow you access to the parts files for your D300T mixer. Download them. When you begin your disassembly, take a photo of every piece that you remove, lay these pieces on a piece of cardboard or something suitable in the order that they were removed. This will help you greatly with your project. Good luck! ricardok45
Posted on May 21, 2009
Seized planetary gear pin?
Page two of the KitchenAid service manual will walk you through how to remove the pin. Here is a link to that service manual:
Apr 03, 2013 | KitchenAid KP50PS Professional 5 Series...
Kg25h0x stand mixer
Sadly the only help we can give is SUGGESTING you contact Kitchenaide and have them assist you
Oct 17, 2017 | KitchenAid Professional Heavy Duty Series...
The mixer won't work the pasta attachment, keeps rotating the mixer motor.
It sounds like it could be a possible stripped gear. You could have a bad attachment drive gear or bevel pinon gear.
Best thing to do would be to take the mixer apart, and inspect those gears. Here is a link to the service manual which will aid you in taking apart your 4.5 quart mixer:
Here is a link to the attachment drive gear:
Here is a link to the bevel pinion center gear:
Let me know if you have any questions.
Thank you,
Customer Service
Jan 27, 2013 | KitchenAid K45SS Classic Stand Mixer
Model g kitchenaide manual is hard to locate. Please help
Locate your model number and then try searching on this site:
If you can not locate your model number, for a hand mixer it should be on the bottom of the mixer adjacent to the mixer attachment holders.
Thank you for using FixYa!
Aug 26, 2011 | KitchenAid Food Mixers
On low it makes a really loud grinding noise the higher you turn up the speed the slower it becomes.
It sounds like the Worm Gear is going out. The faster the motor runs,
the more damages the Center Gear is grinding away the teeth of the
Worm Gear. Things start to slow down, and eventually they will come
to a halt. It's time to replace the Worm Gear. Also make sure to use
new fresh Kitchenaid Food Grade Grease with the new replacement.
Jun 19, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
The attachment/accessory "screw" fell into my mixer while the beaters were mixing a cake batter. The mixer froze up when it hit the "Screw" and now the unit won't turn on. Did I burn up the motor? Does...
Sounds like a classic case of the gears jumping out of sync. This is an issue that needs to be handled by a repair place or sent back to KitchenAide. The motor on a KitchenAide is very strong and it sounds like when the cap for the accessory fell in it must have somehow gotten jammed, although I really don't see how that would be possible unless there was something else in the mix as well.
Dec 04, 2009 | KitchenAid K45SS Classic Stand Mixer
Grinding sounds and slower mixer speeds
It sounds like you may have a broken worm gear inside your mixer which is a common problem.It is a wearable part which transfers the power from the motor to the main drive. It may be chipped or damaged right now, and running it will cause more damage. Part number for the worm gear is W10112253. This does however require some know how to replace. Hope this helps
Nov 21, 2009 | KitchenAid K45SS Classic Stand Mixer
Grain mill stops turning
Will it grind any wheat? I had a similar problem with the wheat overwelming the drive system and had to use smaller amounts of wheat to keep the system grinding. Do you have the feeder attached? I couldn't just load it up but had to feed a little at a time. Hope it helps. Favorable comments are apprieciated.
May 08, 2009 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Motor runs paddle does not move, oil from attachment port
I think this link will help you understand what is needed to fix your mixer.
You will need to purchase a gear. Here is link MarBeck should have it.
You may need to replace some grease. Make sure to use a non-toxic food grade grease.
Dec 14, 2007 | KitchenAid K5SS Heavy Duty Commercial...
Mixer attachment
make sure attachment is turned full counter clockwise to release point give a good tug if doesnt work try a light tapping with a rubber hammer or lobster wooden hammer
Nov 20, 2007 | KitchenAid KSM150PS Artisan Series Stand...
Food Mixers Logo
85 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
