Question about Sharp AL 1631 Copier
Poor quality copies
I am getting poor copies. They are streaked with blank (no print) columns. I replaced my toner cartridge thinking that it was the problem but even with the new toner I am still getting very light and poor copies.
  • 22 Answers
Hi, this is most likely caused by a worn or faulty drum.
Posted on Jan 23, 2009
Poor print quality - dots on side of copies
Using refilled cartridges? avoid refilled one, remove cartridge, used blower blow out toner fallen in side,take 25 pages of blank pages print outs, then go to menu>configure device>fuser modes select clean page wait to clean it self, do this process twice or thrice till fell print quality good.. if no result replace teflon sleeve(replacing the teflon sleeve only professional can do)
Feb 01, 2012 | HP LaserJet P4015N Printer
Printing Quality on HP 4550 Colorlaserjet
most likely the OPC (drum) or sometimes called "image drum or transfer belt located in the top draw. this is a consumable that needs replacing after it's life cycle is over. sometimes it will go below or over the life cycle, it all depends on many variables.
I would take out all the consumables, toner, belt and so on and use a dry cloth and small vacuum to clean the inside of the printer, then test it again, but when you have streaks it is usually the transfer belt. other possibilities is the scanner/laser window inside, sometimes it gets toner on the glass.
but step 1 is the Transfer Belt/Drum
hope this helps
Jan 14, 2008 | Office Equipment & Supplies
We have installed in our office a Canon MF8330Cdn printer. Every page that is printed now have a vertical line down the entire length of the page about 1" from the left hand edge of the page. Can you...
Her are somethings to try.
  1. Paper jam
  2. Bad toner cartridge or bad toner.
  3. Clean the corona wire (see the manual)
  4. Drum is wearing out and needs to be replaced.
Sometime a small piece of paper can get jammed in the toner cartridge roller and cause this type of problem.
Also, often this seen with after market toner cartridges or refilled cartridges. Poor quality or old toner will clump inside the cartridge roller wiper blade. Just like dirt under the wiper blade on an auto, it will leave streak on the toner roller that are transfered to the print drum.
Take a look at the toner cartridge first and inspect the long black roller. If the streaks are there then you need a new cartridge.
If no on the roller streaks try to clean the corona wires.
Also inspect the drum to see if has streak. Try wiping drum with soft tissue paper to see if it come off or is etched into drum.
Thanks for using FixYa!! I provide my answer for free as a public service - a 4 THUMBS rating and POSITIVE Comment is really appreciated for the FREE answering of your question.
LtCmdr Spock said: "An ancestor of mine maintained, that if you eliminate the impossible, whatever remains, however improbable, must be the truth."
Mar 10, 2011 | Canon Office Equipment & Supplies
Fax quality poor when recieving fax from samsung scx 4521F
Good Day Sir, Hope my suggested solution will resolve your problem.
Condition: The incoming fax has a blank spaces or is of poor-quality.
  • The fax machine sending you the fax may be faulty.
  • A noise phone line can cause line errors.
  • Check your machine by making a copy.
  • The toner cartridge, referring to "Replacing the Toner Cartridge".
Redistributing the Toner
  1. Open the Front door.
  2. Pull the toner cartridge out and remove it from the printer.
  3. Gently shake the toner cartridge from side to side five or six times to redistribute the toner.
Have a nice day and God bless.
Oct 09, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Smasung ML2510 Laser print quality poor especially on graphics
Full isn't always the answer, in order to refill a cartridge properly you need to also replace the cleaning blade inside. The blade wears out and doesn't clean the drum properly and also lets toner leak all over. Your best bet is a new OEM cartridge, or put a new cleaning and Dr. blade in yours.
Jul 29, 2009 | Samsung ML-2510 Laser Printer
Printed pages look terrible...
I'm more familiar with HP printers, but it sounds like a fuser is bad. The fuser effects print quality as well. If you've replaced the toner, as you have.
Apr 24, 2009 | Sharp FO 5550 Plain Paper Laser Fax
Blank vertical streaks
the toner cartridge is running low on toner and it needs to be replaced
Mar 26, 2009 | Canon imageCLASS D320 Digital Copier
Copy quality is poor. Replace toner, drum and transformer?
when you say the quality of the text is poor I am assuming that your are describing the line print
IF FUZZY remove corona wire and clean with q tip diped in alcohol
If IMAGE OFFSET check fuser rollers emove pad and ad fuser oil
IF copies lite remove print cartridge and shake back and forth to get toner distributed
also examine photoreceptor sounds the shutter is not closing and causing image distortment
Jan 05, 2009 | Sharp AL 1631 Copier
Poor quality fax to fax, copy great, computor fax great.
beware of generic toner!
you may need to change out your drum unit
the drum unit may have been contaminated by the staples toner.
also clean laser window under drum cartridge.
Mar 17, 2008 | Brother IntelliFAX 2800 Laser Fax
Sharp AL 1631 Copier Logo
126 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
