Manual for hype jumbo universal 3 in 1 remote control
Part#822248537342
Here you go:
https://anonfiles.com/file/5a7569fbd912a9e8d2c12466c65e51c8
Posted on May 08, 2013
4 Suggested Answers
  • 6 Answers
SOURCE: omnitech jumbo universal remote control and vizio hdtv
Here are the instructions for auto code search from the Omnitech manual:
Automatic Search
There is another way to set up your controller, that does not use the brand code lists. You can let your
controller search through all of its available codes automatically in order to set the connection to the
target device. To do this, follow these steps:
1.Turn on the target device.
2.Point the controller at the target device and press and hold the Code Search button for around 3
seconds, until the LED light stays red.
3.Next select the type of device the target unit is by using the Cable/TV/VCR/DVD/Sat Buttons (i.e. if
it is a TV that you are trying to control, press the TV button). The LED light should then blink once,
then stay red.
4.Press the On/Off button on the controller slowly and repeatedly until the device you are trying to
connect with turns off. (Note: the LED light will blink each time you press the On/Off button). When
this happens, press the ENTER button in order to store the code and the LED light will turn off.
Posted on Jul 13, 2008
  • 10 Answers
SOURCE: NEED MANUAL FOR SHARPER IMAGE JUMBO UNIVERSAL REMOTE 1613086
The manufacturer of that remote is Emerson.  Here is the manual.
http://mscustomercare.com/forms/JumboRemoteEM_InstructionManual.pdf
Posted on Mar 27, 2009
rmoseng
  • 77 Answers
SOURCE: iwave Jumbo Universal Remote hookup
I have found the iWave, Innovage, and generic "JUMBO" are the same remote.
Here is the link to the manual. It looks like it has a easy to do auto-search button. If your TV is not listed use the auto-setup function.
http://www.vat19.com/dvds/jumbo-universal-remote-manual.pdf
Good Luck
Posted on Dec 17, 2009
I need a setup manual for the hype 4-in-1 universal remote control along with codes to a sanyo lcd tv
Common set-up codes for Sanyo band TVs are; 0291,0299,0295,0297. Try these codes. For more information check this link. Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
Dec 07, 2013 | Universal Remote Control Televison & Video
Tip
Emerson Jumbo Remote Manual Download
Download Emerson Jumbo Universal Remote Control Manual
Have you misplaced your Emerson Jumbo Universal Remote Control Owners Manual?
Would you like a digital, searchable, pdf version of the Emerson Jumbo Universal Remote Control Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
on Apr 30, 2010 | Televison & Video
Tip
Sharper Image Jumbo Remote Manual
Sharper Image Jumbo Universal Remote Control Manual
Have you misplaced your Sharper Image Jumbo Universal Remote Control Owners Manual?
Would you like a digital, searchable, pdf version of the Sharper Image Jumbo Universal Remote Control Users Guide?
I hope that helps.
I am having trouble programming my hype jumbo remote to my Emerson flat screen tv
I had problems with the instructions on how to program my Hype Jumbo remote. I finally figured it out. It was missing the step using the ENTER button. Here are the modified instructions:
TO PROGRAM
CODE SETUP
1. Manually turn on the device.
2. Aim the remote control at the device and press and hold the "CODE SEARCH" button until the LED indicator light shines, then release the button.
3. Press and release the "DEVICE" button that corresponds to the device you want the remote to operate.
4. Aim the remote control at the device and press the "POWER" button once. The LED indicator will search for the correct code blinking twice for each code.
5. The correct code will turn off the device. When the device turns off, press the "ENTER" button immediately.
6. Press the "POWER" button again to turn on the device. If it does turn on, verify the remote will function by changing channels, volume, etc.
Dec 11, 2012 | Televison & Video
Looking for a jumbo remote that will operate a new 26 inch Vizio Montior. The old one don't work. Is there a new version?
A remote is not designed to control and Moitor. They only run by the video/sound output from the pc. So I am taking it for granted that you meant TV instead of Monitor.
A. Before buying a new remote try replacing the batteries first.
B. I found the Innovage Jumbo Remote Control manual and it has no code for the Vizio TV, you will need to utilize the remote's "Code Search" option.
C. Instructions
1. Turn on the Vizio TV.
2. Aim the Jumbo Universal Remote at the Vizio TV and hold down the "Code Search" button on the remove for roughly 3 to 5 seconds. The LED lights on the Jumbo Universal Remote will come on.
3. Press the "TV" button at the top of the Jumbo Universal Remote.
4. Start pressing the "ON/OFF" button repeatedly until the Vizio TV turns off. This will likely take several minutes due to the amount of available codes.
5. Press "Enter" on the remote immediately after the Vizio TV turns off to save the code.
6. Test the Jumbo Universal Remote by trying to control the Vizio TV with the remote. If the control doesn't work with the remote, repeat the entire process.
Good luck.
Jun 03, 2011 | Innovage Jumbo Remote Control
I have a emerson jumbo universal remote control no manual need code for old sanyo tv
click this link for pdf manual
Aug 01, 2009 | Innovage Jumbo Remote Control
Codes to program Innovage Products Jumbo Universtal Remote
Innovage Jumbo remote codes for RCA TV; 000, 003, 004, 005, 007, 009, 011, 015, 048, 082, 092, 094, 096, 098, 102, 103, 107, 113, 125, 129, 167, 179, 187, 188, 191,194.
Pansonic DVD; 175.
Pansonic VCR; 021, 060, 115, 125, 138, 148, 149.
Philips DVD; 173, 183, 198.
Bell ExpressVu; 168, 187, 194.
Dec 18, 2008 | Televison & Video
Universal Remote iwave
I Have The Codes,But No instructions!! Big IWave . 0054-Philips Hitachi-0145 JVC-0053 LG- 0178 OR 1265
Jun 09, 2008 | Hitachi 50HDA39 50 in. Plasma HDTV
Televison & Video Logo
1,548 people viewed this question
Top Televison & Video Experts
Electro Med Services...
