Question about Motorola Cell Phones
Mz616 won't turn on
Battery is charged, not fully
  • 328 Answers
SOURCE: 2004 Pontiac grand prix gtp won't start- fully
it is the alternator brushes cheap and tanks little time to be replace and the brush who is clicking
Posted on May 27, 2011
aquaman987
  • 927 Answers
SOURCE: Have a Husqvarna riding mower
For a riding mower to start, all of the safety interlocks must be "made".
The brake may have to be set.
The transmission may have to be in neutral.
The blades must be disengaged.
The driver may have to be in the seat.
If one of the necessary interlocks is not "made", the mower will not start.
Gary
Posted on Jun 18, 2011
rockmeister
  • 2047 Answers
SOURCE: my nokia n95 won't charge,
First check the charger by using it to charge a different phone to determine if the charger is functioning fine. After doing this check the battery is properly installed if both options above are in good condition then sorry to say but the central board on your unit is probably bad and will need replacement.
the central board is the main component of the phone and acts as thee brain of the device, all functions go through it. When you purchase a new battery the unit should at least come on even if the charging function does not work.
best refer it to an expert to determine if the entire board is spoilt or just the power segment of the board.
Hope this support has been helpful?
Thank you for visiting FixYa.
Posted on Jul 08, 2011
t00nz
  • 4738 Answers
SOURCE: Canon powershot SD1300 IS won't turn on, even
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Posted on Oct 11, 2011
SOURCE: won't turn on
I had this same problem! Scoured the web and found no solution. This is what I did to fix it...
Remove battery. Unplug charger. Press and hold the power button for 20 - 30 seconds. While still holding the power button, re-insert the battery and/or plug in the charger. Voila! Came back to life and worked like nothing ever happened.
I also did the same thing with the record button, but it was the power button that got the result.
Hope this helps!
Posted on Mar 18, 2012
Won turn fully charged battery
You sure your battery is fully charged and still good?
on the other hand Sony Cyber-shot's are known to have this problem.
Try pressing the on button for 5sec
Nov 24, 2017 | Sony Cyber-Shot DSC-WX9 Digital Camera
Phone is charged and won't turn on, also reset doesn't work
your battery is probably broken, try replacing it (ifixit.com), or let someone else fix it for you.
Dec 02, 2012 | Apple iPhone 4S
Battery will not charge
li-Ion batteries have a bad habit: whenever fully depleted, they lose a few cells, to the extent that they might not be able to hold a full charge if enough cells are damaged. In other words, repeatedly using a laptop (or any other Li-Ion powered device) to battery depletion can shorten the battery's life significantly. You might want to keep the batteries fully charged whenever possible and avoid fully depleting them too often.
There is also the habit of "re-setting" the batteries by using the "fully deplete-fully charge" procedure. It only applies to niMH or NiCD batteries ( and is used to erase the "memory effect" ) but is damaging to Li-Ion batteries for the reason mentioned above.
so if your battery can not full charge,this mean you need change a new battery for your laptop
http://www.aulaptopbattery.com.au
Oct 05, 2012 | Computers & Internet
I have a Finepix xp50, with a fully charged, correctly installed battery, that won't turn on. It worked intermittantly for awhile. We have 3 batteries for this camera thinking it was the battery
Be sure your battery is in the right way. Try reversing it. My battery has 3 rounded corners and one square corner. The square corner goes against the latch.
Aug 21, 2012 | Fuji Finepix F50FD Digital Camera
I put my Droid Razr on charger but battery symbol comes on with ? mark. Won't charge or turn on.
1. Turn off your phone when it's not in use. If you're not using your Verizon Wireless Razr, then shut it off. Your battery will last much longer if you regularly do this.
2. Charge your phone less. If you charge your Razr nightly, then your cell phone battery won't last long. Try to charge your phone only a few times a week to extend the battery life.
3. Keep your Bluetooth turned off when you're not using it. Applications, like Bluetooth, are notorious for sucking the power from a cell phone battery.
4. Protect your Razr from extreme temperatures. Your cell phone battery lasts longer if kept at room temperature.
5. Discharge the Razr fully. Before you charge your phone, let it completely die. You can extend the life of the battery by regularly discharging and then fully charging it.
6. Leave the battery in the phone. Keep the Razr battery dry and free of dirt to prolong its life.
Aug 20, 2012 | Motorola Mobility Motorla MOTXT912 DROID...
My battery indicator won't turn green when it is fully charged.what is this issue?
It is possible one of the battery cells has degraded enough the battery is not showing a full charge, or there is an issue with the green light, but this is minor provided everything is working.
Mar 07, 2012 | Acer Aspire One D250 16GHz Intel Atom...
Canon powershot SD1300 IS won't turn on, even with fully charged battery
Oct 11, 2011 | Canon PowerShot SD1300 IS IXUS 105...
Battery is fully charged, but netbook won't turn on unless plugged in.
I would say that you definitely need to purchase a new netbook battery. If it's only turning on when plugged in, then the battery itself doesn't have any more charge cycles.
Oct 10, 2011 | HP Mini 1033CL Netbook
Cell Phones Logo
29 people viewed this question
Top Motorola Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
