Question about Kodak Pulse 7 in. Digital Frame - Black
Problem with Kodak Pulse 7 in. Digital Frame
Kodak Pulse 7 in. Digital Frame w730s Lost it connection to internet now will not down load pictures. Also does not show any information by help buttons on screen
SOURCE:
SOURCE: Kodak EasyShare software won't connect to digital photo frame
I had some problems with wireless connectivity with the Ex1011. It turned out to be the connection was breaking when I used WPA security. When I went to WEP it worked fine. My suspicion is that the router was changing the Key over time and the frame wasn't following it. So it would work for a while then stop. But also had trouble even seeing it at times. Anyway, worth a shot. You might try turning off security on the router altogether to see if it makes a difference. Good luck.
Posted on Dec 20, 2008
jyackle5
  • 8197 Answers
SOURCE: Lost software CD and USB cable
You can download the software here as for the cable you need to contact them.
http://www.kodak.com/global/en/service/downloads/dln_ekn027989.jhtml?operatingSystem=x&downloadLanguage=en
Good Luck
Posted on Jan 18, 2009
SOURCE: 6800 G3 Kodak picture kiosk
my problem is the same. everything slows down. I also have another problem too. Any time I want to print from any cellphone the g3 gives me aqn error and then say to initiallize.-
Posted on Mar 28, 2009
  • 295 Answers
SOURCE: my kodak scanner won't scan but will print pictures
connect ur printer to ur computer and then try to scan any document or plug in any memory card and then press scan .it will ask u to save the file after scanning, save it on computer. ur issue will be resolved
Posted on Jul 27, 2009
leepania
  • 1099 Answers
SOURCE: the kodak easy share digital picture frame won't show my pictures
Pls. check if there is any reaction when pressing the buttons onto the frame.
Check the batt within the remote.
Reset the frame.
If all fails:
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Oct 15, 2009
The frame cannot find my wireless network
never saw a picture frame that used a network .
Dec 07, 2015 | Kodak Pulse 7 in. Digital Frame - Black
Picture frame screen turned blank
Yeah, they do that. There's a fix, but it costs more than the new ones. They're a lot cheaper than when you likely got yours.
Spend the money ... they're still cool.
Oct 13, 2014 | Kodak Pulse 7 in. Digital Frame - Black
Kodak W730 Pulse is not finding any wireless networks
I'm having the same problem so I'm trying to re register it but need the activation cade since I don't have the box anymore and it won't come up on screen
Nov 16, 2013 | Kodak W730 PULSE Digital Frame
Kodak pulse wifi problems
either you are not entering you web key for the wifi correctly or you have not entered the activation code for the frame which can be found when you hold the heath check button on the back of the frame
Dec 29, 2012 | Kodak W730 PULSE Digital Frame
Do not know how to transsfer pic fromcomputer to the Kodak pic frame
On one side of the frame there should be memory card slots and a usb slot.
two ways to do it, take the memory card from the camera and put it in the frame.
Or down load the camera to tyour computer and then with a usb cable upload the picture fram with the pictures you want
Or from your computer load a memory card and then stick it in the frame
Feb 20, 2010 | Kodak EasyShare SV811 (8858946) Digital...
HOW DO I DOWN LOAD PICTURES FROM EASY SHARE PORGRAM TO PICTURE FRAME?
There is no internal memory in your frame. You can transferre them via the SD card onto the frame. But unfortunantly not irectly onto the frame without a SD card.
Contact KODAK:
Jun 29, 2009 | Kodak EasyShare SV811 (8858946) Digital...
Cant copy any pictures from computer
You can start copying pictures to SV811 digital picture frame if you get the message “Use PC interface to copy files.” Here are the steps:
Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools:
1. Connect the USB cable from the frame to your computer
2. On your computer, open My Computer or Windows Explorer.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, and USB devices.
3. Navigate to the pictures you want to copy. Then drag and drop them to the new location.
4. Unplug the USB cable to view your copied pictures.
Copying pictures from EasyShare software:
1. Install EasyShare software (free download at www.kodak.com/go/sw )
2. Connect the USB cable.
3. On your computer, open EasyShare software. Select the pictures in My Collection and drag them into the Picture tray.
4. In the menu bar, select File and then Copy to the Kodak Drive letter.
5. Select the frame source to which you are copying.
6. Select Best for Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
7. Click Copy. Pictures are copied to your frame.
8. Unplug the USB cable and press “Home” icon to navigate to your copied pictures.
Feb 03, 2009 | Kodak EasyShare SV811 (8858946) Digital...
Can't transfer photos from computer to digital frame
1. Install EasyShare software (free download at www.kodak.com/go/sw)
8. Unplug the USB cable and on the frame check the pictures that were just copied.
Jan 17, 2009 | Kodak EasyShare M853 Digital Camera
Kodak easy share SV 811
I had the same problem. I use kodak easyshare software and load my pics on to that. Then put all the pics you want in the picture tray. Have your frame plugged into the computer with your usb cord. Then go up to File menu and drop down to "copy to". On my computer it is Folder "E" which is the drive the frame is connected to. Then pick from the Resize drop down menu " best for picture frame', then click copy. You will see the program loading all the pics to E drive. When done, unplug usb cord and you will see it loading on your pic frame. As easy as this is to do, I found it frustrating as well, but when it works, it is easy. Hope this helps
Aug 04, 2008 | Kodak EasyShare SV811 (8858946) Digital...
Kodak Pulse 7 in. Digital Frame - Black Logo
179 people viewed this question
Top Kodak Cameras Experts
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
