Question about Audio Technica AT-PL120 Turntable
Anti skate doesn't work regardless of setting.
I use a groove-free vinyl disc. Anti-skate does not work regardless of setting. The stylus always moves from the edge of the vinyl to the center. Is there some adjustment underneath the turntable?
2 Suggested Answers
  • 9 Answers
SOURCE: I just set up my
KEEP THE ANTI SKATE AT 0 FOR NOW,then you need 2 balance the tonearm with the rear counterweight so it just hovers at around the height of the platter.now you need to zero the gauge on the rear counterweight being carefull not to turn the counterweight,then check again that the tonearm still hovers.then screw counterweight inwards untill the dial on counterweight reads between 1.5- 2 grams dependin on tracking weight of cartridge.then adjust antiskate 2 whatever u set the tracking weight to.i would also double check with a spirit level ur level surface
Posted on Oct 13, 2010
Denon dp-26F when i tried to play a record the arm just skated all the way across the record. is there a way to adjust the arm so it plays correctly?
The short answer is that you need a new stylus as the one you have is either broken or worn away so that it won't stay in the groove. It could also be out of place. Rubbing your finger on the stylus you should be able to feel it digging in. If you can't it's gone!
Nov 16, 2014 | Denon DP-26F Turntable
Anti skating
Skating is when the stylus slides across the record's surface and doesn't stay in the grooves. This can happen when the stylus is too worn and so any control to correct it called "Anti Skating" won't work. Getting the pressure right to the stylus is the first thing to do. Once this is set up if an odd record then skips a few grooves on a good condition record, you can adjust the Anti skate control to prevent it. Adjustment it is like setting the stylus pressure, a question of trial and error.
Jan 16, 2014 | JVC Audio Players & Recorders
Needle skips along records.
3 causes
1. Bad stylus.
2. Not enough weight - adjust weight on end of arm, or turn knob with numbers up slowly bit by bit, trying a record each time till it stops but doesn't "rumble".
3. Adjust anti-skate control if it's got one. Again bit by bit, testing with record.
Aug 28, 2011 | Sony Audio Players & Recorders
I have purchased two ARK IV white elliptical Stylus replacement needles for my turntable and I am not getting the life out of these items, despite very limited play time. Seems like they just wear down...
What's the turntable? Skipping across the record would be a (mal)function of tracking and anti-skating. The recommended tracking force for this stylus os 3.0 grams. I've been out of the vinyl groove for some years now but I remember my Shure M95 tracking in the range of 1-1.5 g. Railroad spikes track at 3.0. Is this for 'scratching' or whatever it is they call that noise?
Apr 27, 2011 | Audio Players & Recorders
I have a Kenwood KD12R turntable. How do I set the arm and needle. I have a weight with an adjustable dial at the end of the arm and a separate anti skating dial on the base of the turntable? Regards -...
The weight should be set to the position recomended by the cartridge maker. Typically 1.5 to 2.5. If you don't know the makers setting, set it at 1.5 and work upwards. The stylus should track nicely in the record groove and not jump. But not too heavy as to cause rumble in the sound. Set the skate control low and again try the record out, if the stylus starts to skate accross the record increase the force. It's a case of experimentation with no fixed rules on these settings. Some records might need adjusments afterwards.
Feb 15, 2011 | Kenwood KD-291RC Turntable
All the arm does whenever I try to play a record is move across the record. This even happens with a brand new needle. I'm ready to get a new turntable.
there is a counter balance on the side of the arm called an anti skating weight.it prevents the grooves on the record from pushing the stylus inward,wearing out one side.when the anti skate weight system has a fault,it drags the arm toward the center of the record faster than needed.there is also a weight on the back of the arm.that is the balance.when set to zero,the arm should balance.then the weight is turned to 1 gram or so.if there is not enough force downward,the anti skate mechanism will drag the arm inward.
Oct 28, 2010 | Audio Players & Recorders
Stylus skates across record; doesn't engage grooves
Increase the weight of the arm, check if it has anti-skate control.
Dec 30, 2009 | Audio Players & Recorders
Had to replace stylus on SL-B2. Arm was "skating" across disc but seem to have that fixed. Sound definitely not correct. What can I adjust?
Hi sounds like the cartridge or stylus are not seated correctly or at correct angle (cartridge).
Also weight/balance and anti skate need adjustment. Try getting the manual and using that to set it up correctly - no easy task though as lotsa info there.... :) Manual for 1200 MK3 will do as well. Hope that helps
Jul 15, 2009 | Technics SL-1210 Turntable
Marantz TT221 turntable anti-skating problem
Hi, sounds more like tje stylus tip is gone and therefore the needle isn't holding to the grooves rather than a tracking weight or anti skate problem. Styluscity@gmail.com
Mar 27, 2008 | Marantz Reference TT-15S1 Turntable
Well on my technics MK2 1210's, the little anti sketch settings and all the others probably arent set to what they are supposed to be, because my needle arm keeps jumping :P could someone tell me what all...
There are two main things that will influence the anti skate settings.
1) The Headshell Weight and Balance
Firstly, check the data sheet for the cartridge and stylus you are using. It should tell you the correct weight setting which will vary from one cartridge and stylus to another. If the stylus is set too light, it can skate across the disc. This can damage the disc and the stylus. The sound will also be thin and it is likely to distort on high frequencies. If the weight is too heavy, it will not jump but will definitely damage the disc.
If you are a serious vinyl user, get yourself a tone arm balance. This is a device that you place on the turntable and you rest the stylus on a plate which is marked in micrograms. You place the stylus exactly at the correct weight marking and then make adjustments to the turntable settings until the tone arm is balanced. It's easier than it sounds!
If you don't have the data sheet for your cartridge and stylus and cannot find it online, use an old disc that you don't mind damaging, set the weight on the light side and gradually increase the weight until it stops skating.
2) Platter Levelling
Secondly, you need to make sure your turntable us on a level surface. If you are a purist, use a spirit level. to do this.
There are other things that can cause skating and jumping, especially if you use the turntable as a DJ. For example, vibration (caused hopefully by dozens rocking to your music). DJs will often increase the headshell weight very slightly to overcome this and I have sometimes placed the turntables on a thick rubber sheet such as carpet underlay to improve shock absorption.
Mar 26, 2008 | Technics SL-1200MK2 Turntable
Audio Technica AT-PL120 Turntable Logo
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Vito Vacirca Jr.
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
