Question about Leviton 003-1755-W Three Rocker Switches
The old fixture has 3 screws on each side. The new leviton has 3 screws on one side and only one on the oher side. How do I hook this up?
5 Suggested Answers
SRF518
  • 232 Answers
SOURCE: Old switch only has three screws, with a white
I don't understand your problem. Green wire is ground goes to the yoke. it should not have any current on it If it does sumbody messed up real bad!
a combo outlet/switch has three brass screws and one nickel screw. yoke should have a green hexagonal screw.
Posted on Oct 25, 2009
SOURCE: Leviton Dimmer Switch wiring and
I recently purchased a Leviton Dimmer switch which has a brown lead. This switch is to replace 1 of 2, 3 way switches that control the ceiling light in my kitchen. My problem is the new dimmer switch has 4 leads including a brown one which has me confused. I have installed and replaced numerous dimmer switches without difficulty. Please help.
Posted on May 20, 2010
  • 1949 Answers
SOURCE: We are replacing an old
black to brass colored screws /white to silver screws /green is ground
Posted on Dec 20, 2010
Leviton T5625 has shutter (tamper resistant) mechanism that blocks access to the contacts unless a two-prong plug is inserted. My understanding is this mechanism prevents child from sticking piece of metal into receptacle and getting shocked. Tamper resistant receptacles are code for new home construction, and receptacle is marked with TR. The light switch part of device works at all times, with or without two-prong plug in receptacle.
http://www.leviton.com/OA_HTML/ibeCCtpItmDspRte.jsp?item=388754§ion=24614&minisite=10026
Electricians test, they don't guess.
Let's test your wires using ordinary two-prong tester.
Tape wood sticks to tester leads to keep hands away from power. Stand on dry surface or wood boards. Do not shake or sweat.
Separate wires for testing
Turn power ON.
Test each wire to bare ground wire.
Tester lights up on Hot wire. Hot wire connects to either dark-colored screw, as long as there is a brass connector plate that connects both dark colored screws. If connector plate is missing, add a jumper wire between both dark screws so they are connected together.
Hot wire is identified.
Now test Hot wire to each other wire, except bare ground wire.
Tester lights up on neutral wire. Neutral wire connects to silver screw.
If neutral wire is white wire, AND both white wires were connected together before, then they both connect to silver screw.
The last wire is the Load wire that goes to fan, light, motor. Load wire connects to brass colored screw.
Double check instructions with instructions on new device.
Add a comment any time.
You can also take advantage of fixya phone service.
For a price, fixya expert speaks to you over the phone while you test and wire the device.
Posted on Dec 29, 2010
How do I replace the Leviton Bi-Pin on a Linear Fluoresent Lampholder?
Take the end cap off the fixture case - unwire the old socket and reverse the process for installing a new socket.
The little slots on either side of the socket slide onto the fixture case.
Nov 12, 2014 | Leviton 23351 T8 Or T12 Turn-type...
I remodeled my kitchen and replaced my leviton dimmer switch with another brand. After installation I turned the light fixture on. Only one of the three lights of the single fixture turned on for...
Hi Leonard,
I'm a licensed electrician and will be happy to help you get this working again. I suspect an incorrectly wired or incompatible switch or a load that is not designed for dimming. To know which one(s) is the problem and to be able to provide a solution, I need a little more information.
1) What was the old switch brand and model number?
2) What is the new Leviton switch's model number?
3) What type of light bulbs are you trying to operate in the 3 fixtures?
4) What is the number of and wattage of each lamp in the fixtures?
5) How many switches operate the lights?
5a) If more than one switch is used, what is the brand and model number of the other switch(es)?
Thanks
Oct 05, 2012 | Electrical Supplies
How do I hook up a Leviton Decora no 5601... I have a white, a red, and a black wire
Wiring is unclear without more information.
Question posted under 4-way switch.
Wiring sounds like 3-way switch is possible.
And Leviton 5601 is single pole switch.
Add a comment and say what load the switch controls. Load means light, fan, motor, etc.
Say if another switch controls same load.
And include what type of device you are replacing.
Include what screws and screw colors are on old device.
When you add a comment, it sends email, and I will respond to comment.
Sep 01, 2011 | Leviton 112-05604-2WS 15A 4-Way Decora...
Where on line is there a wiring diagram for the Leviton GLW-1463? I could'nt seem to find it on there web-site. Thank you. :)
Leviton GLW-1463 appears to be ordinary lighted 3-way toggle switch.
This switch is used in a hallway application where more than 1 switch controls a light.
The green screw is for bare ground wire.
There are two brass colored screws for traveler wires, and 1 dark screw for common wire.
If you are replacing another 3-way switch, then note color of each screw on old switch.
Put wire from old dark screw to new dark screw.
The travelers wires can go onto either brass screw.
Open following link for drawing of ordinary 3-way and 4-way circuits
http://waterheatertimer.org/ST01C-program.html#3-way
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 03, 2011 | Leviton 3W Lighted Toggle Switch -...
I just installed a Leviton IP106 Illumatech dimmer switch. It was replacing my existing rotary dimmer switch. The switch is a 3-way wiring job, with another 3-way toggle switch (no dimmer) on the other...
The Leviton IP106 Illumatech dimmer switch must be installed at the switch location where the hot feed exists. From your description your hot feed is at the regular 3-way switch location. Swap locations.
Dec 22, 2010 | Leviton Decora Light Dimmer Switch
I have a Leviton 5634 two rocker switch that I'm using to replace an old double switch that controls two lights. There are 1 black, 1 red, and 1 white wire in the light switch box. The white wire is...
Review old switches:
Two old switches > each has 2 wires
Old switch 1 > Red and White
Old switch 2 > Black and White
The same white wire connects to both switches, so effectively they count as 1 wire
This means you have 3 wires ... 1 White, 1 Red, 1 Black
Each switch controls a separate load (light, fan, motor)
New Leviton double-rocker switch:
-Leviton has 2 Brass-colored screws on one side, and these screws are connected together by a brass plate >> your Hot wire will connect to brass screw
-Leviton has 2 Silver-colored screws on other side, and neither of these screws are connected in any way >> the wires going to each load will connect on a different screw on this side of switch.
Hot wire: Each box in your house has exactly 1 hot wire that is connected back to breaker box. This is true for all boxes (excluding boxes that have a 3-way & 4-way switches).
We need to identify Hot wire.
-By code the Hot wire is black for identification purposes ... but your box sounds like maybe the Hot wire is White.
-If your Hot wire is white, that is NOT an immediate safety issue ... it will not cause a fire or malfunction ... it is a code violation ... because code requires things be uniform so next electrician knows what previous guy did. So some day, electrician working outside grabs wrong color wire, and wow. I say this so you know.
Moving on.
Identify Hot wire:
-Pull 3 wires up so they can be tested
-Turn on power
-Use ordinary tester, or old lamp with plug cut off and wires stripped back
-Tape tester lead to sticks so hands are away from voltage
-Power is on. Don't stand in water or touch metal pipes, and you're fine.
-You have 3 wires in box + ground wire
-Test all 3 wires to bare ground wire >> when tester lights up, that is Hot wire ... testing is complete
Connect wires to Leviton double-rocker:
-Power is OFF.
-You have 3 wires - 1 White, 1 Black, 1 Red >> one is Hot wire, the other two wires go to load
-Hot wire connects to Brass-colored screws on new Leviton.
-Brass colored screws are connected together by a brass plate so the Hot does not need to connect to both brass screws.
-The other two wires connect to Silver screws on other side of new Leviton switch
-One wire goes to each silver screw
-Connect bare ground wire to green screw.
-Push wires back into box. Use eraser end of pencil if needed.
-Make sure ground wire is back and away from screws on switch
-That's it.
Sep 30, 2010 | Leviton Electrical Supplies
We are trying to change a 3 way switch. It is the original wiring/switch from the 1950's. We bought a new switch to replace the old one with. The new switch has two gold screws one on each side and one...
Remove the black wire (it is called the switch leg in this case) that is connected to the bottom screw on the old switch and connect it to to the _black_ screw on the new switch. Then remove the red and white wires from the old switch and connect them one to each gold screw on the new switch. The red and white wires are the "travelers" and it doesn't matter which wire goes to what screw as long as you are connecting both to the _gold_ screws. The "odd screw out" is always the switch leg or hot.
If the switch box is metal you'll need to attach a (green or bare) wire from the green screw on the new switch to the box with a green screw. There are grounding clips available if the holes in the box are not threaded. Or use a 10-32 tap to thread the hole.
Please remember to turn off the circuit and be _sure_ it is OFF. Turn off the main breaker and work with a flashlight if you can't determine which circuit breaker to turn off.
Be safe, and Happy Thanksgiving!
Nov 22, 2009 | Leviton (102-5G108-RW5)
Leviton Dimmer Switch wiring and ceiling wiring for new kitchen table light fixture
Oct 10, 2009 | Leviton Decora Light Dimmer Switch
How to wire so switch controls outlet? We hooked it up. The switch controls the light fixture but no power is going to the outlet.
You should run a short "jumper" wire from the same screw that the light fixture's wire is on to the brass screw at the outlet. If you put the jumper on the OTHER side of the switch, the outlet will be always on.
Sep 26, 2009 | Leviton 5225ISP Switch and Outlet
I have a black and white wire to hook to. leviton has black, blue and white. green also but thats a ground. what do i do with the blue wire? this is a single switch to a gfci then to outside lighting....
The blue wire is the switched hot wire coming from the leviton.
So:
black hot/source to black leviton -- blue leviton to black for light fixture or black "line" on GFI -- all whites connected together.
Charlie
P.S. If the GFI is only powering a light fixture, it is not needed.
Sep 23, 2009 | Leviton 6124H-A 6124H-A Decora LCD Timer...
Leviton 003-1755-W Three Rocker Switches Logo
65 people viewed this question
Top Leviton Electrical Supplies Experts
 Kenneth
Kenneth
Steve
Hippy_dd
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
