Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Hadn't used it a couple years, socleand it all up, checked the muffler, spark plug, air filter... all looked OK. filled it up with fresh gas/oil mix and tried to start it per instructions. No resp
  • Poulan Master
  • 2,239 Answers
The ignition unit is a small assemby fixed to the side of the cylinder with two screws, there is more than one unit type fitted to this model so i cannot give you the part no, most of the units will have the part no. on them, remove the top cover held with three screws, now remove the starter held with four screws, you will now see the ignition unit, pull the cap off from the spark plug, remove the eart cut out wire from the terminal on the unit, now remove the two screws holding the unit to the cylinder, once the unit is of check the top for the part no. check the web for a new unit, refit the new unit too the cylinder, use a feelr gauge to set the 0.3mm gap between the flywheel magnets and the ignition unit core, re connect the cut out wire. Before doing all of this i should have said you need to give the engine a good crank over to check for a spark with the old unit with the cut out wire removed.
Posted on Jan 08, 2013
5 Suggested Answers
johncaman
  • 201 Answers
SOURCE: Poulan saw will not start
This is not really a solution.... I can't post a comment. I think you know where I was going with the flywheel thing - whether or not the timing is right. I thought you'd pulled the flywheel yourself, and sorry, I'm not sure how to pull it. I'm assuming this is a 2 stroke motor... you might want to just check that the piston is near top dead center when the magnet on the flywheel hits the coil..... you can stick a pencil or anything long through the spark plug hole to give you an indication if the piston is at the top of the cylinder or not. Let me know how it goes!
Posted on Mar 14, 2009
  • 25 Answers
SOURCE: new saw - will not
It's possible the brake is on. Try pushing the brake forward then pulling it back until you hear it click. Then try cranking it again.
Posted on Sep 22, 2010
SOURCE: my Poulan 3500 chain saw will not start
3500 poulan runs and secand stop
Posted on Oct 22, 2010
SOURCE: Chainsaw won't start. Replaced carburetor, fuel lines, fuel filter, ignition module, spark plug. Using new gas and oil. Has good spark but won't pop.
try priming it mite work lol
Posted on Mar 29, 2012
TRACTOR WILL NOT STAY RUNNING
Give it a tune-up, spark plug, oil change, fuel filter, air filters... Drain gas completely from gas tank and carburetor... Fill with fresh fuel. White smoke from muffler means there is water in the system... Fuel "goes bad" as soon as 1 month.
Nov 18, 2013 | Garden
Poulan Leaf Blower
you may need to turn the Hi screw on the carb in 1/4 of a turn. Make sure the gas and mix are fresh.
Jul 22, 2013 | Poulan Garden
Ryobi ry34441 hard to start, when started runs very low rpm's then dies.
It really does sound like the exhaust or the spark arrestor is blocked ( or the exhaust port itself is carboned up ) remove the muffler, check the exhaust port, if this looks ok, run the machine with a very slack muffler aqs a test, if ir revs then it is blocked.
Apr 20, 2012 | Garden
Chain saw won't start
Things to check,drain and re fill with fresh fuel/oil mix, replace the fuel filter in the fuel tank, remove the spark plug, rest on top of the cylinder and check for a spark, if this is all ok remove the muffler and check the condition of the piston through the exhaust port, any signs of damage and the saw will have to come apart for further investigation.
May 30, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Sovereign xc 375 very difficult to start, getting spark, fresh fuel, oil and new spark plug - no change. Any suggestions?
Is your spark plug wet when you pull it out? If so then it may be fludding on you, If it's dry then your carb may be gunked up from old fuel setting in carb and lines it also can plug you fuel filter. after checking all these, check your compression and also take your spark plug out and look inside the hole at cylinder foe bad scores or scratches in the wall of the cylinder, you should also pull muffler off and check cylinder that way too, you may be low on compression.
Another thing you could try is your air filter, is it plugged with sawdust, take off and try that , then try carb clean short blasts into carb and try to start, then work choke back and forth keeping it running to help **** some fresh gas through carb, all else fails pull carb and dissasemble and clean. Good Luck
Apr 26, 2011 | Garden
Wont start
Remove the spark plug and check for spark. If snappy and blue with a fresh plug gapped at 0.020", then pour a little fuel mix into the plug hole and try for start. If it pops or runs for a few seconds, then look for fuel delivery problems. Check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for decay or other problems. If no help, remove the carburetor, disassemble and clean the interior with spray carburetor cleaner. Inspect the diaphragm in the lower chamber for flexibility with no holes or cracks. Make sure the fuel is fresh and properly mixed with a modern synthetic saw oil. Be sure to shake the container thoroughly each time time just before filling the tank to prevent oil starvation. Hope this helps!
Jan 14, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Filled with gas/oil mix and won't start. Was running fine 30mins before. No issues at that time.
Remove the spark plug and test for snappy blue spark. If ok, pour a little fuel mix into the plug hole and try for start. If it pops several times, check the fuel filter, air cleaner, and muffler for plugging. Check the condition of the fuel lines and the primer bulb. Did you make sure that you used proper mixing of the fuel/oil? Be sure to use a modern synthetic saw oil with fresh fuel at the required ratio and use it's own can for mixing/storage. Shake the can thoroughly just before filling the saw. Hope this helps!
Sep 05, 2010 | Garden
Will not start. Spark ok tried with started fluid
Spark should be blue and snappy with fresh plug gapped at 0.020. Try putting some fresh fuel mix into the plug hole and try to start--it should pop several times. Does the engine seem to have good compression? If not, remove the muffler and check the piston skirt and cylinder wall for severe scoring. If it is, then the engine has probably be run on straight gasoline or poorly pre-mixed fuel/oil. At the very lean fuel/oil ratios ( 50:1) recommended for today's saws, proper premixing of fresh fuel and a modern synthetic oil made for saw use is imperative plus the fuel container should be vigorously shaken just before each filling. If the compression appears good, then check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for any decay or other damage. Make sure the carburetor fasteners are tight. Hope some of this helps!
Jul 10, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Craftsman chainsaw 18" 42cc doesn't start
Remove the spark plug and test for spark. If nothing, try a new plug set to 0.020" gap. If ok, put a small mount of fuel mix in the plug hole and try to start. If you get several pops, then check the fuel filter, air cleaner and muffler for plugging. Check the fuel lines for rot or damage. Make sure to use fresh fuel premix (40:1) using modern synthetic saw oil in it's own can and shake thoroughly just before filling each time. If you got no spark in the first test, expose the flywheel and ignition module. Remove the wire from the module that goes to the ignition switch and check for spark. If still nothing, replace the module using a thin business card for a gap gauge between the module poles and the flywheel magnets. If you did get spark, then investigate the ignition switch and wire for possible grounding. Hope some of this helps!
Jun 24, 2010 | Ryobi Factory Reconditioned 18" 40cc...
Poulan 6.75 Lawn mower will not start
Remove spark plug, clean and dry. Replace plug. Remove air filter. Spray WD-40 into carb opening; one second blast. Turn over engine, (pull handle). Engine should start briefly and run for 3 seconds.  If not, you are not getting spark to spark plug. If engine starts, you have a dirty carb and you can buy a rebuild kit from manufacture.
May 02, 2009 | Poulan Pro " Pro" Self Propelled Mower
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
50 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
