Question about Coleman Heating & Cooling
Wiring diagram for coleman evocon
Have coleman evocon 3500a818 electric furnace and am trying to wire heat sequencer The replacement part ordered for unit is 3115-3571r. I need wiring diagram
5 Suggested Answers
Gigatech
  • 259 Answers
SOURCE: REPLACED 10KW FAN/HEAT SEQUENCER AND LOST TRACK OF WIRING
Could not find the E1Eh-020HA but found the E2 series
http://www.nordyne.com/Literature/707716c.pdf
http://www.nordyne.com/Literature/901a.pdf
Hope this helps. :]
Posted on Dec 13, 2007
SOURCE: Wiring diagram needed RV rooftop coleman
Motor1258,
Thanks for the response, to be more specific, the nine pin connector was damaged, but I was able to connect the wires back to main unit panel. I am ready to hook to the hunter thermostat and do not know which wires to connect to. This is my problem and I do not want to short something out. Hope this helps, I want to get it installed again. Thanks again for caring....Jerry
Posted on Aug 16, 2008
  • 96 Answers
SOURCE: need help hooking the right colored prong wires onto my sequencer
There should be a wire diagram on the back side of the panel you took off to get to the sequencer
Posted on Nov 13, 2008
SOURCE: Wiring Diagram for Ruud Heat Pump
Unfortunately, the wiring diagrams for heat pumps are not so easy to come up with. The outdoor unit will have its own diagram, but may not include the indoor air handler and will probably not include the thermostat. That said, the orange wire is commonly run from the thermostat to the reversing valve in the outdoor unit. This wire is usually not connected to the indoor airhandler. The orange wire is usually used in a unit that has the reversing valve energized in cool. Ruud, however has its reversing valve energized in heat. Probably not useful but maybe helpful
Mike
Posted on Mar 26, 2009
How do I wire a Coleman Evcon 3500A916 furnace Model
Wiring Diagram for a Coleman Furnace - RV-Coach Online
www.rv-coach.com > Discussion Forum > RV - Insurance
... Furnace, Mark, 9-12-07. Need wiring diagram for coleman furnace Model # 7700B856 .... Amanda, 11-10-11. I need a wiring diagram for a Coleman evconpresidential model 7956c856 ... Need wireing diagram for coleman 3500a916 ... More results from www.rv-coach.com
FURNACE Diagram & Parts List for Model eb15b Coleman ...
Dec 22, 2015 | Coleman Heating & Cooling
Hook ignition wire
This is a typical 5 wire setup. The colors can change depending on the person installing the system, meaning if the installer liked using BLUE for cooling instead of YELLOW, that's how he hooked them up. If YELLOW wasn't available, they could of used BLUE or BLACK, and visa-versa. But, the wiring below is the most common. If you have a heat pump system, it will be slightly different. Hope this helps!
R- Red- Power 24v
G- Green- Fan
W- White- Heat
Y- Yellow- Cooling
C- Blue- Common
Dec 07, 2013 | Coleman Heating & Cooling
I have a coleman evcon electric furnace. The blower fan runs constantly, the switch is in auto and the fans runs even when the thermostat is shut off.
Most likely on that particular electric furnace you have a fan sequencer that is closed (stuck shut). It is the black relay that you are looking at when you take off the furnace cover to access your heat strips. You should have a red wire coming from the blower motor that plugs into the side of it. If you have a ohm meter turn power off and remove wire. Check resistance across the sequencer and it should read OL. If you have resistance across it, the relay is bad. Replace it.
Nov 28, 2013 | Heating & Cooling
Have Coleman electric furnace and strips stay on no matter what you do changed sequencer and limits nothing left to change any ideas
Have you tried a new t-stat? They go bad. Also try jumping wires at t-stat, then disconnect & jump at furnace - to see if there's a short in the wire
Nov 05, 2013 | Heating & Cooling
I have a 1987 mobile home with a coleman electric furnace model 3400-812. I need a wiring diagram for the repairman to use to rewiring all the new parts. He has installed a new fan blower motor, new...
5cd0d9d4-9d59-458b-ae93-d14f7aa016ab.jpg728c66bc-7660-4666-bc17-bdfa1b3130ed.jpgded744e2-3c31-4bc2-aec3-aa2d40664be6.png
I mean this respectfully, if the technician cannot wire a unit without a wiring diagram , he is not competent to do the work.
It is really very simple, If you look at the power lines entering a building, ther are but 2 hot legs of 115 volts for 230 volts and a earth / ground, every wire we will ever see are these 2 hot legs or a combination of them.
Every circuit requires 2 sides/legs of power, a device and a switch, begin at L1 go through switch to load return to opposite side of power from where you began, very simple.
If you do not know this a wiring diagram will tell him nothing but how to blindly try to follow some diagram he has no grasp of the theory behind or he would see how simple his dilamna is.
Oct 19, 2013 | Coleman Heating & Cooling
Need wiring schematic for coleman 3500A818
Contact Coleman Heating & Air Conditioning Consumer Relations at: 877- 874-7378 Monday - Friday between 8am - 5pm Central Time.
Mar 08, 2011 | Coleman Heating & Cooling
Need wiring diagram ,colman central electric furnace 3500a816
I have the diagram pasted to the cover over the sequencer. I only have a 5 megapixel camera, but I am willing to try and get a picture of it if it will help.
Nov 03, 2010 | Coleman Heating & Cooling
Need help hooking the right colored prong wires onto my sequencer
Nov 13, 2008 | Heating & Cooling
Heating & Cooling Logo
48 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
