Question about Pelonis HC-461 Ceramic Heater
Pelonis HC-461 Ceramic Heater works, but then stops putting out
Everything seems to be fine with the heater: it runs fine for a few seconds, but then it stops. The safety interlock seems to be malfunctioning. Since the heater is trash anyway, I just want to know how to identify the anti-tilt switch and the overheat switch. If it is one of those, I could defeat each and see if that solves the problem.
  • Anonymous Feb 10, 2009
    The heater runs for a period of time then quits like it is over heated. After a short peroid of time it can be restarted, but then it runs for a period of time and shuts off again.
  • Anonymous Apr 05, 2009
    This is exactly what's "wrong" with my Pelonis V, (hc-461) disc furnace. It turns on fine, the fan comes up to speed, green light on, heat great, then, the fan begins to slow, a small click is heard, the red light comes on, the heat is shut off, and the fan runs at slow, blowing only cold air.
    Anyone know a fix... other than sending it to Pelonis, which I read, is a nightmare?
SOURCE: caution light comes on,rarely used heater. any thoughts?
Try calling 1-866-876-4332 ext 224 for tech help, it worked for me.  I only needed a temp
setting/off switch to fix mine.
Posted on Oct 23, 2008
SOURCE: PF-1212-B4A--REPLACEMENT ON/OFF PLASTIC KNOB ON FRONT
Went directly to the supplier
Posted on Dec 05, 2008
MNfisherman
  • 11896 Answers
SOURCE: looking for manual FOR PELONIS HEATER MODEL#
You can find your manual here:
http://www.pelonis.com/oilfill.htm
And for electric type you can get it here:
http://homeappliance.manualsonline.com/manuals/mfg/pelonis/hb211.html
Posted on May 15, 2009
shastalaker7
  • 1515 Answers
SOURCE: Pelonis heater does not heat
Hi, Have you checked to make sure that there is power at the outlet you are plugged into? I have looked up some information on this heater and it is in the top 5 oil filled heaters. I do know this, they are maintainence free. They are sealed and no place to fill will oil as the oil is heated to a certain temperature and not enough to burn the oil, so they never have to be filled. Anyway, check for power, and if you have power, check the cord over for any damage. If you can't find anything, you have a internal problem with the control on this heater. This is something you may want to take in to a appliance repair store and have checked out. There is no fuse to replace, so I would say a problem in the circuitry. There is not much for me to walk you through other then what I have mentioned, that it is getting power and cord is good. Please keep me posted.
Sincerely,
Shastalaker7
Posted on Feb 02, 2010
Testimonial: "They got back to me fairly quickly and although the problem was not solved. He did answer my questions. I believe it is a problem for a service repair"
  • 1015 Answers
SOURCE: Can you get replacement discs for pelonis ceramic
I have spent the last 1 1/2 hours going thru several of my catalouges and called a couple of my old suppliers and I can find no source repacement disc. Sorry I could not help you this time.Thank you.
Posted on Jan 24, 2011
Pelonis HC-0114T Ceramic Heater parts
I worked in maintenance for several years, and often found hard to find parts at Grainger.com. Sometimes they can be pricey. Here's a link to there fan section. Fan Blades and Propellers
Feb 08, 2014 | Pelonis Heating & Cooling
Can you get replacement discs for pelonis ceramic heaters? One of mine is cracked.
Jan 24, 2011 | Pelonis Disc Furnace Heater
I love this heater but now after a few seconds of running it shuts itself down. Im wondering if there is too much dust or something that is causing it to overload the heat sensor? Its level on the...
I would definitly try to give your heater a through cleaning before before giving up on it. Remove screws that hold back cover on and remove cover. There shoulb be a fiter directly behind it,remove it and give it a through cleaning. I don't know on the new ones if the filter is made of foam material,the older ones like mine are.It is safe to wash them in warm water and a little dish soap. Rinse fully and pat dry. Clean any lint,hair,dust or any other foreign material from fan motor. Blow it out with compressed air if you can. You can use a tooth brush to clean around motor shaft and air ports on motor. You can use a couple of drops of fine grade machine oil on motor shaft,such as 3 in 1 oil or WD-40. Wipe off excess. Lightly brush heating elements and reassemble. I hope this works for you. Thanks We had our first pelonis disc heater for twenty years.
Nov 18, 2010 | Pelonis HC-461 Ceramic Heater
Is the ceramic heater high on your light bill?
yes they are very high  and they are power consuming units.its true.
Mar 02, 2009 | Pelonis NTK15A Safe-T-Furnace Ceramic...
Pelonis LT101A/ B2-IVA
Pelonis heaters generally have safety devices built in to them for if they fall over and such. This model may have other safety devices, I would check it out in the manual. If its completely dead in the camper, there could be a problem with the outlet in the camper.
Sep 22, 2008 | Pelonis Disc Furnace Heater
Utility heater hb - 301 0109
Sounds like the thermostat has worn out. Try replacing it.
Mar 08, 2008 | Pelonis Utility Heater HB 301
Hf-0022
tap the heater gently. i say GENTLY, in the area of the on switch. try this several times. usually the tip over mechanism will stick. i say gently.
Nov 21, 2007 | Pelonis HB156T Ceramic Compact Heater
Pelonis HC-461 Ceramic Heater Logo
82 people viewed this question
Top Pelonis Heating & Cooling Experts
Paul Carew
Mack Baxter
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Pelonis Heating and Cooling Expert? Answer questions, earn points and help others
