Question about Canon PC-920 Black and White Copier
Cannon PC920 I'm getting wrinkled copies
I'm getting a wrinkled fold from top to bottom on the right hand side of each of my copies. When I open the top of the machine I see gears that line that side of the interior of the copier, are they the problem?
  • Canon Master
  • 19,396 Answers
When paper is jamming inside the printer is either because one of the traction gears is stuck, because of a foreign object inside, or because something has broken.
Tru removing toner/drumkit unit, and remove carefully all peces of paper inside.
Unplug printer from main.
Once toner is out look for foreign objects, efentually with the help of a friend you can turn printer upside down and shake it gently (careful not to damage the printer), this will reveal the presence of lose parts inside.
Sometimes it is necessary to disassemble the printer to fix this kind of problems, in that case, call a technician.
Posted on Jan 21, 2009
    Sergeant:
    Novelist:
  • 326 Answers
Open the machine for gear realignment.also service the printer to free the gears. thanks
Posted on Jan 20, 2009
Copy machine - canon PC920 leaves black streak in middle of page - on copy
Check for white-out or some other dirt on the scanner head, the piece that moves from top to bottom to scan the item to be copied.
Feb 18, 2017 | Canon PC-920 Black and White Copier
Cannon MP 140 series Printer, USB002 The ink absorber is full.
This mayclear the ink absorber problem. There is ink absorbers located at both ends of the printerwhere the ink head move.
To dry the ink absorber, power up the printer and open the cover so the inkcartridges and print head will move to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place itinside the printer over the ink absorber on the far left hand side of theprinter to soak up the excess ink. You may need to change the absorbent tissuea few times. Then repeat the same procedure on the right hand ink absorber.
Close the lid and the printer should now function normally.
Sep 04, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Paper wrinkles when printing
You can try these following solutions:
If the paper does not completely eject, press the paper with folded side paper button, then open the printer cover and remove the paper. Also, check the Paper Size setting in your application or printer software.
If the paper is wrinkled when it comes out, it may be damp or too thin. Load a new stack then try to print again. You can also try to check the printer alignment and the printer setting.
Feb 11, 2010 | Office Equipment & Supplies
We are suddenly experiencing 2 problems. First,
The fuser needs to be replaced, it is causing your smears and the wrinkling/jamming problem.
Apr 28, 2009 | Lexmark T430 Laser Printer
A bar code stripe on the right side of the copy.
i'm not sure if you're talking about a solid black band or a bunch of little stripes running down page. does it happen when you run an internal report or only on copies? if its a black solid band, check and make sure the bluish colored tab on top of the drum is all the way to the left side. if its a group of fine lines, depending on whether it happens on internal reports or not, it could be the drum is going bad or you may have a bad scanner. write back with a little more info if this suggestion doesn't work.
good luck,
razors
Mar 18, 2009 | Brother IntelliFAX 5750e Laser Fax
Printer
mybe u put a lot of paper .try to put just one and place the paper holder to the left side of the paper
Dec 19, 2007 | Canon PIXMA MP210 Photo All-In-One Printer
My paper keeps "kinking"
Check the fusing unit.Pressure roller,pressure roller bushings, thermistors for over heating,fuser roller. replace if defective.
Sep 21, 2007 | Toshiba 1370 Black and White Copier
Canon PC-920 Black and White Copier Logo
old marine
old marine
