Question about Saeco Magic Comfort Plus Espresso Machine
Got an old saeco magic comfort 7/8 years old -
Just started reusing the machine and dont know how to decalcify the machine as cant find the manual!  Any help would be appreciated I have the same problem. The solution given is how to descale, decalcification is different. Any other solutions. I have done the descale and it still asks for decalcification. Also note it is the older Magic comfort, not the magic plus machine
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 16 Answers
You are correct to descale the machine. I am not sure how "decalcification" is different, but if the message is still coming up, you may need to have some repair work done. There are some sensors inside that can be cleaned manually if a descaling solution doesn't do the trick. You can do some work if you are mechanically inclined.
Posted on Apr 19, 2009
Saeco magic comfort has message brew unit blocked!
Manual on http://www.partsguru.com/user/Saeco%20%20Manual%20MagicComfortPlus.pdf
Feb 01, 2010 | Saeco Magic Comfort 103467 Espresso...
Water pump in Saeco Magic Deluxe
If you haven't cleaned the brew group, or decalcified the unit I would start there. This is something I do every 4 to 6 months (or anytime I notice the flow of coffee to start to slow down). This normally restores the flow to the original flow level. If you have already done these things you may want to give Saeco support a call and see what they suggest. They are extremely helpful, although very difficult to get on the phone as the phone system they use is horrible and hangs up after you hold more than a certain amount of time.
Dec 03, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco Magic Comfort Plus machine has message "Ventillate" how do you clear this?
open steam knob and water need start going on steam wand keep going couple minuts and you will see machine is ready,if you still have same problem thats mean your flowmetar is not good
Aug 03, 2009 | Saeco Magic Comfort Plus Espresso Machine
Decalcify
im not a saeco folks but i buy those machine on ebay and repair them decalcify ready to used mean its ready for you to put descaling product in machine and you press on it will start the descaling sequence if you dont whant to descale i sujject you do it if not go in our menu and push botton untill you see descaling finish or done thanks pierre p.s taking about descaling my machine vienna told me this morning time to descale it comme about every 3 months let me now i know those machine good
Jan 10, 2009 | Saeco Incanto Classic Espresso Machine
bye a good coffee descaler not vinager follow instruction on it normally fill the water tank leave room for the descaler start the machine open side valve leave it running for 15 second turn it off let it site for 10 to 15 minute after open valve for 30 second let it site for 10 minute and open valve repeat untill empty tank after clean water tank very good that descaler is acid nasty stuff after fill the water tank full of water start machine open side valve empty water tank that its good luck pierre p.s it take a while do descale good but worth it
Jan 02, 2009 | Saeco Magic Comfort Plus Espresso Machine
Making Espresso shots... how does the macine do this? Not in man
www.partsguru.com look to the left for Saeco Home Models, select that, then go the model you have and download the manual.
On a magic comfort it has two settings for adjusting the espresso shot besides the amount of the shot. .
On a magic comfort plus,
you can adjust the grind size, the amount used for the shot, preinfusion (a short shot of hot water on the grinds before the unit passes all the water through the puck (coffee grinds), temperature and amount of water for shot
Also, when setting the strength on this machine, don't use a full grind amount as it can jam the machine. use a setting of 6 or 7 max for strong shots, not the 8 or 9 setting!!!
Dec 03, 2008 | Saeco Magic Comfort Plus Espresso Machine
Saeco Magic Comfort +
How old are your machine?
What number is the grinder on?
How often do descale the machine?
/Mirran
Aug 26, 2008 | Saeco Magic Comfort Plus Espresso Machine
Saeco magic comfort coffee machine
sounds like the thermal resistor may be going bad.
Only way to get this fixed is having it sent out to a service center. Machine needs to be opened up and the resistor and a few sensor's need to be checked.
May 12, 2008 | Saeco Magic Comfort Plus Espresso Machine
Saeco Incanto will not power on.
The curcuit breaker on the boiler probably tripped. There are 2 of them on the boiler. You can remove the back cover to access these parts. If you are not comfortable with taking the machine apart, take it to a service center.
Check out www.CeriniCoffee.com
Authorized saeco service center for new york
Oct 25, 2007 | Saeco Incanto Classic Espresso Machine
Saeco Magic Comfort Plus Espresso Machine Logo
356 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
