Question about Hitachi 53FDX01B 53" Rear Projection Television
Poor picture quality on Hitachi model # 53fdx01b
All of the sudden my picutre quality started having a blue shadow, it is blurry and dull-not as sharp as it used to be. What could be the problem?
  • Hitachi Master
  • 3,459 Answers
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions yopoor picture quality on Hitachi model # 53fdx01b - 2c07611.pngnce chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Posted on Mar 15, 2009
I have hitachi 53fdx01, it looks to me that the red color has gone. Is there a color card that I can replace.
Posted on Jan 20, 2009
Sinotec
check the antenna u may be getting poor reception,if the video is ok on dvd then the antenna is , if not the tv is faulty on its video output need a tech to check it
Jul 10, 2013 | Televison & Video
Hitachi 53FDX01B 53 in has green line in the middle and in the corner
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony2_bing.gif, Samsung,JVC2_bing.gif,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif, Hitachi,Mitsubishi,Zenith2_bing.gif and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull bb0cf99.png
Apr 20, 2010 | Hitachi 53FDX01B 53" Rear Projection...
Dark picture
Hmm my dad's old t.v. just cut out on him it took awile to turn on this my be the end of ur tv so this might be a power problem but older t.v. loose there colour on the screen my uncle had a like 10-15 year old t.v the screen was like green when it was light but when u turned of the light or closed the blind's it's picture was ok so try that.
Feb 02, 2010 | Hitachi 53FDX01B 53" Rear Projection...
Looks like I have 3 different colors of the picture....red shadow and I think the other shifted color was blue...
Replace Both of your STK ICs STK 392-110s use 150s or 180s they are Big Black ICs will have part number on them. Call Mats Electronics for parts 1-800-628-1118 also replace these resistors RK42,RK46, RK50, RK54,RK58, RK60.
Dec 29, 2009 | Hitachi 53FDX01B 53" Rear Projection...
Dull / dark screen and picture quality not sharp
The cooling fluid in the blue and perhaps the green picture tube assembly has become contaminated. Only solution is to remove the assembly and dump old fluid and clean and reinstall new fluid.
Apr 30, 2009 | Televison & Video
Hitachi HD 53" digital projection tv
Good Day; brannie1;
For dark picture check RP41 heater circuit, 1.5 ohm, may have changed value & clean spark gaps. Good Luck, big IRISH.
Sep 04, 2008 | Hitachi 53FDX01B 53" Rear Projection...
Hitachi Projection tv
Projection TV sets have two very common problems listed below.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
*Screen Looks 3-D
*Colors wont align
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 17, 2008 | Hitachi 43F300 43" Rear Projection...
Blurred picture
Hitachi > 53FDX20B blurry picture
I would start 1st by checking all resistors ie.
RK43 2.2 ohm - 2W
RK47 1.5 ohm - 2W
RK51 2.2 ohm - 2W
RK55 1.5 ohm - 2W
RK59 2.2 ohm - 2W
RK63 1.5 ohm - 2W
If I were you I would also replace the convergence chips. From the above thread it's clear that they are of different quality so they may last different lengths of time (B&D is a good place to buy good quality ones).
I found a free pdf service manual for 53FDX20B on a Polish web site: http://instrukcje.elektroda.net/main1750.html
other models try here: http://www.webtronix.ca/hitachi/index.htm
http://www.asm-service-manual.com/List/Hitachi%20List%20ASM.htm
Download pictures from my repair (Password: delirious).
http://www.uploading.com/files/HGGLJLXC/Delirious.zip.html
Jan 16, 2008 | Hitachi 53FDX20B 53" Rear Projection...
Dark picture
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Nov 13, 2007 | Hitachi 53FDX01B 53" Rear Projection...
Hitachi 53FDX01B 53" Rear Projection Television Logo
322 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
