Question about Craftsman Arnold Mtd Snow Thrower Blower Light Easy Mount
I am replacing the engine on a Craftsman Snow Blower. What is the engine to chassis mounting bolt torque amount?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,095 Answers
Do not have a true answer other than to say it's probably a 5/16" bolt. 40 ft lbs would be about right for that
Posted on Jan 25, 2014
2 Suggested Answers
ToolBoxHero
  • 171 Answers
SOURCE: I need a replacement belt
Sears will not tell you what size of belt you need. They only list parts by part number. But this machine uses MTD belts and you can get them at searspartsdirect.com or your local mower shop can order them through MTD.
Part Listing: http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Snow-removal-equipment-Parts/Model-247886640/0247/1507200?sid=MMLxMerchandizexManualsModelxcraftsman%2088664x247886640
Manual: http://www.managemylife.com/mmh/owner_manuals/search?query=craftsman+88664
Here are the two part numbers for the two belts on the machine. MTD Part #: 954-0343
and #: 954-0430B
Any other questions, please ask. Remember to rate this answer if it helped.
Posted on Jan 11, 2011
What is the head gasket torque spec for a 8.5 horse power horizontal shaft brigg and Stratton engine.
not nearly as critical as you think. I bet 40 ft lbs on all bolts would be fine. It's more the consistency among the Bolts than the actual torque
Sep 28, 2014 | Craftsman Snow Blower / Snowblower Bottom...
Craftsman Snow Thrower engine spews balck smoke
the choke is stuck so remove the cover and look for the choke to see why it,s not movin
Feb 13, 2014 | Craftsman Arnold Mtd Snow Thrower Blower...
Setting valves on craftsman snow blower model 536.8818000
Howdie what year is it ?they should set them selfes but only do you have to set them if it is nut adjust then goto the dealer for the spec,s
Jan 11, 2014 | Craftsman Arnold Mtd Snow Thrower Blower...
5hp Briggs engine on craftsman snow blower won't stay running
Remove the nut that holds the float bowl on and clean the hole on the side and the hole that goes down the center of the bolt.
Jan 05, 2014 | Briggs & Stratton Snowblower Snow Blower...
Craftsman 32" 10 hp
3600+/- 20rpm. That's the top end, I'd say idle should be between 1200 and 1500, but I don't know what model motor it is. I'm assuming its a Tecumseh snow king engine
Nov 22, 2013 | Craftsman Arnold Mtd Snow Thrower Blower...
I have a Sears snow blower. It is not throwing even a light snow. On engaging auger both sides spin slowly. I observed one side of the auger stops spinning when proceeding into snow pile. What may be the...
many Sears/Craftsman snowblowers have a shear bolt on the auger shaft or one on each side. This bolt is designed to break under a specific amount of force to prevent damage to the gear box or drive assembly if the blades encounter an immovable object or something becomes jammed (even a newspaper buried in the snow can cause this). They likely broke at some point during use in the past and you did not realize this, or they were not properly installed when the blower was new. If you check the auger shaft and find one or 2 holes that look like something should be there, then you found the most likely problem. If you reply with the model I can tell you exactly where to look and the part # or if you realize the bolts are missing you can contact that parts dept at Sears with your model and they can provide replacement bolts. Can be a pain with small things but a lot less expensive than a new gearbox.
Jan 13, 2011 | Craftsman Garden
Craftsman Snowblower. One auger is disengaged...turns freely when touched....does not push snow
the augers on many craftsman snowblowers have a sheer bolt. If the auger encounters too much resistance, ie, a foreign object like a piece of wood or even a newspaper buried in the snow, this bolt will break off preventing damage to the gear box, which is a lot more expensive to repair than replacing the bolt.
This bolt requires not tools to install, just insert and secure with a cotter pin.
The parts dept at sears can sell you the replacement bolts with the correct sheer force rating. Have your snow blower model number handy when you call or go in.
Dec 27, 2010 | Craftsman Garden
I have craftsman snow blower 5 hp 24inch model #
does the impeller spin and not the augers.if so check sheer bolts.if neither impeller or auger spins check auger belt.
Feb 22, 2009 | Craftsman 16" High Garden Tractor Snow and...
Scheduled Maintenance Items Are Not Detailed.
interval_box.gif Replace engine oil and oil filter interval_box.gif Rotate tires Inspect the following: interval_line.gif Automatic transmission and differential oil interval_line.gif Ball joints and dust covers interval_line.gif Brake linings/drums and brake pads/discs interval_line.gif Drive shaft boots (re-torque flange bolts) interval_line.gif Exhaust pipes and mountings interval_line.gif Rack and pinion assy. for leakage interval_line.gif Steering linkages
Additional Maintenance Items for Special Operating Conditions:
Driving on Rough, Muddy or Snow-Melted Roads interval_box.gif Inspect nuts and bolts on chassis and body Driving on Unpaved or Dusty Roads interval_box.gif Inspect engine air filter Towing a Trailer or Using a Camper or Car-Top Carrier interval_box.gif Inspect nuts and bolts on chassis and body interval_box.gif Replace automatic transmission and differential oil
Jan 19, 2009 | 1998 Toyota Avalon
Craftsman Arnold Mtd Snow Thrower Blower Light Easy Mount Logo
90 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
