Could you please guide me on how to restore firmware on the printer. Firmware was being updated when I had power outage and now the printer won't turn on at all.
SOURCE: Brother MFC-210C Firmware Problem
I would try re-running the firmware installation if you haven't. Last time I had a firmware problem like this I left the machine unplugged for a hour or two came back and re-tried it and the machine took the upgrade fine the second time.
SOURCE: Brother mfc MFC-5440CN magenta issues
You cant print in ANY color when it says NO CARTRIDGE for any one color. Sucks.
SOURCE: Firmware update how to put
Even though the printer appears idle it will not take a firmware update until you erase all the voice messages from memory and clear the outgoing voice message.
SOURCE: Brother Printer MFC-8480DN making a knocking
Try re-seating the ink cartridge ensuring there is no debris in the internal paper path.
2.
Press the STOP/EXIT and the UP ARROW key at the same time.
The first 2 characters on the top row will determine the ROM version.
3. A
utility is available that will allow you to update your Brother machine with the
most recent version firmware, by downloading updates over the
Internet.
4.
Choose your country.
5.
Choose your language.
6.
Choose Inkjet FAX/MFC/DCP
7.
Choose your model
8.
Click on "Downloads"
9.
Under Notes/Information select the option - Click here to view
firmware version history.
10.
Close the window to continue with the firmware update.
11.
To update the firmware please follow the instructions listed below:
DO NOT interrupt
the process or turn off the machine once it has begun. Doing so may corrupt the
memory on the machine and may require the machine be serviced in order to
correct the problem.
12.
Select your OS and language in Steps 1 and 2 on the website and then
click on "Search".
13.
In the next window, scroll down to the bottom of the page to locate "Firmware
Update Tool".
14.
Click on "Information & Download"
15.
Scroll down to the bottom of the next page and click the "Download"
button
16.
Accept the license agreement.
17. A
dialog box appears with options for "Run", "Save" or "Cancel". Choose
"Run".
You
may also download the utility for later use by choosing "Save".
18. A
dialog box appears informing you that some information from the machine will be
collected and stored. Click "I Accept".
19. A
dialog box appears informing you what will be deleted during the firmware
update. Click "Next".
20.
The program will now begin to update the firmware.
STEP 1: Verify the firmware version of your Brother machine:
a. Press the OK key 2 times.
b. Press the UP ARROW (+) key 5 times.
c. Press the OK key 2 times.
The firmware version will be displayed on the LCD.
- If the firmware version is 1.01 or 1.02, go to STEP 2: Update the firmware of your Brother machine.
- If the firmware version is 1.08 or above, go to STEP 4: Toner usage and yields.
STEP 2: Update the firmware of your Brother machine:
A firmware update tool is available that will allow you to update your Brother machine with the most recent version firmware by downloading updates over the Internet. The updated firmware will assist in optimizing toner usage.
The Brother printer driver must be installed and working properly prior to the update of the Brother machine. The firmware update tool also requires that you have Java installed on your computer. The firmware update tool will not work if Java is not installed. If you do not have Java installed or are not sure if it is installed on your computer, you may download Java from http://www.java.com.
To update the firmware, follow the instructions listed below:
DO NOT interrupt the process or turn off the machine once the update has begun. Doing so may corrupt the memory on the machine and may require the machine to be serviced in order to correct the issue.
1. Open an Internet web browser and go to http://welcome.solutions.brother.com
2. Select your country and language.
3. Type in the model of your machine or select it from the appropriate section (Ex: HL3070CW in the Color Printer section).
4. Select Downloads.
5. Select your OS and language for step 1 and 2 on the web site. Click the Search button.
6. The Firmware Update Tool will be listed at the bottom of the web page. Click Information & Download.
7. Click the Download button and I Accept if you accept the license agreement.
8. A dialog box appears with options for Run, Save, or Cancel. Select Run. You may also download the firmware update tool for later use by selecting Save.
