The remote control stopped working so I switched the batteries and it still didn't work.
    New Friend:
  • 4 Answers
Try opening the remote controller and check if there's any buttons push in
Posted on Jan 08, 2013
  • nikos katsiko
    nikos katsiko Sep 05, 2014
    yes it have the same botton as the aircondition but the only thing it do is reboot the remote controller and still not working in the aircondition
SOURCE: My Sharp Remote Control Is Suddenly Stop Working
Ok I just dealt with the Sharp customer support for this problem.
1) You need to unplug the TV for 1 full minute and remove the batteries from your remote aswell (this will reset the system)
2) Hold the power button on the remote for 30 seconds with the batteries still out of the remote and the TV still unplugged
3) After the 30 seconds replace batteries then press every button on the remote beginning with the power button in order from left to right and top to bottom (same way you read)
4) Then plug your tv back in and try the remote again.... and the remote and TV should be back in sync.
Posted on Jan 01, 2009
  • 5471 Answers
SOURCE: TV Remote control stopped working. I changed the
It depends. If this is a remote for a satellite receiver, you may need to resynch the remote (see your manual - I know the Dish instructions).
If this is a TV only remote, you might try opening it and cleaning the contacts with an can of compressed air, electronic contact cleaner and a clean pencil eraser. However, recent remotes are like keyboards (membrane contacts) and this doesn't always work. In that case consider a universal remote to replace the bad one or look to see if remotes.com has a duplicate of your remote.
I hope this helps.
(for Dish, it is turn on the TV and the receiver, hit the Sys Info button on the receiver, then hit record on the remote. Then hit Select on the remote.)
Posted on Apr 24, 2010
  • 204 Answers
SOURCE: remote control stopped working, changed batteries
For this you have remove the outer cover of the remote and wash the top portion of the remote(PCB board)with any volatile liquid like spirit,petrol.
Posted on Jan 13, 2011
gopakumarg43
  • 75571 Answers
SOURCE: remote to tv doesn't work
Hello
Check the remote first for its infrared emission. If it is OK, the infrared sensor inside your tV is faulty. It should be replaced with same type and number. It can be located just behind the infrared window at the front panel of your Tv. You ahve to open your TV ot access it. It will have three solder terminals, and will look somehat brownish black in colour. Will look like this.
Posted on Nov 14, 2011
gopakumarg43
  • 75571 Answers
SOURCE: Remote control has stopped working
Visit this site to get more details about now to check a remote control and how to repair it.
Type in this link address, [without brackets] either to Google Search Box or into the Address Bar to your browser and press Enter. Pull up the older posts. You can see it htere.
electronicshelponline(.)blogspot(.)com
In name [Electro-Help]
Posted on Apr 19, 2012
Sony RMT-D187A stopped working!
1= change the batteries by new ones
2= clean the contacts cleaners with contacts cleaner
3= resolder the wires contacts batteries
4= retight the spring contacts batteries with pliers for better contacts
5= open the r.control clean the kepayds switch for dirty, oxide, and test for open, bad contacts.
6= try agan, if doesnot work go to the repair shop TV for fix it.
God bless you
Jul 19, 2012 | Sony Televison & Video
Remote quit working for litex ceiling fan
after changing the batteries make sure you didn't change the remote code. If you didn't there should be a reset button inside the battery compartment, it may just look like a small hole. Just use a toothpick and insert it into the hole and lightly depress the reset switch.Replace the battery cover and try using the remote again.
Apr 13, 2012 | Casablanca Fan Dryers
Problem with hunter ceiling fan 23272
The problem is with the remote receiver attached to the fan body. It is a small device that acts as a remote switch and this is cradled in a pocket inside the ceiling fan itself. If you are handy, you can replace this device yourself. I believe you need to purchase a new kit from Lowes that comes with a matched transmitter and receiver for fan control. Go to Lowes Lighting section for this product.
Jan 12, 2018 | Hunter Dryers
My remote control for my TV won't work. I changed
See my response to your other identical question.
Mar 14, 2012 | Philips Televison & Video
My remote for sony dvd player NS 590 p suddenly stopped working. I repleced the batteries but it didn't help
if its not batteries it will be a replacement remote. try cleaning the terminals and see if helps,
Dec 10, 2011 | Televison & Video
I have a 32" insignia LCD TV. My remote stop
You can reset your remote control by removing the batteries, pressing all of its buttons, and installing new batteries. Also, ensure that your TV's sensor is clean and unobstructed. If the problem persists, try using a universal remote control as a troubleshooting step. This will help identify whether the original remote or the TV is at fault.
Oct 20, 2011 | Insignia IS-LCDTV32 32 in. Television
My remote won't set to the tv I tried pressing the set button and it didn't work then I replaced the batteries to see if that would work but it didn't and now I don't know what to do please...
Hello
You might have a cellphone with camera option. Set the cellphone co cemera mode, and place the remote control at about 1 feet away from its camera lens, and press each button on your remote control. Remote control emits infrared rys as we press each button, but can't be detected by human eye. Electronic cameras can detect it. If there is any infrared ray emission from your remote control you will see its image on the camera screen for each button press to your remote control. If there is image and still the Tv doesn't respond to it, The TVs' infrared snsor inside has damaged and should be replaced. If there isn't any image; check the battery contacts of the remote battery compartment first. Clean these contacts by using a piece of corborandum paper or with the tip of a razor blade. Improper battery contacts, due to rust and dust to these contacts will prevent the battery supply voltage to enter into the remote contro.
Still it doesn't work at all, the remote control is damged and should be replaced. Contact the nearest Vizio Authorised Service Cente fro original remote control. OK.
Jul 21, 2011 | Vizio VF552XVT 55 in. LCD HDTV
Remote Keyboard and Remote Control have stopped workinh
1- Check all batteries and check all switches sometimes adjusting the switches to a different channel position helps.
2- There usually is a button on all three items, mouse keyboard and transmitter press all three.
3- Re-install drivers usuing a corded keyboard and mouse
Apr 25, 2009 | Microsoft Keyboard, Remote Control
Fan and remote not working
make sure the main switch is on ,also the chain switch on ,before using control remote!!
Dec 23, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
