Question about Omron Exercise & Fitness
The screws fell out of my pedometer battery compartment. Can I get replacements?
3 Suggested Answers
SOURCE: Missing a battery for a Sportline Model 342 Pedometer.
Same problem here. If your pedometer is rectangular, with slanted window, LR 44 battery should work.
Posted on May 10, 2010
6ylucy
  • 742 Answers
You should be able to get every Sportline Pedometer manual here
Posted on Aug 27, 2012
I need to replace the battery in a Hrt Slim Mini heart rate pedometer.
https://www.nbmonitors.com/assets/Manuals/Archives/HRT%20Slim_HRT%20Slim%20Mini/HRT%20Slim_Slim%20Mini_English.pdf
Dec 26, 2013 | New Balance Balance Hrt Slim Mini Heart...
I can't turn it on
Mine wouldn't turn on either....what they do not tell you is that inside, (take out for four screws and open the meter), is another battery under a silver round clip. Take that bettery out and replace it....works like a champ now!.
Sep 01, 2012 | Gaiam Walking Fit Kit Pedometer...
What battery do I need to replace and how do I replace it?
the clock battery in the watch and unscrew the bottom piece and then put a new battery in where the old one was then screw the bnottom back on and well la go as new
Jul 07, 2011 | Sportline 345 Electronic Pedometer
Hello, I have a Sportline Digital Motion Sensor.
Do you mean the screen is blank or you cannot remember how to program it? Was it working perfect until you replaced the Battery?
Make sure the battery is inserted with the positivet side up?
Manual is here: http://www.sportline.com/manuals/370.pdf
Replacing the battery: 1. Unscrew the battery compartment cover on the backside of the unit using a small Phillips screwdriver and remove the cover. 2. Remove the exhausted battery from the unit, and insert a new battery (be sure to place the positive (+) side of the battery is visible, facing toward the battery compartment cover). 3. Replace the battery compartment cover on the battery compartment and fasten the screw (CAUTION: do not over tighten).
Dec 14, 2010 | Sportline 370 Traq Motion Sensor Pedometer...
Lost the directions need to know how to set all the buttons
Here see if this helps....
http://www.gaiam.com/product/pedometer+fitness+kit+-+intermediate+level.do
How to use the pedometer:
Take out battery insulator pull tab.
Set the metric / imperial system.
  • Press the S5 (Up/Mode) to enter step mode.
  • Press S3 (Set) and hold button for 3 seconds.
  • Press S5 (Up/Mode) to toggle between metric / imperial.
  • Press S3 (Set) to select.
  • Basic operation buttons:
    Time mode
  • The display shows the current time.
  • Press S6 (Down) to toggle 12/24 hour display format. If 12-hour display format is selected, PM times are indicated with a P.
  • To set time: press and hold S3 (Set) to adjust mode. Hour will flash and display.
  • Press S5 (Up/Mode) of S6 (Down) to adjust the flashing digits. Hold the button for fast scrolling. Press S3 (Set) to confirm and move to minute. Adjust the minute.
  • Press S3 (Set) to confirm, and return back to the time mode.
  • Step mode:
  • Press MODE key to enter step mode.
  • The display shows the steps you have dones.
  • Press and hold S2 (CLE) to reset the step count. All information regarding the step counter/distance/calorie will be erased.
  • Distance mode:
  • Press mode to key enter distance mode. It shows the distance traveled.
  • To set personal stride: press and hold S3 (Set) to adjust mode.
  • Press S5 (Up/Mode) and / or S6 (Down) to adjust the flashing digits. Hold button for fast scrolling. Press S3 (Set) to confirm, and return back to distance mode. Set stride: 30-180CM (12-70 inch).
  • Calorie mode:
  • Press mode key to enter calorie mode.
  • It will show the calories burned.
  • To set personal weight: Press and hold S3 (Set) to adjust mode.
  • Press S5 (Up/Mode) and S6 (Down) to adjust the flashing digits. Hold button for fast scrolling. Press S3 (Set) to confirm, and return back to calorie mode. Set weight: 10-15kg (20-330 lbs.)
  • Measuring your own stride:
  • An individual's stride may vary in length. Input the appropriate length by measuring the distance of 10 steps and dividing by 10 to get your own stride length.
  • How to adjust:
    Motion sensitivity slide switch
  • Attach the unit correctly and walk 100 steps. If the reading is 105 steps or more, slide the Motion sensitivity switch to the left. If the reading is 95 steps or less, slide the motion sensitivity switch to the right.
  • How to wear your pedometer:
  • Your pedometer clips easily and snugly to either side of the hip portion of your pants or shorts. For best results, keep the unit in line with the crease line of your pants.
  • The pedometer must be directly perpendicular to the ground. The pedometer needs to be at a 60 degree angle to the ground. Dragging your feet, walking with sandals or uneven footsteps in a crowded area can affect the accuracy.
  • The pedometer only works when walking, jogging, or walking up/down stairs.
  • How to use the panic alarm:
  • Pull out the panic alarm pin S7 (Panic Alarm) from the unit to trigger the alarm.
  • Press and hold S1 (RES) to stop sound temporarily.
  • Insert the panic alarm pin back into the unit to stop the alarm instantly.
  • Battery replacement:
    Panic alarm and LED Torch battery:
  • Open the battery door by unscrewing the secure screw.
  • Flip out the exhausted battery and replace with two new *CR2016 (3V) batteries. Make sure the polarity is correct. Close battery door and fasten the screws.
  • heatman101
    Oct 02, 2010 | Gaiam Walking Fit Kit Pedometer...
    There is nothing on the screen of the pedometer, what ever I press. Do they run on a battery and if so can it be replaced? There's no apparent place to fit a new battery!
    Pedometers run on a battery, the type depends upon the exact make and model which you have failed to mention.
    Many cheap giveaway pedometers are not designed to have the battery replaced but it's usually possible to carefully prise the case apart if it's not screwed together. Some are glued together in which case you'll need a razor saw: if you have to buy a razor saw then it's cheaper to just replace the pedometer. You'll often find that with cheap disposable pedometers that the batteries actually cost more than a complete new unit with batteries included.
    More expensive pedometers will always have a clearly defined battery access point, even if it's just a matter of undoing a few screws to separate the casing..
    Sep 21, 2010 | Vacuums
    I need help knowing how to replace sportline s12 battery
    it uses a cr2032 lithium battery.it says to take to a dealer,but get a small phillips screwdriver.take the 4 screws off back,there will be a small rubber bans on inside,thats for the water resistance,change your battery and put rubber seal back on,then the back.and you are set.good luck.
    Jul 03, 2010 | Heart Interface Sportline S12 Ecg Heart...
    Oct 23, 2009 | Sportline Exercise & Fitness
    Operator manual for lifesource pedometer H-215
    pacificrimwellness.com/library/.../H215-Pedometer_Manual_ENGL.p.
    Jun 10, 2009 | RTO Reebok CS-1 Pedometer
    Exercise & Fitness Logo
    62 people viewed this question
    Top Omron Exercise & Fitness Experts
    Electro Med Services...
    Howard
    Howard
    Tom Chichester
    Are you an Omron Exercise and Fitnes Expert? Answer questions, earn points and help others
