Question about AOpen AOR-401M Router
Can't find WEP key for DS
I have att Motorola wifi modem serial number 50078832.
I can not find an WEP key or anything compatible to work with my DS lite or WII.
  • 1 more comment
  • Anonymous Feb 28, 2009
    i cant find mywep key
  • Anonymous Apr 03, 2009
    cant find out what wep key is
  • Anonymous May 10, 2009
    i dont have a sticker, as everyone has clearly pointed out you need one to work...
    any clue what to do?
    ~ morgan ~
    Genius:
  • 1,269 Answers
You can see the WEP key at the side or bottom of your modem. Its the 10-digit code. If it is not listed there, you need to access the Setup Page of Motorola modem. Go to internet explorer and type http://192.168.1.254
Posted on Jan 20, 2009
Ds lite wi fi connect wpa
Try changing your WiFi encription to WEP or no security, this should be available on your cablemodem/router web internface (need a user and password for that) under the Wireless/Security option.
DS Lite is not compatible with any other WiFi encription for online gaming: "Important note about the Nintendo DSi and WPA security: While the Nintendo DSi is compatible with WPA security, Nintendo DS games with online play still require the use of WEP or no security to connect with the Nintendo WFC. Therefore, your connection settings for using these games must be set up on slots 1-3. If you need more details on using your adjusting your router's settings,click here and select your router (if available).
Nov 04, 2013 | 2wire Computers & Internet
DON'T HAVE SECURITY SUPPORT FOR MY WIFI CONNECTION FOR DSLITE
The problem is the fact the nintendo ds only supports only one security setting which is 128 bit wep. You were probaly trying to connect to a modem with wpa2 or something else. If you want your ds to connect, consult your modem's manual to change the security to 128 Bit WEP and think of a ten character password (no less or it won't work).
Dec 25, 2011 | Nintendo DS Lite Console
The access point's security settings are not supported by the Nintendo DS
WEP and WPA are types of security that are used to protect home wireless networks. WEP is the only security setting that works with the Nintendo DS and Nintendo DS Lite. WPA and WEP are both compatible with the Nintendo DSi. If you are not sure how to find your router's WEP or WPA Key or if you have problems entering it into your Nintendo DS, try the following tips:
so if your wifi is WPA. you wont be able to use wireless
but if your wifi is WEP you can.
WEP is not recommended because it is not secure. Easy to hack
Mar 20, 2011 | Computers & Internet
We have an error code 51310 for wifi! Can you
Error Code: 51310 Our experience has shown that this error message is typically caused by WEP Key issues. Please read the following information:
  • Check Nintendo's router info for special notes, if available, for your router.
    1. Click here to go to our Wireless Router Configuration page.
    2. Use the drop-down box on the left to select, if available, your router manufacturer.
    3. Click on your router's model number, if available.
    4. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
  • Are you using WEP security on your router?
    1. Log into the router using the default IP (consult your router's manual for assistance)
    2. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
    3. The WEP key is case sensitive, so be sure to enter it exactly as it appears.
    4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
    5. The WEP Key must be a Hexadecimal (1-9, A-F, no other special characters or letters).
    6. Verify they are using the WEP Key in the first (#1) slot. Even though your router may have multiple slots, the Nintendo DS is only compatible with the WEP Key in slot #1.
  • Check to see if your router is using MAC filtering.
    1. Log into the router using the default IP.
    2. Find the section for MAC Filtering (typically under "Security").
    3. If MAC Filtering is on ("enabled"), enter the Nintendo DS’s MAC address to the list of approved MAC address. For info on locating the DS’s MAC address, click here. For instructions on how to find the MAC address for Nintendo DSi or Nintendo DSi XL, click here.
      (For assistance with locating the MAC Filtering section of your router's setup tool, please consult the router's manual or contact the manufacturer.)
  • When using connection files 1,2, or 3 on any Nintendo DS system:Check to see if your router is set to "g only" mode. In order to work with the Nintendo DS, the router must be set to "mixed" or "b and g".
Jun 11, 2010 | Nintendo DSi Black Console
I am trying to get wifi on my nintendo ds lite ,
The DS's Wi-Fi capabilities are not up to par and can unfortunately be a little fickle sometimes, and many people would rather buy another wi-fi device before trying to set it up, but if you do want to attempt to obtain your wep key so you can have wi-fi I am happy to assist you.
What you must do is get on to a computer that is hooked up to your wireless modem. From there you should be able to bring up on your system settings the information about the modem. Depending on what type of modem it is, you may have to flip through the more advanced information to find the wep address.
Once you do, you will have to put that code into the DS and pray that it works, because much of the time your DS will still not be able to connect.
May 14, 2010 | Linksys WRT160N Wireless Router
What is wep key for wifi ds lite that they r asking for
The is the hex code you need for a secured network.. if you have FIOS its on the side of you modem
Nov 08, 2009 | Nintendo DS Lite Console
Cant get wifi on my ds even with WEP key
The DS doesn't have the best WiFi signal.
Make sure you are close to your router for one.
Also check the WEP key as it may say the AP (access point) isn't there if the WEP is wrong.
Also some routers won't connect properly to the DS unless the IP,Gateway, and DNS are set manually.
If you choose to set the AP info manualy then you need to find the you AP's IP address.
Commonly this would be 192.168.1.1 however it varies from one brand to another or may be changed manualy.
Try these settins with the corrected IP adress number as the gateway.
IP Adress 192.168.1.152 (this is you'r DS IP adress. The 3rd digit should be the same as you gatway's 3rd digit. The fourth digit can be any number that isn't used on your network.
Subnet mask 255.255.255.0
Gateway 192.168.1.1
DNS Pri 192.168.1.1
DNS Sec 192.168.1.0
(Usually I set the Gateway and DNS numbers the same and it usually works. The Gateway is the IP address of your wifi router.)
If this fails and all numbers are correct, then it may be that the WiFi router will not work with the DS as some brands simply refuse to work with it for unkown reasons.
Anohter solution is to get a WiFi USB dongle and connect to that.
May 07, 2009 | Nintendo Pokemon Pearl Version for DS
Wep key
Try admin for the username and motorola for the password.  The default SSID is Motorola.  Here is the pdf with all of this info.
http://broadband.motorola.com/consumers/products/SBG900/downloads/SBG900_Quick_Install%20_Guide.pdf
Apr 24, 2009 | Arris SURFboard® SB5101 Cable Modem
Att 2701 hg-b modem
Hi , the 2701HG-B by default uses the last 3digits of the SN number as the SSID and the 10 digit number in brackets as the WEP key to access the user interface of the 2701 type in the address bar of your browser 192.168.1.254 and push enter, to access the interface program you will need to run the system set up and you must know the keycode from your service provider and the username and password
Jan 06, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Nintendo DS connection to wifi
You need to make sure your router is capable of transmitting at the Wireless G frequency and use a WEP encryption on your key or no Encryption however I reccomend WEP Encryption.
Dec 07, 2008 | Video Game Consoles & Games
AOpen AOR-401M Router Logo
1,191 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
