Question about Advent Computers & Internet
My laptop battery willnot charge
Did not use laptop for a couple of months after buying it ,but after first use battery refused to charge -do i need new one?
    Novelist:
    Champion:
  • 233 Answers
For this kind of issue, you may try the following troubleshooting steps:
Take your laptop battery out, plug in the charger and see if the laptop works.
If it works, the battery may be the problem.
Check the AC Adapter
Check to make sure the adapter is plugged securely into the wall outlet, connected firmly to the adapter box and to the back of your laptop.
Most AC adapters have a little light in them on that rectangular box in the middle of the cord that lights up when it's getting electricity.
If that light isn't on, try a different outlet.
Check your fuse or circuit breaker box and plug a different device into that outlet to make sure there is power to it.
If it still does not light up, your adapter could need replacing.
Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.Remove the Battery Sometimes it's as simple as a seated battery.
Remove the battery entirely and clean out any dust, lint or hair that may be clogging the connectors and preventing a proper connection.
Reseat the battery securely and make sure the little locking pins that hold your battery in place are securely fastened and there is no movement.
hope this helps
Posted on Jan 10, 2013
AvioriX
  • 689 Answers
SOURCE: Battery failure
Yes perhaps you can be sure if you BIOS up to date. latest version of BIOS is v1.20. This version has several important fixes including critical battery wake up. You can obtain the BIOS from Toshiba support website. I am adding the direct link for your convenience.
http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=1721794xml&sliceId=&dialogID=30999201&stateId=0%200%2030995558
BIOS update is a critical process that you should close other applications and make sure computer is on AC power. the update process takes few minutes.
If the Issue persists after BIOS update you can think about replacing the battery, Just to remind you that usually brand new laptops warranty covers the battery for a year. So you have said that its only 11 months, you can think about using warranty.
For Toshiba Tech Support
1-800-457-7777
Good Luck
Posted on Jan 10, 2008
antiochpc
  • 1314 Answers
SOURCE: I Have a Toshiba A135
Unforutnately there is no way of telling if it is the battery or the charging board in the laptop. However, 98% of the time, it is the battery because the battery life in a laptop is very short.
Did you find this message helpful? If so, please give a good rating of fixya. Thanks.
Posted on Dec 25, 2008
  • 3940 Answers
SOURCE: the battery is not charging
Normally, one of 3 causes.
  1. Dead Battery
  2. Bad connection of battery interface on Motherboard.
  3. The AC Adapter sensing pin (In the center of the plug) is damaged (If the system cannot sense the AC adapter, the charging circuit is disabled.)
Troubleshooting:
  1. Try a different AC adapter (Any Dell D-Series system adapter is interchangable)
  2. If no difference, then next is replace the battery.  (The battery on a portable is a consumable item, and the battery life is generally 300 to 500 recharge/discharge cycles  around 18 months)
  3. If no change with battery or AC adapter, then the failure is the charging circuit of the motherboard.
Posted on Apr 11, 2009
Ctrlr4repair
  • 91 Answers
SOURCE: bettery can't charge
you may have the wrong type of charge, your port where your charge cord go in may be loose or not connected correctly anymore.
You also may want to check into buying a new battery for that laptop. Depending on how old it is it may of died after alot of use.
I'd test it using those two ideas first. If that doesnt work contact the maker of the laptop.
Posted on May 05, 2010
  • 2567 Answers
SOURCE: My toshiba satellite m60 (6
First, you need to make sure it is not a power supply problem. Please follow the diagnostic tests explained in this article:
http://www.fixya.com/support/r6395191-troubleshooting_laptop_power_failures_ac
Once you made sure it is not a power supply problem, perform the next batch of diagnostics tests outlined in this article:
http://www.fixya.com/support/r6416948-troubleshooting_laptop_power_failures
Posted on Jan 01, 2011
Battery wont charge
A lot of electronic equipment nowadays is pretty finicky about the power supply and battery. Did you buy an approved battery for you laptop? The computer may refuse to charge the battery if it does not recognize it as compatible.
Nov 27, 2013 | Dell Computers & Internet
My aspire starts blinking when i charge it
What's blinking the battery charge light? If so that is not a problem unless the battery is not charging. The battery only has a useful life, then it has to be replaced when it refuses to charge. If you AC Adapter is ok and allows you to get on the laptop and work, then your battery needs to be replaced.
You can look at the power options in the control panel to see if the battery is holding a charge. Or you can remove the power cord and work off the battery and if it goes dead real quick, that's another indication that it needs to be replaced.
May 12, 2012 | Computers & Internet
Compaq Presario CQ60-215DX. Doesn't start
You will need to buy a new battery, there is no way old one will be OK. To see if it works, remove battery, and use wall adapter ONLY, PC should work fine. If not maybe Flat CMOS, replace, If replace and still NO go.must be bad motherboard (maybe try charge battery 5 hours left alone)
Mar 27, 2010 | Compaq CQ60-215DX Notebook
Have not used my shoprider cordoba for a couple of months as we have been away in England - but would not start - think it is the controller that has died but the scooter has not had much use at all (we...
Scooters should be charged weekly, leaving for 2 months without a charge will cause the batteries to be so low that they cannot recharge.These type of batteries willnot recharge never mind how long you keep them on charge.
I would suggest it needs some more batteries, yes expensive.
Try and buy things from malta there must be a local scooter shop that can supply you.Plus being malta a dealer maybe able to confirm what i`ve said and if you buy from him ,he will be able to help you with niggly problems
Oct 16, 2009 | Shoprider Sprinter 889B-4 Scooter by
Dell Inspiron 1525 Battery won't charge
i recommend you to buy new one.. for dell 1525 .. must better
Jun 08, 2009 | Dell Inspiron 1525 Notebook
Battery not charging!
If the battery is 2 years old, then buy a replacement battery, see if it charges. Portable batteries are good for roughly 300 to 500 recharge/discharge cycles before they begin to fail roughly 18 months. Dell warrants the Battery for 1 year, so there is no warranty on the battery. If a replacement battery doesn't charge, then the motherboard will need to be replaced. If under warranty, Dell will fix it, if not, motherboards are $100-150 on Ebay.
May 21, 2009 | Dell Vostro 1500 Notebook
Battery will not hold charge ,where can i buy new battery
HI,
if your battery charge fully and only long with 2 or 3 hours it is normal don't worry no need to change.
but if you charge it and a minimum of 30 mins and it will drain need to chnage the battery unit.
thanks.
Mar 29, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Computers & Internet Logo
46 people viewed this question
Top Advent Computers & Internet Experts
Lee Durbin
Lee Durbin
Computer Links
Are you an Advent Computer and Internet Expert? Answer questions, earn points and help others
