Question about HP Photosmart C6100 All-In-One Printer
Error code on hp photosmart c6100 need code to reset
I have had this problem before but misplaced the code I received to enable me to access the system configeration. It can be fixed as I have done it several times.
SOURCE: Error HP Photosmart 3310. No strart print, no scanning...
I have a Photosmart C6180 all in one and get an error message 0xc18a0101 Ink System has failed. Unable to copy, receive faxes or print. Refer to printer documentation. Error: 0xc18a101.
I put new cartridges in and tried to recalibrate as mentioned by someone on the board. Can anyone help, please?
Posted on Feb 20, 2008
SOURCE: HP Photosmart c7180: "Ink System Failure" error code Oxc18a0306
I get the ink system failure message on my hp c7180 as well as an error code of oxc18a0306.
Posted on Nov 21, 2008
covertgreywo
SOURCE: Ink System Failure (Error 0xc05d1381)
Don't waste your time on the copy and paste HP solution above.
If you really want to fix your printer:
Okay, HERE IS THE ACTUAL FIX FOR THIS ERROR.
1. Disconnect your USB cable.
2. Turn off the printer.
3. Press and hold down these four buttons at the same time:
OK, Cancel, Black, Color.
4. While still holding them down hit the power button once.
5. It will Blink.
5. Hit the power button again.
6. Continue holding until you get a message on the screen.
7. Allow the printer to sequence through and there you go.
Enjoy.
Posted on May 01, 2009
SOURCE: hp photosmart error code 0xc05d2381. does this
french oeioe
Posted on Aug 16, 2009
SOURCE: Ink System Failure HP C5180
-------solution 1---------
HP C5180
Hidden tech menu For resetting and repair, FIX UIAUX
Fixes error 0xc18a0507 error ink system fail
press <left arrow> then press <setup> button together
then press <ok>once support R0631m comes on screen
right arrow 2 times to the System configuration menu
then <ok>
then <ok> to select and ok to confirm reset error.
then <cancel> to escape ( all of witch are onscreen instructions.)
presto restart and no further error
http://www.thecomshack.com/hpc7180.htm
------------- solution 2 ----------------------------------
HP C5180 All-In-One Printer HARD RESET:
Hold down HELP + OK button and unplug printer
Hold down HELP + OK button again as you plug the printer back in.
Then power it on, if it doesn’t power on automatically.
Be Safe: keep holding the buttons until the printer turns itself off. (It took mine less than a minute.)
Now you can release the buttons and simply power it back on.
I got an error message about “improper shut down” since I unplugged it w/out powering down. After I clicked “OK” the printer was just fine and didn’t mind anymore. And now I can print.
Posted on Sep 21, 2009
Hp 6100 crashes my computer
please , record the blue screen error , then post to me i will diagnose the error , anyway almost uninstall driver last driver then find the right driver for your printer " hp c6100 driver winx x: means the version of your windows 7,8,...etc
Mar 21, 2013 | HP Photosmart C6100 All-In-One Printer
My printer is photosmart c6100; from time to time when I print many time it gives me error; I have to off and on it again to continuo; I try to update the sofware, include the SO but the problem persist. I...
HP designed a quick and easy tool that diagnoses and resolves many printing problems: The HP Print Diagnostic Utility. HP recommends that you download and install the Print Diagnostic Utility any time you need to troubleshoot a printing problem.
Nov 04, 2010 | HP Photosmart C6100 All-In-One Printer
I have an HP C6100 printer and it keeps telling me to power down
Your scanner unit has failed. It will cost the same as a new printer to have it replaced.
Mar 05, 2009 | HP Photosmart C6100 All-In-One Printer
Vista
Go out to hp.com support and check under updates and downloads, you should find the updated software and drivers you need. I just went through this with my photosmart 8750,.
Aug 17, 2008 | HP Photosmart C6100 All-In-One Printer
Print System Failure came up on the screen on my printer
below is the technical document that i want you to follow exactly. Read all the informations and follow the instructions.
CLICK DOCUMENT HERE ==> DOCUMENT
Please, let me know the outcome after following the steps.
thank you so much.
adonscott
Jul 26, 2008 | HP Photosmart C6100 All-In-One Printer
HP Photosmart C6100 All-in-one Series
Hi ok you can try I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 01, 2008 | HP Photosmart C6100 All-In-One Printer
Installing HP C6100 Drivers Breaks Wireless
Try this utility it resets all the registry information for Windows networking.
http://www.majorgeeks.com/WinSock_XP_Fix_d4372.html
Dec 17, 2007 | HP Pavillion ZV6000 Notebook
HP Photosmart C6100 All-In-One Printer Logo
79 people viewed this question
Seeker5211
Seeker5211
