Question about Gateway DX4860-UR14P DT.GD4AA.004 Desktop PC Windows 7 Home Premium 64-Bit
Wifi connection problems on windows 7 64 bit and ios devices
    Sergeant:
  • 247 Answers
You will need to be more specific if you want more specific advice.
Two totally different systems are having trouble connecting to your router/gateway device? Orient your antenna vertically and see if you can connect from a few feet away. If not restart your router and try again. Be sure you are using the appropriate protocols (WEP/WPA etc.) and credentials (passphrase/word, key, PIN) to link devices together.
Posted on Jan 09, 2013
How do I stop continually trying to connect to wifi and failing
Unable to Connect to wifi problem - Solved for me ' Apple Support ...
discussions.apple.com > Support > Apple Support Communities
Apple Inc.Jun 7, 2012 - I tried the "forget the connection" workaround but it always came back. ... recognizing and joining the wireless network, but are not connecting ... Ipad won't connect to wifi after update iOS 7.0.6
Mar 1, 2014
New iPhone 5s - constant "Incorrect WiFi" password
Nov 25, 2013
Wifi ISP keeps failing
Sep 10, 2013
New Macbook Air - wifi connectivity problems
Jun 13, 2013
More results from discussions.apple.com
How to fix limited or no connectivity Wi-Fi issues in Windows 8
www.fixedbyvonnie.com/.../how-to-fix-limited-or-no-connectivity-wi-fi...
The connection is limited ... He couldn't connect to Wi-fi on battery power. ..... Will this work if we have limited connectivity when trying to connect through a LAN cable? .... I found another solution, If you are running Windows 8 and your laptop keepsdropping the WiFi .... Investigate router or access point issues Failed
Dec 28, 2015 | Tablets & eReaders
How do I get iOS 5
How to do I update to iOS 5?
There are two ways to upgrade the iOS version of your iPhone, iPad, or iPod Touch - via connecting the device to iTunes on a computer
(or directly from within the device, but only snce iOS 5, it is possible to upgrade the iOS version without the need to connect the iOS device to a computer (over-the-air update).)
get-ios-5-t1spgccj4wn2l2jsn32qxq4v-4-5.jpg get-ios-5-t1spgccj4wn2l2jsn32qxq4v-4-9.jpg get-ios-5-t1spgccj4wn2l2jsn32qxq4v-4-14.jpg
May 07, 2014 | Apple iPad 32 GB WiFi Tablet PC
Need to update my ipad 2 to iOS 7.1
There are two ways to upgrade the iOS of your iPad
- or directly from within the device
so in your case you can try connecting the iPad to a computer with iTunes installed
procedure:
  • Connect your iOS device to your computer using an USB cable. Wait for iTunes to open and connect to your device.
  • Click on device button to the left of the iTunes Store button in the top right corner in iTunes.
  • Hold down on the option key (Mac) or the shift key (Windows) and click the "Check for Update" button in the Summary pane. Browse to the .ipsw file you downloaded and select it.
  • Do not disconnect your device until the update has finished.
  • If necessary, restore your device from the previous backup and sync with iTunes.
need-update-ipad-2-ios-7-1-qrl052hdp2kg0kvuqxssgusw-4-0.jpg need-update-ipad-2-ios-7-1-qrl052hdp2kg0kvuqxssgusw-4-2.jpg Install iOS 7 0 4 update on iPhone or iPad Tutorial
Apr 06, 2014 | Apple iPad 2 Wifi 16GB
Logithec attack3 devices not detected
Disconnect the divice uninstall the driver restart the laptop and then reinstall the driver again restart the laptop then connect the device it works.
Apr 03, 2014 | Video Game Consoles & Games
Can't connect iPhone 5s and hp 1220c
Sir/Madam
iOS: Troubleshooting Wi-Fi networks and connections Symptoms This Issue is Related To Your apple Mobile And Make Sure You Already Install HP Printer Software In Your Desktop or Laptop. If yes I suggest you perform below Solution for Your Apple 5s and HP Priter Connectivity Issue:
Learn how to troubleshoot WiFi.Issues you may encounter while using your iPhone, iPad, or iPod touch.
Resolution Occasionally while using your iOS device, you may notice unexpected Wi-Fi behavior: Difficulty locating or connecting to a network
Unexpected Wi-Fi signal strength or disconnects
Inability to access the Internet
Not automatically connecting to WiFi when expected
Follow these steps to troubleshoot the above issues:
1.Be sure you're in range of your Wi-Fi router (access point).
2.TapSettings WiFiand turn WiFi off and on. If your Wi-Fi setting is dimmed,follow these steps.
1.Confirm that your Wi-Fi router and cable or DSL modem are connected to power, turned on, and connected to the Internet. If not, refer to your network administrator or Internet service provider (ISP) for assistance.
2.Restart your iOS device.
3.Tap Settings WiFi and locate the WiFi network to which you're connected.
4.Tap and Forget this Network.
5.Try to connect to your desired Wi-Fi network.
Note: You may need to enter your Wi-Fi password again if your network requires one.
6.Turn your Wi-Fi router off and on. If your ISP also provides cable or phone service, check with them before attempting this step to avoid interruption of service.
7.Update your deviceto the latest version of software.
8.Update your Wi-Fi router to the latest firmware. For AirPort Base Stations,install updates using the AirPort Utility.
If the issue is still unresolved Follow the steps below for the issue you're experiencing.
Collapse All'Expand All
Unable to locate a Wi-Fi network
Unable to connect to a Wi-Fi network
WiFi disconnects or signal strength is less than expected
Unable to access the Internet while connected to Wi-Fi
Unable to automatically connect to Wi-Fi
Additional Information Find information onconnecting to a Wi-Fi network.
Some third-party routers may not be compatible with all iOS devices, even after updating to the latest firmware. If your iOS devices can successfully connect to other Wi-Fi networks, contact your router's manufacturer to ensure that your router is compatible with your iOS device.
See recommended settings forconfiguring your Wi-Fi router for use with iOS devices.
Notes
1.iOS devices sold in China may use the term Wireless LAN (WLAN) instead of Wi-Fi. Not all China iPhone models supportWLAN.
2.If needed, please consult with your network administrator (which may be your Internet Service Provider) for assistance with this step.
3.iPhone 5, iPad devices, and iPod touch (5th generation) are the only iOS devices that can connect to 5 GHz networks.
If You Still Haveing Problem then Visit official Below Apple Website URL Link:
http://support.apple.com/kb/ts1398
Or
In case you still having HP Printer Issue Then Follow Us On:
HP Printer Support
Feb 12, 2014 | HP DeskJet 1220c InkJet Printer
Please post the solution. Why is there no "software update" on my IPad 2?
There are two ways to upgrade the iOS version of your iPad
- or directly from within the device, but only since iOS 5, it is possible to upgrade the iOS version without the need to connect the iOS device to a computer (over-the-air update)
just go to: settings - general - software update
- so in your case try an update with a computer with iTunes installed:
- procedure with iTunes connected:
Install iOS 7 0 4 update on iPhone or iPad Tutorial please-post-solution-no-software-qrl052hdp2kg0kvuqxssgusw-5-0.jpg please-post-solution-no-software-qrl052hdp2kg0kvuqxssgusw-5-2.jpg please-post-solution-no-software-qrl052hdp2kg0kvuqxssgusw-5-5.jpg
Jan 31, 2014 | Apple iPad 2 Wifi 16GB
Download ios 7 update
There are two ways to update the iOS version of your iPad 2:
but only since iOS 5 it is possible to update the iOS version without the need to connect the iOS device to a computer (over-the-air update)
download-ios-7-update-hmu2cfrdaalq4nhfkdotj12h-4-2.jpg download-ios-7-update-hmu2cfrdaalq4nhfkdotj12h-4-8.jpg download-ios-7-update-hmu2cfrdaalq4nhfkdotj12h-4-12.jpg
Jan 30, 2014 | Apple iPad 2 Wifi 16GB
Can't get my Nikon s9500 to connect to wifi
The only connection you can make is a wifi connection to a Andriod or iOS device (iPhone or iPad) if you first install the appropriate software on the Android or iOS device. It is in the manual on page 93, 94 and 95. The manual is online with Nikon USA.
Nov 25, 2013 | Cameras
Load iOS 5
load-ios-5-b1rp0yxywxqcfecmaboiorny-5-0.jpg load-ios-5-b1rp0yxywxqcfecmaboiorny-5-2.jpg load-ios-5-b1rp0yxywxqcfecmaboiorny-5-5.jpg
Apr 17, 2013 | Apple iPad2 WiFi 64GB
Gateway DX4860-UR14P DT.GD4AA.004 Desktop PC Windows 7 Home Premium 64-Bit Logo
79 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
