Question about Acer Aspire 5742-7653 : 2.53GHz Core i5 15.6in display LX.R4F02.036
Unable to detect hard drive during windows installations
Bios can see the hard drive but during windows installatioin, it cannot detect hard drive. It request for some missing DVD drivers
  • Acer Master
  • 7,627 Answers
Remove HDD, test, replace if necessary.
Posted on Jan 09, 2013
SOURCE: Cannot install Windows XP Professional on Acer Aspire 4720Z Laptop
yu need to go to the the bios before you start the installation and change the Sata hard disk mode to IDE.then it will detect the hard disk.
Posted on May 14, 2008
  • 50 Answers
SOURCE: Unable to recognize usb to install drivers after format
maybe you didn't install windows xp professional properly
Posted on Dec 23, 2008
  • 3 Answers
You have to integrate the SATA AHCI driver to your windows XP CD. By doing this you will be able to install the OS. The process of integration is given in the link below:
http://techrena.blogspot.com/2008/10/how-to-install-your-own-wndows-xp-in-hp.html
They have given a detailed description in the site.Hope this will work.
Posted on Feb 11, 2009
SOURCE: ACER ASPIRE 5100 DVD/CD ROM IS NOT DETECTED IN BIOS?
My Aspire 5100 not only looses the cdrom but also the hard drive! It sometimes beeps 3 times.. I'd go into set-up (BIOS) and niether the hard drive or dvd would be listed.. As a last resort, I flashed the motherboard bios with the latest version from Acer and so far the problem hasn't returned. I also set the laptop to hibernate after 30 minutes of non use when both on battery or on ac power. Reason? My problem always started when I left my laptop unattended for some time. When I'd return, the computer would be off.. not asleep or hibernating, but off - even though it was set to never turn off in the power settings in windows. When I'd turn it back on, that is when the hard drive and dvd rom would vanish in the BIOS. So as an added precaution, I set the laptop to always hibernate after 30 minutes.. Like I say, so far so good..
Posted on Mar 25, 2009
  • 4961 Answers
SOURCE: How to Reset or Remove Acer Aspire 4752Z BIOS password?
BIOS passwords can be reset or removed in two ways:
1. using software 2. using hardware.
I would first try resetting or removing using software, here are two software apps to reset or retrieve BIOS passwords.
!BIOS - is a PC BIOS toolkit offering password removal/decrypt and BIOS settings modification/backup/restore.
You can download it here:
http://www.syschat.com/download120.html&act=down
CmosPwd - Cmos password recovery tools
http://majorgeeks.com/CmosPwd_d239.html
You will need to create a bootable Dos, or Linux or NT cd in order to run them.
Good Luck!
Posted on Sep 07, 2012
Hard disk drive not detected during installing windows server 2003
It depends on what type of drive you are using. Plus, you may have to specify the array controller drivers if your are using the SAS (Serial Attached SCSI) drives.
May 22, 2013 | Dell POWEREDGE R610 (4640223) Server
Toshiba l450 h.d.d unable to detect from bios
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Mar 23, 2012 | Toshiba Computers & Internet
I cont intstal win xp in my toshiba U200-148 laptop
you can use another installer coz maybe your installer have some scratches
May 22, 2011 | Computers & Internet
Hey i have a HP laptop which is probly a few years old now and i went to turn my laptop on today and the screen would turn itself off just after the windows loading bar finishes loading. i can operate the...
If the Windows installation CD cannot detect the hard drive to install Windows then the hard disk could be faulty or it may only need reseating.
First - remove the hard drive and connect it back into the laptop.
2nd - Boot up the laptop and go into the BIOS configuration and check if the BIOS detects the hard drive.
If the hard drive is detected then proceed with the Windows installation.
If the hard drive is not detected in the BIOS then most likely the hard drive is faulty.
In this case you need to replace the hard drive before you can install Windows.
I have a k8u-x motherboard.. my problem is i cant install winxp in it because it doesnt detect any hardisk during the setup. All my floppy drives are damage as well as my floppies. Is there any way to...
Your trying to install windows 3.1 or 98 ? I have never seen Windows XP or newer on floppy disk is why I ask. That will not resolve your problem though. If you are sure you have the hard drive installed and connected with at least one of them set to Master, if you are installing 2, You may need to enter Bios and have it auto detect the Hard Drives in the Bios. If the Bios doesn't recognize the Hard drive or you have 2 hard drives and one isn't set to Master it won't matter what media you use you won't be able to install anything on the hard drive.
Sep 08, 2010 | ASUS K8U-X Motherboard
Error "Setup didn't find HDD"
Well, first of all XP is not the latest supported operating system from Microsoft.
That being said, I have not had a garbled screen followed by an error message 'setup didn't find any hard disk drive installed' on a laptop, in my limited experience with laptops (i.e. Acer One, Acer Aspire, Sony Vaio, etc.)
If you have an unexpected garbled screen it points to the pc board or mother board or the video card, but more likely the motherboard.
And, if you couple this with the hard disk drive not being detected, it reminds me of a situation where I had a no hard disk drive detected on a SCSI drive connected to my Windows 95 computer in the 1990s when I had heat related issues with the circuitry on the hard drive getting burnt out capacitors.
If the drive is not recognized, it might mean the boot sector is wiped, and essentially it needs to be reformatted and the operating system needs to be reinstalled (which you evidently tried to do).
To my memory, I never had this problem on Windows XP with a laptop, so I am thinking it's not Windows that is at fault, but the physical hardware is giving you problems.
If you boot from the CD for Windows XP and it doesn't find the drive, it's a big problem for this laptop.
I wish you luck in finding an answer to that one, seeing that it's out of warranty and XP is no longer supported by Microsoft.com.
Jul 19, 2010 | Fujitsu Siemens AMILO Pro V2000 Notebook
How do i format the seagate 5400 160 gig hard drive?
Configuring the BIOS
After completing the drive installation, restart your computer. Your computer
may automatically detect your new drive. If your computer does not
automatically detect your new drive, follow the steps below.
1. Restart your computer. While the computer restarts, run the system
setup program (sometimes called BIOS or CMOS setup). This is usually
done by pressing a special key, such as DELETE, ESC, or F1 during
the startup process.
2. Within the system setup program, instruct the system to auto detect
your new drive.
3. Save the settings and exit the setup program.
When your computer restarts, it should recognize your new drive.
There ya go ya tubby *****.Give me a shout this weekend, Mike
Mar 29, 2009 | Seagate Momentus 5400.3 Hard Drive
Sata drive not detected
just no other solution except upgrading BIOS properly
Sep 24, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Hard disk drive not deteted during windows installation
This problem arises due to a missing driver in windows installation. download your specific driver and copy it to a floppy drive. Then start the windows setup. As the setup loads it will ask "Press F6 to load a SATA RAID driver".Press F6 and insert the floppy into Floppy disk drive.
And continue the setup...
Jul 16, 2008 | Computers & Internet
firstly check your cable connections, then log onto your bios setup menu during startup and check whether the Hard drive is detected by your bios, if it is then you can try to format the harddrive using the ntfs system (use the long formatt) if you are using windows xp or later if using any earlier os then formatt with the FAT32 system.
If your HDD is not detected by the bios then try to download bios updates for your motherboard and install thed in windows. is this does not work then its time to get a new HDD. thanks
May 27, 2008 | Hitachi hts548080m9at00 80 GB Hard Drive
Acer Aspire 5742-7653 : 2.53GHz Core i5 15.6in display LX.R4F02.036 Logo
23 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
