Question about Kitchen Appliances - Others
I have a pitco deep fryer... Everything works fine, but when the burners go off, I get a popping sound that blows out my pilot light
    Scholar:
  • 81 Answers
It sounds like the burners and tubes may be dirty and clogged in your fryer. The burners are removable and need to be cleaned periodically. The tubes can be cleaned when the burners are out using a burner cleaning brush. If the above mentioned items appear to be clean, you may have a gas pressure issue.
Posted on Feb 19, 2013
r carbo
  • 21 Answers
SOURCE: Pitco Fryer
Sounds like the burners are dirty remove burners and run under cold water and replace propane gas burns dirty and might have blocked up burners creating a pop at the burners this will then blow out pilot light if this does not work give me a shout
Posted on Nov 21, 2008
  • 125 Answers
SOURCE: Imperial deep fryer IFS40 pilot lights, turn on
Hi there, it sounds like your thermopile, for the pilot, is failing during use, when this happens, the small DC voltage it generates is less than the gas valve requires to stay open, and shuts off the pilot, which shuts off the main burners. Another thing that could be happening, is the hi limit is opening prematurely, instead of shutting of the pilot at 450 deg. it now is opening at 325, or 225 or 250. Sometimes the sensing bulb gets broken where it pass's through the oil tank causing this symptom. If you temporarily bypassed the hi limit to test this also, and it still goes off, you need a thermopile. If it stays on, check your temp with a reliable thermometer, and see if it reads fairly close to your setting, if so, then you need a hi limit.
Hope that helps, and thank you.
Posted on Feb 21, 2009
  • 30 Answers
SOURCE: burner doesn't ignite
did you check to see if the knob on the gas valve is set to on?
Posted on Mar 31, 2009
SOURCE: comercial deep fryer pilot light goes out
This problem could be caused by a few different things. You should check the condition of your pilot and the thermocouple, if the pilot is weak due to being dirty you will not generate the optimum Millivolts to run the fryer, you may need to dissassemble and clean the pilot. The thermocouple needs to be correctly placed in the pilot assembly, if it has dropped down to where it is not in the flame it will not work correctly. You may need a new thermopile as it may not be generating millivolts as needed. Gas pressure can cause this as well, if the pilot goes out then the main burners come on you should check the gas pressure. One more thing to check is the hi-limit thermostat, if this is cutting out early your pilot will go out. Imperial uses a self-resetting limit, after a few minutes your fryer will relight and work until if cuts out again. If your fryer pilot stay on with the thermostat off for long periods of time and does not go out immediately when the burners come on and the pilot is clean, you may need a hi limit. This is a lot of info, I hope it helps.
Posted on May 26, 2009
97F350diesel
  • 1326 Answers
SOURCE: I have a Pitco 35C+S
With the thermostat on the burners are still getting gas. that's normal. If it lights with the thermostat off you do have a severe problem. (bad gas valve/Tstat). The pilot does occasionaly go out on all no electronic ignition items is normal. Follow the remommended steps for relighting and if it lights fine your ok.
Posted on Aug 15, 2009
HELP PITCO FLAMES OUT BLOWS OUT PILOT LIGHT CAN WORK FOR 3 OR 4 TIMES SHUTS DOWN NICELY THEN WOOF SMALL BLOW BACK CAUSEING PILOT TO BLOW OUT THEN HAVE TO WAIT 10MINS TO RELIGHT
This is caused by a pressure problem. There should be an adjustment screw on the gas valve regulator. Also, make sure the pilot orifice has been removed and cleaned. There is also an adjustment screw on the gas valve for the flow of gas to the pilot.
Jan 05, 2015 | Pitco Frialator 35CD Deep Fryer
Burner problem
Hi there!
Check the incoming gas pressure.
Insufficient gas pressure will greatly affect the unit's efficiency.
Regards.
Apr 03, 2012 | Pitco Frialator 35CS Deep Fryer
Pitco deep fryer flames coming out the fryer
Hi there.
The soot or carbon have probably build up inside the fire tubes, better check and have an authorized service technician clean them.
Make sure that the fryer is receiving the rated gas pressure and correct gas type as stated on the nameplate, this way, carbon or soot formation on fire tubes can be prevented
Regards.
Sep 12, 2011 | Pitco Frialator SG14 Deep Fryer
I light the pilot everything is fine then when i go to turn thermostat on pilot light goes small and burners dont light and when i turn back to pilot the gas ignites and goes out
Sometimes certain models turn off if you touch the thermostat before it lites...
We've seen this happen many times, so you would need to light the fryer first, wait until it's stable before turning your thermostat to desired temperature.
Sep 02, 2011 | Pitco Frialator 35CS Deep Fryer
My pilot light is out on pitco 35cs fryer, i cant locate it to relight it
Pilot assembly is located between the two middle burners, this is where the pilot is lighted. You have to turn the gas valve knob to pilot position then push it while lighting the pilot assembly.
Jan 27, 2011 | Pitco Frialator 35CS Deep Fryer
Pitco Frialator SF14 pilot will light and the burners will light but within an hour it completely shuts off (pilot and burners). The high limit and thermostat have been changed 1 month ago.
Check the hi limit sensing bulb, it should not touch the fire tube, when it does, it will sense high temperature which will trip its mechanical contacts and will shut pilot and burner flames.
Make also sure that the thermopile is free of soot or any form of dirt and is properly heated by the pilot flame.
Jul 06, 2010 | Pitco Frialator SG14 Deep Fryer
Pitco Fryer will not light up
Check the thermopile, it must be free of dirt or soot so that it can absorb enough heat from pilot flame and in turn can generate the right amount of voltage to energize pilot and burner coils.
Check also the gas pressure, it should be of standard as required on the unit's nameplate.
Apr 15, 2010 | Pitco Frialator SG14 Deep Fryer
Pitco Fryer
Jul 27, 2007 | Pitco Frialator SG18S Deep Fryer
Kitchen Appliances - Others Logo
93 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
