Question about Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic dvd/vcr DMR-EZ47V model.Code OOOOOO keeps going across.
On this dvd recorder/vcr, code OOOOOO keeps going across the display. I set unit to record on vcr, turned player off. Wanted to check the times so turned unit back on. Code started going across display and went to the dvd but won't play dvd or let me turn unit back off. None of the functions work. Manual says the unit is carrying out a recovery process but that was 2hrs ago. I didn't want to unplug it and start over. Can anyone help? Thanks
  • 1 more comment
  • kahead50 Feb 27, 2009
    Thanks so very much. When this happens again, I will sure try that method. thanks again...
  • dppeters2004 Mar 30, 2009
    I have tried to play my VHS tape but it didn't turn on.  The tape inside the player would not eject until I dpressed the eject button while the display was sending those little squares across the display.  Now it won't take a tape.  Everytime I try to turn on the player on the display reads C 8.1. Whats this about?
You must manually hold in the on/off button on the machine itself (NOT on the remote) for approximately 30 seconds. This will shut the unit off. Then you can restart it.
Posted on Feb 26, 2009
I have a panasonis DMR ez47v and a ez48v. the remote will work on the 48v but not on the 47 v are the codes the same Den
Panasonic remotes have a number of code sets. Thus if you have more than one panasonic device the remotes will not clash. Check the manuals for the code sets and how to change them.
Good luck
May 30, 2014 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DMR-EZ47V DVD Recorder / VCR Combo RC1 errior message how do I fix this problem
To get into Service Mode, first put the machine in STANDBY mode, then press the buttons ChUp OPEN/CLOSE and REC all at the same time on the front panel (Ch Up is hidden inside the AV3 input flap). Eventually the front panel display will show "SERV" (after its "HELLO" messages). Anyway, pressing [6] then [5] on the Remote Control tells me that I have an Error Code of "04" which is a Digital PCB or Communication Error (whereas an Error code of "02" means a "Defect of RAM drive"). (To exit from Service Mode, press [0] then [0] which should get you back to "SERV" and then POWER-OFF the machine).
Hopefully, your manual will display your error codes.
Perhaps the remote control is not set to the same control code as your DMR-ES40V. Codes may be set to 1, 2, or 3 on the remote by holding down the enter button and one of those number buttons for several seconds at the same time. The factory default is code 1. Try 1 first. If that doesn't work try 2. If that doesn't work try 3. If one of those codes doesn't work you may have a bad remote or a bad sensor on your machine. On DMR-ES35V models the sensor is located just to the right of center behind the black window
Jun 23, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
I am getting a U99 error code. The only function
The "U99" error code signifies a "general communications failure."
It is not associated with one specific problem.
It can be related to the version of firmware your DVD recorder is currently using and it has been associated with the TV Guide on screen guide.
If your unit displays U99, turn the power off-unplug the
unit for 5 minutes, and reconnect the power.
If U99 reoccurs, please contact the Global Service Center Network for assistance.
Feb 26, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic dmr-ez47v won't recover from u61 code faul. Unit keeps ejecting tray and switching off.
no solution sorry, I have same problem. any one else with same prob?. Thought panasonic was a good make, 18 months old and now knackered.
Dec 01, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Paqnasonic DVD recorder Model DMR-EZ45VEBS is stuck with error code U61, and now will not play any disk. Every time I insert a disk it comes up with the error code, Problem started whnI was recording a TV...
try cleaning the OPTICAL LENS directly with a Qtip , gently rub , try again , the code U61 means a self test procedure that the unit is running according to PANASONIC tech people, good luck , AJ
Nov 30, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
New Zealand dvd will not play on my Panasonic dmr ez47v can you help please .
If DVD disc was purchase in New Zealand the region code is Region 4, if the Panasonic unit was purchase in the US it only plays DVD disc with region code "Region 1 and ALL". This information is found on the back label of the disc that has the code on the globe.
Sep 16, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Unlock region code on DVD player
go here and have a look
Apr 30, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
I have a panasonic DMR-ES46V vcr/dvd HDMI i lost the instruction manuel and need to reset the remote to work agin i dont have the codes to do so all the display says is set 1 and the remote dosnt work
1) Hold The Enter Button Down On The Remote
2) Press And Hold The Numeric Button "1" For About 3-4 Seconds
3) Your Remote Is Now Reset To The Remote Control Code #1 (Default Setting)
Apr 27, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Can you tell me the Full Model number for this TV Please
Jun 11, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
543 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
