Question about Intermatic Hardware & Accessories
Model EJ351 Manual
I need a MANUAL in English
  • Intermatic Master
  • 5,245 Answers
Copy following link:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#EJ351
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Oct 13, 2013
I have the EJ351 mechanical in-wall timer for my outdoor garage lights which are LED.I set the timer but lights go on way early Is there another method for programming the switch that I could try.
This is not a mechanical timer; it has a solid-state switch. It is designed for incandescent lights, and is not recommended for CFL or LED lamps. It may work properly with dimmable LED lights if you have at least four (total 32 Watts or more) connected.
You can try programming using the 24-hour method described at the top of page 2 of the manual. I've provided the link to the manual below.
https://www.intermatic.com/-/media/inriver/6842-8228.ashx/EJ351-Instructions-EN
Jul 08, 2017 | Hardware & Accessories
The red indicator light for the intermatic light timer EJ351 does not even go on - what can I do?
Hello Barb.
EJ351 timer indicator light problem:
Reset timer and try again.
This timer is rated for incandescent lighting only, 500 watt max, 40 watt minimum, and timer has two wires.
When replacing switch, either wire can connect to timer wires.
Check circuit breaker: click breaker all the way off, and then back on.
Use non-contact voltage tester to see if wires are live at timer.
If the timer does not work, then it has 1 year limited warranty for defects in workmanship.
Copy following link for EJ351 timer manual with instructions for resetting timer.
http://waterheatertimer.org/pdf/Intermatic-ej351c.pdf
Jul 18, 2012 | Intermatic Programmable 24 Wall Switch...
Nnecesito manual del temporizador ej351
Copy link to see EJ351 manual
Use google translate to convert to Spanish:
http://translate.google.com/
Jun 08, 2012 | Hardware & Accessories
How do i set the off and on time on the mod. ej351 night sentry timer
1) There are two methods shown in manual.
7-step rapid method, and 4-step programming method.
2) Here is link to on-line manual.
3) Add a comment if manual is confusing, and say which method you are using, and what step is not working.
Manual also has illustrations of parts, and a troubleshoot section.
4) The EJ351 timer is rated for incandescent light bulbs only, and not rated for CFLs, ballast or motor loads.
5) If you need timer recommendation for load other than incandescent bulbs, then add a comment and say what timing and load needs you have.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 29, 2011 | Hardware & Accessories
I had a timer model EJ341C many years ago, it was broken down. I went a store and the salesman said the new model EJ351C is the substitute. My questions to you is (1) Are these two models pretty much the...
Hi Henry,
Intermatic EJ351 is sold today to replace earlier models.
EJ351 is very popular 24-hour ez-set timer with simple wiring.
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/in-wall%20timers.aspx
Instruction manual:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej351c%20-%20english.ashx
Connect wires inside box to either timer wire.
Red indicator light is helpful when setting timer program.
Add a comment if instructions are confusing, and say what part of manual does not make sense.
Apr 19, 2011 | Intermatic Inc. ST01C Digital In-Wall...
My EJ351 programmable timer has work perfectly since 2004. A few days ago the red light just started to continuously flash. I turn it off to rest and regrogram but no luck, the indicator light still...
What is amazing is that you know the year of purchase, AND remember how to set the timer.
1) Try turning off circuit breaker and see if timer resets.
2) Buy cheap circuit analyzer and plug into outlet on same breaker and see if line is clean.
3) EJ351 has limited 1 year warranty.
I test timers: usually when in-wall timer goes bad, it needs to be replaced.
There are no repair parts.
Google search: Intermatic EJ351 timer
Amazon sells EJ351
http://www.amazon.com/dp/B000Q9YUGU/ref=asc_df_B000Q9YUGU1408425?smid=ATVPDKIKX0DER&tag=nextagus0039178-20&linkCode=asn&creative=395093&creativeASIN=B000Q9YUGU
Aplus supply sells Ej351 timer.
http://www.aplussupply.com/intermatic/timer.htm
I buy timers from both these suppliers.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 28, 2011 | Intermatic Programmable 24 Wall Switch...
I have a intermatic ej351 in my garage to turn the outside coach lights on and off. I made the mistake of putting some 10 year bulbs in the coach lights and now the red light on the timer just flashes...
I answer questions for free.
I specialize in timers and electrical devices
Below is the manual for the EJ351
The red light is a good indicator of the EJ351 timer.
The manuals says that you can clear all programming by moving control lever to OFF-CLEAR position for 20 seconds.
After programs are cleared, the red light will turn off.
Then move control lever to ON position, and then red indicator light will start flashing.
So the problem may be that the timer programs were accidentally cleared.
Use the instruction manual to re-program your timer.
Add a comment if you need more assistance, and I will help.
Nov 02, 2010 | Intermatic Timer E1020, Single pole/single...
Hardware & Accessories Logo
79 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
