Question about Toys
How do i stop the helicopter from circleing on its own. Adjustments dont work.
    Filmmaker:
    Uploaded 5 video answers.
  • 25 Answers
My indoor heli also did this i found it wasn't the trim settings its was a window in the house creating a draft hence the unstable flight worth checking pal other than that take it to ur local model store
Posted on Jan 09, 2013
Helicopter will not fly, just goes in circles
try pressing right or left on the remote or try flicking the joystick forward slow
Feb 17, 2014 | RC Helicopter Select Sanhuan SH 6030 C7...
Helicopter not stable
Hi, I had a toilet bowl effect after changing the blades on my s107g. After making sure the shaft was seated properly, I simply adjusted the tension on the screws holding the blades in position and after a bit of trial and error tightening and loosening: it's as good as new!
Jan 21, 2013 | SYMA Toys industrial New Syma S107 Radio...
How could i use my iphone 4g to control my toy helicopter
Instructions
    • 1 Remove the main rotor blades, throttle up the helicopter while holding it in your hand and twist the helicopter from side to side to determine if the gyro is working. The gyro should make the tail rotor spin faster when the helicopter twists; you will be able to hear a difference. If the gyro does not appear to be working, replace it. Some gyros have a sensitivity adjustment screw; try making small adjustments if possible.
    • 2 Check the tail rotors and see if they are connected correctly. If the tail rotor blades are not pitched correctly they will not be able to hold the helicopter still.
    • 3 Test the tail rotor motor and see if it seems strong and responsive. Brushed motors, like those commonly used to drive tail rotors, can wear out in a relatively short time. Replacing the motor may solve your problem if the gyro seems to be working.
    • 4 Check the trim on your transmitter. Ideally the trim should be in the center of the stick movement. You may need to dial in some extra right trim or you may find the trim is set too far to the left.
Jan 20, 2013 | Toys
We just bought a 3.5 channel gyro 339 metal series mini helicopter and the lower rotor has stopped spinning properly. Instead the rotor moves slowly and the helicoptor now spins in circles.
Same Happened to me you have to push the lover rutter down until you hear a snap all that happened is the rutter came off the gears it might need a little force but it worked for me hope i helped
Jul 20, 2011 | Toys
I have a TY 901 medel rc helicopter. it flys, but then suddenly stops, as though it lost radio signal. the battery is fully charged, and the batteries in the remote are new, so i dont understand why it...
u must have change the a b c form thats y it do like that stay on one only. if u r flying helicopter u suddenly switch to b if u do like this then off the helicopter ^& then open it wl work!!
Mar 05, 2011 | Toys
I need an owners manual
why does my helicopter fly to the right.Are there adjustments? how do I make it go straight. I'm new to this. I'm just trying to find out all i can
Jan 05, 2011 | Jumbo RC JUMBO HELICOPTER
I crashed my Apache onto a table and when I try to fly it, It keeps spinning out of control. To my knowledge I don't see anything broken. It spins to the right. Please help! thanks!!!
It sounds like your tail rotor is acting up or missing. It keeps your Helicopter from flying in circles.
http://www.start-flying.com/new%20site/heli1.htm
Oct 04, 2010 | Apache RC Mini Helicopter AH-64
Helicopter keeps spinning in circles and won't lift.
There is a "trim button" on the controller. Ex: if the helicopter is spinning left, press the "R" trim button repeatedly. Takes a little practice to get it down to flying with out hitting anything. Good luck.
May 17, 2009 | Spinmaster Air Hogs RC Reflex Micro...
Heli max hicro helicopter just keeps spinning in circles
Spinning is caused by one of the main propellers rotating faster than the other. If both propellers are secured tightly to their drive shafts, the spin control knob on the remote control can be used to stop the spin. However, if one prop is slipping with respect to the other, the spin control knob will not fix the problem.
I've found that the set screws holding the propellers to the drive shafts tend to loosen after a while. If one prop is a bit loose and the other is tight, the relative slippage will cause the helicopter to spin.
To check, turn off helicopter power and manually rotate each propeller separately, watching the nylon gears in the body. If the propeller is moving and its drive shaft gear isn't, the propeller is slipping because its set screws are not applying enough pressure on the propeller's drive shaft.
Carefully tighten the set screw and the problem should be fixed. DON'T OVERTIGHTEN, or the plastic threads for the set screw will be stripped and the propeller assembly will be ruined.
Apr 10, 2009 | Max Heli- Axe CX Micro Electric Rc Mini...
Toys Logo
60 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
