Question about Samsung Microwave Ovens
We found model # for Samsung micro wave door will not stay latched tight model # is SMH7174WC/E how do we take door apart? thank you
  • Samsung Master
  • 9,098 Answers
This service manual should help you.
If you need to order any parts, the best bet is to get the full model number from the tag in or on the unit and call Encompass toll-free at 866-779-5835.
Posted on Jan 09, 2013
MicrowaveSvc
  • 9098 Answers
SOURCE: Door Disassembly
Actually, the spring is probably okay. What breaks is either the latch head (with the hook-like protrusions) OR the spring mounting tab on the inner side of the outer door panel. The spring connects to both of these parts. The outer door panel is not availablke as a separate part, so if that's where the break is, you'll have to get a bit creative and clean it squeaky and use epoxy (like JB Weld, but never use "super glue") or you can drill into the panel slightly and install a small screw eye or glue it in place. Even if the spring mount on the inner door panel is not yet broken, while you're in there, it's a good idea to clean it squeaky and add some epoxy to strengthen it. To get to the screws, you have to remove the choke cover (see sample photo below). It's usually not necessary and is better not to remove the door. You can set the oven on its left side on a table top, open the door carefully, and ease it down to the table top. Then you have a level, stable area to work on the door. If the problem is the latch head (ref # 5-2-2) then I would recommend replacing that part instead of gluing it. That's because the new part may be an improved version. Plus you'll start out fresh. The part # is LSTPPB030MRF0 (zero on the end, not an "oh") You can order Sharp parts from http://wwww.wehaveparts.com You can find a helpful exploded view of the door here: http://207.234.249.73/mwd/r1480_control_door_exp.pdf
Posted on May 11, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Sharp Carousel Microwave door latch stopped working door won't stay closed
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have *critical* safety & disassembly info at our site, linked here: http://tinyurl.com/yzjozk
We also have this full service manual at our site: http://www.microwavedisplay.com/R1480_R1481_R1482_sm.pdf
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 18, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Broken door latch
The latch head (the part you describe) is ref # 5-7 in the parts list and is part # LSTPPA169WRF0 (that's a zero on the end, not an "oh") You can get it from Tritronics at http://www.wehaveparts.com We have the entire service manual on our site: http://www.microwavedisplay.com/r930ak_aw_sm.pdf I appreicate your rating. Good luck!
Posted on Feb 10, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: samsung mw4699s fuse replacement
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
The TCOs you need to be concerned usually with have black wires. You can ignore the ones with blue / violet wires in this case.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can order Samsung parts here.
Posted on Sep 01, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Broken door latch on Model 63679 Kenmore Elite Microwave.
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can find helpful exploded views by entering your full Kenmore model number at the Sears parts site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Please be aware that you may have a broken spring mounting tab on the inner door panel.
In such cases, the best way to fix that is to drill a hole in the remaining material, insert the spring, then add a dab of epoxy where they spring attaches to the panel.
Posted on Jan 18, 2009
I have a emmerson 1000 watt microwave its about 3 or so years old. it stays on even when the doors open. so when its done and u take it out, it keeps on going around?
micro-switch if faulty or in stuck position thinking that it is okay to start/run microwave . these machines are mostly made in china and are sensitive of slamming the door too hard the plunger that insets into wave there is a micro-switch, you will have to take apart the wave..sorry ..
Oct 14, 2017 | Microwave Ovens
My feigidiare micro wave door won't close tight
I would really need the full model number to help you.
Feel free to contact me via microwavecontrol.com with your full full model number and FCC ID number from the tag or even better, a clear photo of the tag itself.
Sep 30, 2016 | Microwave Ovens
The door latch broke
Slightly different model, but this will help you fix it.
https://m.youtube.com/watch?v=JqeeGBhRwFw
Feb 06, 2016 | Samsung SMH2117S
Genn-Aire JUMV 8208BAB door on microwave will not stay shut
try to adjust the latch, if not you must replace go to www.repairclinic.com and buy it
God bless you
Jul 16, 2012 | Microwave Ovens
When micro wave oven is in use, I can feel air coming from the door. is it leaking micro waves?
Not likely if the door seals are intact, clean, and the door is latched. The pin-holed screen that you can see through stops the microwave energy. Hope this helps!
Jan 25, 2011 | LG LMH1017 Convection Microwave Oven
The micro wave door is warped so that the top right latch will not fully engage. How do I fix it?
If the door is warped, buy a new microwave but that is very unlikely.
Release the lower hinge screws and square the door up to the latches then tighten the fixing screws.
Hope that helps.
Jan 12, 2011 | LG LMV1630ST Microwave Oven
Jenn-Air micro-wave oven serial number #JMV8208AAS
This is the door latch, and replacing it is not a bad job for a do-it-yourselfer, in case you or someone you know may want to do it.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
You have to separate the door panels (as shown in the attached photo) and then you'll see how you can replace the broken door latch. (Don't lose the spring!)
Or you can watch a YouTube video (not a video I made) that demonstrates how it's opened.
If you don't want to do it yourself, you can find your nearest Jenn-Air / Maytag-authorized servicer here.
They generally charge about $75 to visit the home, $75-90 to do the repair work, and the part may run about $15 or so. If nothing else, you can save about $75 by taking it to the shop yourself.
I'd suggest a helper for that task, and you can download installation instructions here.
Nov 05, 2008 | Jenn-Air JMV8208AAS Microwave Oven
Apr 18, 2008 | Sharp R-1480 Microwave Oven
Stuck door latch
no call a tech micro-waves can be dangerous to work on
Dec 22, 2007 | Whirlpool GH8155XJ Microwave Oven
Microwave Ovens Logo
269 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
