Question about Fujitsu fi-5220C Flatbed Scanner
FLATBED WON'T SCAN SAYS SHIPPING LOCK - Fujitsu fi-5220C Flatbed Scanner
2 Suggested Answers
john_madd112
SOURCE: Fujitsu fi-5750C flatbed will not scan. I keep
Mine came with the same error message. If you look through the glass into the left front corner, you should see a spring loaded belt tensioner device. It merely hooks into the bottom plate against a spring to keep the belt tight. On my 5750C, the belt tensioner had slipped out of the base during shipping. The hardest part of inserting it back into the base was getting to it. Directions to do that are on this site at .../support/t484836-taking_apart_flatbed.
Posted on Nov 15, 2011
Won't Scan -- "Cannot properly communicate with the scanner"
I think the USB cable is defective or the scanner is failing.
Apr 25, 2017 | Epson Gt-15000 A3 Flatbed Scanner Eu-45
2005 G6 remote . lock won't work but unlock does. Does not seem to be battery. Maybe the connection inside ?
Knowing the poor quality of this remote I would buy another remote on eBay and that will likely solve the problem. Here is a link to an eBay auction. Just $17.99 and free shipping.
Oct 10, 2012 | 2005 Pontiac G6
Cant scan with my trusty old AGFA SnapScan 1212u with Lion OSX
I've got a solution where you won't spend any dime on it. It's a long road, but in few words, you need to install SANE for Mac, get the SnapScan1212U.bin file (you can get it from the Windows Installer), and a scanning software such as Snac for Mac, and/or Adobe Acrobat X.
I'll prepare a HOWTO only if someone really needs it.
Greetings,Diego.
Apr 22, 2012 | Agfa SnapScan 1212u Flatbed Scanner
Fujitsu fi-5750C flatbed will not scan. I keep getting an error "Irregular status is detected in the scanner. Anomaly in Flatbed motor operation. There are some codes: Sense Key = 0x4; ASC=0x580;...
Sep 20, 2011 | Fujitsu fi-5750C Flatbed Scanner
My VZ9996U1 built-in dishwasher won't lock &
sounds like the door latch is broken, turn off power to unit and remove in side of door, about 20 screws, at th etop of th edoor you will see the latch it will have several wires going to it, you may even find broken parts (PLASTIC ) you can order parts from here http://www.appliancepartspros.com/ they have very fast shipping you just need all the info on the machine
Jul 27, 2011 | De Dietrich 24 in. DVI100 Built-in...
The 12x12 scrapbook pages scan beautifully, but they won't save to my computer! How can I save the images as jpegs?
Hello annabanana7
You can try with a third party twain software , like FreeKapture from : http://freekapture.en.softonic.com/
Works on all Windows versions , including Vista and Windows 7 .
Best regards ,
fanaudi .
May 16, 2011 | Mustek A3 USB Flatbed Scanner
I cannot use scanner Lide 25.. because show error : "release the lock switch,detach the I/F cable and reconnect" How solution?
Sounds like the scan head is locked. This is usually done so you can transport the scanner without bouncing the scan head out of alignment. Look under the scanner and you will see it. Make sure it's in the UNLOCKED position. You may need to power the unit off/on to reset it or restart your computer to get a fresh attempt at the scanner.
Mar 05, 2011 | Canon CanoScan LiDE 25 Flatbed Scanner
When I am scanning negatives, and try to save my scan to a file on my computer, it sounds like something is stuck and when the picture is finally saved, the middle of it is blank or shows rainbow-like wavy...
There is usually a locking lever on the bottom of the scanner to lock the mechanism during shipping or transport. Make sure that lever is fully in the unlocked position!
Oct 22, 2010 | HP ScanJet 3970 Flatbed Scanner
Probmlem in printers scan locked
the scanner is locked into its docking point this lock is incorporated into the machine to prevent the ccd unit from being damaged during shipping.
these locks can be located in several different places depending on the make and/or model.
first lift the flatbed cover to a 90 degree angle and look for the switch on the glass deck on the left side about mid way.
these locks can also be located on the roof of the standard out put bin to the left side.
in some units this lock can be found on the outside of the case on the left side.
Jan 01, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Error message
Get another scanner. Check whether the lock has not been enabled at the bottom of the scanner. This has happened with me as well and a known Visioneer problem.
Sep 19, 2007 | Visioneer OneTouch 8920 Flatbed Scanner
Fujitsu fi-5220C Flatbed Scanner Logo
Top Fujitsu Office Equipment & Supplies Experts
Tony
Electro Med Services...
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
