Question about General Electric GFSS6KKXSS Stainless Steel Bottom Freezer French Door Refrigerator
Turn on fridge
A new GE gfss6kkxass french door. I set the temps to both and it returns to off. the frige does not apear to come on
  • Anonymous Apr 26, 2009
    I have the same problem. I set the temp on the freezer and refrigerator to recommended settings and it returns to "OF"??? Do I have to wait until it reaches the set temps for the "OF" to literally go off and display the temps they were set at? Thanks.
    Go this link about getting it to cool if you are having this problem. I don't want to steal bmalm's solution and he should get credit for it. Thanks bmalm!!!
    http://www.fixya.com/support/t1650450-ca...
Press the Ice Off button and the Freezer button together for thirty seconds. Set your temps at 36 for refrigerator and 0 for freezer.
if that doesn't work, press the freezer button and the energy saver button for thirty seconds and do the same thing.
Posted on May 30, 2009
Why is the freezer too cold and my fridge not cold at all
Perhaps the temp setting got turned by accident checckwhere it is set 4 or 5 should work
Jan 27, 2015 | Kenmore Elite 78722 78729 Bottom Freezer...
My L.G french door frige GR-B218WV ices up under the freezer drawer causing the drawer to jam or not close fully the seals seemto be in good order what can I do. regards Ern.
This is the common problem to everyone. Due to defrost failure. Check temp setting is not very low. Keep 5 degree.. Check thermostat, defrost timer are working properly. Now, manuyally press defrost switch or turn counter clockwise your thermostat. Then fridge shuts off and wait for sometimes to get complete defrost and then restart again by turning thermostat clockwise. Helpful?
Jan 30, 2011 | Refrigerators
I have an ge french door bottom freezer model gfss6kkxass. it has started collecting water under the vegtable drawers and leaking down front of freezer
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
ll
Sep 26, 2010 | General Electric GFSS6KKXSS Stainless...
My frenchdoor fridge keeps running constantly. Doors are fully closed and the temp seems right (now!!) but the motor keeps going. what can I check? Please & Thank you!
does it run all night too?
the fridge will run as long as it needs to to obtain and maintain the selected temperature,
the freezer should be set to zero and the fridge to 38
Sep 04, 2009 | GE PFS22SISSS Stainless Steel French Door...
Bottom freezer temperature rises as high as 35 degrees and drops only to a low of 15 degrees continually. ongoing for a month now. french doors fridge now has temp. fluxes within this past week. temp. goes...
check the defrost thermostat , and any temp sensor that can determine the freezer temperature.
If this fridge temperature is electronically controlled, the freezer control board must also be tested.
Click here to get all parts and diagrams for this fridge.
Regards.
Jul 09, 2009 | GE Profile PFS22MBW French Door...
Fridge works but doesn't isn't cooling
I will help but you need to confirm your model number. Is your model the one listed above your post? Let me know, Sea Breeze
Jun 19, 2009 | GE Profile PFS22SBSS Bottom Freezer French...
Cannot get the fridge to start cooling
If the panel temperature reads 0 F 0 F it is in the "DEMO" mode. This is normal if you purchase a floor model. To bring it back to normal mode press ENERGY SAVER & ADJUST FREEZER together for 3 to 5 seconds until it beeps. Then unplug the referidgerator for at least 30 seconds. Then plug it bck in. That will reset the stupid computer and get it back to normal operation.
Did you think this was helpful? Yes No
Feb 08, 2009 | General Electric GFSS6KKXSS Stainless...
GE PFS22MISBBB freezer not cold enough. Temp won't reset.
replace the fan as quickly as possible it may be shorting and causing damage to your control board,
Mar 30, 2008 | GE PFS22SBSSS Stainless Steel French Door...
Samsung french door fridge not working?
I had the same problem ("OF" on display and not working) and just found a fix and it worked (on SAMSUNG site).It was correctly stated that fridge is in "demo" mode. You need to push and hold POWER FREEZE and ENERGY SAVER buttons (not "Fridge button and the Power Cool buttons" as it was suggested above).
Oct 14, 2007 | Samsung RM255LASH Side by Side...
General Electric GFSS6KKXSS Stainless Steel Bottom Freezer French Door Refrigerator Logo
691 people viewed this question
Top General Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Shehu Pro
Shehu Pro
Are you a General Refrigerator Expert? Answer questions, earn points and help others
