Question about American Standard 4175.200.002 Colony Single Control Kitchen Faucet, Polish
American standard bathroom faucet model 2804 cartridge
  • 171 Answers
SOURCE: kitchen faucet , reduced water flow / pressure
Hi ssam1
I'm Harvey the Master Plumber.
You want to know if you can fix a sudden low volume /pressure delivery problem on an American Standard model AS4205100 H7, one hole / single lever with pullout spray And is it fixable by owner?
Yes and maybe!
All plumbing systems are plauged with debrie buildup. Every time you turn on a faucet the water starts moving and will bring bits of debrie up from the water main or well. Most are small and will pass through to be caught by the screen in the aireator. Sometimes a relatively large piece comes along and dosen't make it through to the screen. It is stuck in the body of the valve.
Fixing takes a little mechanical ability.
First, turn off the water to the faucet in question. Then carefully disasemble paying close attention to the order of disasembly so you can reverse the order when putting back together. As each part is removed inspect it for that troublesome bit. I find that a little bit of wire or a paper clip is helpfull. Carefully reasemble. If the volume is still low then you missed finding that bit. Try again or call in a local pro.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 10, 2008
  • 68 Answers
SOURCE: Slow and nonexistent water flow.
Start by removing the spray head from the hose. Pull the spray head out and with a channel lock pliers unthread connection between the spray head and hose. BE CAREFUL not to let the hose fall back down into the faucet. With the hose directed down toward the sink test for volume by turning on the faucet. If you get a nice volume the problem is in the spray head. This is usually the case. Put the spray head back on then remove the aerator. It's the screen where the water comes out of the spray head. Clean out the assembly ( 3-4 parts). Reassemble and test.
Good luck, Phil
Posted on Dec 11, 2008
  • 297 Answers
SOURCE: American Standard Easy Touch 6310 kitchen faucet leaks at base
you must remove the faucet form the sink. under the plate in the middle is 2 screws. remove the screws to remove the body.
Posted on Jul 15, 2009
  • 297 Answers
SOURCE: how to replace sprout seal kit in american standard faucet ?
just pull straight up,wiggle back and forth,the o-rings are holding it on .
  • 297 Answers
SOURCE: American Standard Colony Soft gooseneck kitchen faucet leaks base
at the spout near the base is an echeion ring. turn this counterclock wise then pull up ring to expose the neck,pull spout straight up.this echeion cap holds on the spout to the base there are plastic parts inside so be careful when pulling apart.
Posted on Jul 22, 2009
How to replace washer cartridge in bathroom tap
Turn the faucet to the closed position. Turn off the water to the faucet. Remove the handle. The screw that holds it on may be under a plastic cover. Unscrew the large nut. Remove the cartridge. Put the new cartridge in the closed position. Look at the old cartridge and be sure the new one matches the old one. Insert the cartridge. Replace the nut and tighten. Replace the handle. Turn on the water.
Nov 16, 2014 | American Standard Plumbing
How do remove the screen on an American standard bathroom faucet?
Simply unscrew the end of the tap where the screen is. Some faucet models have a small hole just above the screen where you insert a pin that locks the parts together so they can be unscrewed in the counterclock rotation.
Aug 07, 2014 | American Standard Ceramix Monoblock...
When turning on my American Standard single faucet I get a water hammer noise and my sprayer also jumps?
Replacing the spray diverter or faucet cartridge ( depending on your model) will fix the problem. Call American Standard and ask for free replacement parts.
Sep 09, 2010 | American Standard Plumbing
Installed new tub faucet and all i have is a trickle
If you have galvanized water lines in your home, I will bet you have sedament in the cartridges causing blockage.
Sep 30, 2009 | American Standard Colony 3275.505 099...
How to replace sprout seal kit in american standard faucet ?
Jun 05, 2009 | American Standard 4275.550.002 ColonySoft...
American Standard 4175.200.002 Colony Single Control Kitchen Faucet, Polish Logo
103 people viewed this question
Top American Standard Plumbing Experts
john h
Steve Wood Plumbing...
Level 1 Expert
Mike
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
