Question about HP LaserJet 3800 Printer
10.00.00 supply memory error on color laserjet 3800 printer
SOURCE: Error 59.99 Printer Error
An error occurred in the secondary transfer
engaging mechanism.
1. Faulty secondary transfer engagement
sensor. Replace the secondary transfer
engagement sensor.
2. Faulty secondary transfer engaging
solenoid. Replace the secondary transfer
engaging solenoid.
3. Faulty feed motor. Replace the feed
motor.
4. Faulty DC controller PCB
Action: Replace the DC controller PCB.
Posted on Jan 22, 2008
57 varieties
  • 1653 Answers
SOURCE: error memory 10.1000
This means that a specific cartridge has an e-label error.
The solution is to:
1. Reinstall the print cartridge.
2. Turn off and then turn on the printer.
3. If the problem is not solved, replace the cartridge.
Posted on Oct 07, 2009
57 varieties
  • 1653 Answers
SOURCE: hp color laserjet 3550 59.99 printer error
This error shows
An error occurred in the secondary transfer engaging mechanism.
1. Faulty secondary transfer engagement sensor.
Action: Replace the secondary transfer engagement sensor.
2. Faulty secondary transfer engaging solenoid.
Action: Replace the secondary transfer engaging solenoid.
Action: Replace the feed motor.
Posted on Nov 09, 2009
SOURCE: 10.10.00 supply memory error coming on HP Laserjet 5200 Printer.
Dear Sir,
I has change the printer cartridge. After changing the printer cartridge above mentation comming. When I am making printer power on the (10.10.00 supply memory error) display. Please tell me how to solve this problem. Best regards,
Thanking
Ajom Khan Hero
Mobil No.092 5192797.
Al Nahr Co.Ltd
Tripoli - Libya
Posted on Feb 20, 2010
SOURCE: hp laserjet m1522nf 10.0000 supply memory error
had same problem. It turns out I didn't remove all plastic caps from new cartridge (mine came with orange-color). Once I did that, problem solved.
Posted on Jun 23, 2010
Supply error
Just bought laserjet M1213nf MFP and installation done by the HP reseller engineer. From first use after power on every time this error is flashing
10.1000 Supply memory error
To accept press OK
After pressing OK this error keeps flashing at regular interval. The printing etc functions are OK, what can be the problem?
Apr 01, 2014 | HP LaserJet Pro 400 color M451dn - Printer...
Supply memory error color
A "supply memory" error is usually caused by a bad toner cartridge. Each cartridge has a chip that is read by the printer.
Try reseating the cartridges.
Did the error occur after you swapped out a cartridge?
Jan 13, 2014 | Hewlett Packard Printing & Imaging Refurb....
Hp color laserjet cp2025 10.1000 supply memory error
Hp color laser jet cp2025 10.1000 supply memory error solution
May 30, 2012 | HP Office Equipment & Supplies
Hello I have a problem with the work printer. It is a 3500 hp color laser jet and it is having a 10.10.00 supply memory error. I'm not sure what to do. Can you please help me?
10.10.00 SUPPLY MEMORY ERROR
Missing memory on supply
Black print cartridge
1. Open and close the front door.
2. Ensure the cartridges are fully seated.
3. Swap the cartridge for the color indicated with a cartridge in another slot to determine whether the error follows the cartridge or stays with the slot. If the error follows the cartridge, replace that cartridge, otherwise, continue with step 4.
4. Check the memory controller PCB contacts to the memory tag. Clean if dirty.
5. Reseat the memory controller PCB connector J201 and DC controller PCB connector J1025.
6. Defective memory controller PCB, replace the memory controller PCB.
7. Defective DC controller PCB, replace the DC controller PCB
Aug 25, 2011 | HP Color LaserJet 3500 Printer
HP Color LaserJet 3800 dtn printer. Error message says 49.4C06 Service Error
49.XXXXX ERROR A critical firmware error has occurred.
If the message persists with different programs and print jobs, turn the printer off.
Remove all memory DIMMs or thirdparty DIMMs from the printer. (Do not remove the firmware DIMM in the lower slot J1).
Remove the printer EIO card.
Turn the printer on.
If the error does not persist, install each DIMM and EIO device one at a time.
Turn the printer off and then on again after installing each device.
Replace DIMMs and EIO devices as necessary.
If the error persists, replace the firmware DIMM.
If the error persists, replace the formatter and calibrate the printer.
Jun 16, 2011 | Office Equipment & Supplies
I am getting error: 10,1000 supply memory error reinstall
You are using re manufactured toner and it has a bad chip. Replace the toner.
Jul 06, 2010 | HP Laserjet CM2320nf All-In-One Color...
I am getting 10.00.01 memory supply error on the cyan cartridge of my HP color laserjet 3500. The cartridge is nearly full and was working fine. I have tried cleaning the memory controller PCB contacts but...
I had a like problem and found that the chip on the cartridge was mounted without enough spacer such that contact was not being made with the memory controller PCB connector.  I cut some two-sided tape and put it behind the chip such that it stuck out further so that better contact could be made and the problem was solved.
Apr 28, 2009 | HP Color LaserJet 3500 Printer
HP LaserJet 3800 Printer Logo
279 people viewed this question
Seeker5211
Seeker5211
