Question about Roland Music
Boss BR-8 won't power up
I have a Boss BR-8. It hasnt been used for a few years, and the last time it was used, it was used by my teenage daughter who never mentioned anything wrong, but who knows, did she shut it down properly etc? When I have turned it on, I get nothing in the display other than illumination. Leds are lite under the faders of 1, 3, 5 and 6. Nothing will work. A brief search of the internet and some posts here, they lead me to restart it holding down the button under 5 and the undo button at the same time. Eventually, it came to life, and after a bit of messing around it work. It did not give me an initialization menu as others have mentioned, it just started going. Used it for 30 mins and then shut it down properly. Now, the following day, it won't work again. The tip of holding down 5 and undo whilst powering up doesn't work. I have been trying for nearly an hour. Is there something that can be done? It is not used enough to warrant a repair. Someone said to download the latest software, but without a zip drive, I won't be able to put it on a disk. Your help would be appreciated. Kind regards, Andy
  • Andy Shukie Jan 09, 2013
    Thanks for the comments. I dont have time to mess with it tonight, other than to check the supply voltage. It is 9.3v. It is the outer on the connector which is positive....is that correct?
CRTN
  • 716 Answers
SOURCE: boss br-8 digital recorder wont load up. powers up but no program
This Sounds Very Bad Do You Have Experience With Taking Apart Computers? If So You May Want To Open Up Your Br-1180 And Remove The Hard Drive And Put It In Your Computer And Copy All The Data Off Of It. I Also Would Recommend Calling Roland They Are The Most Helpful People In The World.
www.Myspace.com/CrossRoadsToNowhere2007
Posted on Jan 05, 2009
  • 5603 Answers
SOURCE: My Boss RC-50 has stopped working. I used the
CHeck the voltage out of the adapter. It should be around 9 to 11 volts. If it is not, it is possible that the OC3 has reversed polarity AND a protector that put a short on an incorrect supply. If so, it could have damaged the RC50 adapter. If the RC50 adapter is putting out correct voltage, then I suspect the inout connector on the RC50 may be damaged or not quite seated. Visually inspect the connector first.
Posted on Dec 04, 2010
SOURCE: I bought a used BR 532 Boss recorder - can't get a
I get an unformatted come on the screen on my Boss BR 532 when I swith on, and also when pressing record, although I can get drum machine to work and guitar go through it ok but no recording Hmmmm Erggg
Posted on Feb 14, 2011
  • 411 Answers
SOURCE: the boss br-8 multitrack recorder. would somebody
The possibilities are almost endless. It's going to have to go to a qualified repair shop.
Posted on Jul 05, 2011
  • 5603 Answers
SOURCE: I bought my g-dec jr form ebay last summer and
This amp uses a TDA2050 chip that has thermal protection. It is also a small amp that is NOT capable of high sound levels. If *********** can't stand to be within 5 feet of this amp you are playing TOO LOUD for this amp and it will shut down until cooled off to protect the amplifier chip. This amp is intended for practice. It would be adequate for sensible listening level in a 10 foot by 10 foot room. If you need more sound you will have to get a bigger amp. I would suggest you get a sound meter and verify the sound level. DO NOT exceed 4 hours at 90 DB... I know a lot of deaf musicians that have lost their hearing and they are not much good anymore.
Posted on Jul 16, 2011
Hi, I have a boss BR 600 and when i insert any card it checks the card and then says ' card not supported'. I t used o work fine. However i have noticed that 2 pins seem to be missing inside t
I have the exact same problem. All my flash cards worked fine, and all of the sudden, none work. Not even the one that came with it. I am still trying to fine the reason. I bought it eight years ago, that might be it.
Jan 30, 2013 | Roland BOSS BR 600 8 track portable...
Boss br-600 unsupported card
Feb 12, 2012 | Roland BOSS BR 600 8 track portable...
Hi. My boss br 1600 will n ot start. I turn on the power source and it will blink for a split second and then nothing. I checked for loose connections but everything seems ok. Any suggestions?
I have this problem with mine. I've did some research and with the boss br 600 this problem can arise quite often .it's caused by a faulty power diode apparently except in that case I've never heard ofrom the screen blinking at all (which my 1600 also does) I wonder I'd this problem can be the same for a br 600 as the br 600
Sep 08, 2011 | Boss BR 1600 Cd Br1600 Cd 16 Track Digital...
My Boss br-8 keeps saying medium error. It's not reading any disc. It ask me to initialize disc that already have music on them.
If the disk had music that was not CREATED on the BR-8 you will get the error. The format is incompatible with computer formats.
If the files were created on the same BR-8, then you probably have a disk drive failure.
Try initializing a blank disk. If it will not, then you have a drive failure.
Also is it possible you are trying to read a 250Mb disk on a 100Mb drive? That won't work either.
Jul 25, 2010 | Boss Micro BR Digital Recorder
Nov 16, 2009 | Boss Micro BR Digital Recorder
Need Help on a Boss B R 8
I think I solved this problem.
I used a different power adapter and it works now. Try different adapters, I used an old Nintendo one. It is 9V 1.3A, even though the back of the BR-8 says 9V 2A
Jul 18, 2009 | Boss Micro BR Digital Recorder
Boss br-8 digital recorder wont load up. powers up but no program
Dec 28, 2008 | Boss Micro BR Digital Recorder
Music Logo
429 people viewed this question
Top Roland Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Roland Music Expert? Answer questions, earn points and help others
