Question about Plumbing
Water won`t come out of kitchen sink spout,sprayer works fine
    New Friend:
Is it an old faucet? Did it just happen all at once? More info is needed to know what to do.
Posted on Jan 08, 2013
What is the best kitchen sink faucet?
The name Comllen represents what is possible with today's plumbing technologies that are clean and efficient. I'm indicating the goodness of Comllen's kitchen faucets. The Comllen Pull-Down Sprayer Kitchen Faucet works to discover smarter ways for people to know and live with water. Every kitchen and bathroom are unique with high-quality technology, Comllen Pull-Down Sprayer Kitchen Faucet review will meet all the features of this technology, and your kitchen life will be simple and flexible by using this faucet.
The best kitchen faucets are operated with a single handle and high-arch spout as well as 360° rotation, durable brushed nickel material, and premium ceramic disc design. Comllen Stainless Steel Kitchen Faucet provides all the features to become the best kitchen faucet.
So, if I say, this one is the best.
Here is Comllen Pull Down Sprayer Kitchen Faucet review explains how to work with this faucet comfortably.
Apr 07, 2018 | Plumbing
Water is leaking around base of "spout" and
If you have properly replaced the diverter assembly, there is either a problem with valve or debris was left in the valve from old diverter when new diverter was installed. Disassemble diverter by pulling spout back off. remove new diverter and check valve. Cup your hand over faucet and turn cold water handle on to attempt to flush any debris left behind. Try several times then reassemble. If this doesn't do the trick then replace. Get a quality filtering system and take care of your new faucet by making sure it's dry and polished after use. You won't be replacing your fixtures as often from calcium and corrosion.
Apr 23, 2011 | American Standard 4271S 'The Standard...
New faucet in December - water barely comes out of spout - sprayer works fine
Remove the areator see if water comes out spout better if so clean out aerator they get limed up or get junk in it..
Apr 03, 2011 | Delta Faucet Signature Single Handle...
Water volume has been getting very slow
Could be a blockage in the valves and check any filters any where in line.some sinks in kitchen have a filter under sink and check valve to make sure they are opened all the way.
Apr 29, 2010 | Kohler Fort© Single Lever Handle Kitchen...
Faust sprayer doesn't work
The problem is probably in the floating valve that is located under the spout. This valve floats up and into the base of the faucet when you push the handle on the sprayer to use it. This redirects the water to the sprayer.
They get stuck and then don't close off the spout properly
Short of teraring the faucet clean apart they are almost impossible to fix. Turning the water off and disconnecting the supply hoses, then blowing air back through the faucet spout may dislodge whatever is in there. This has worked for me in the past... and it has not work also...
May be worth a try..
Heatman101
Dec 30, 2009 | Price Pfister Marielle Kitchen Faucet with...
No water passes from faucet to hand sprayer
try soaking it in some CLR calcium lime and rust remover .
Mar 15, 2009 | Kohler Model 10430: Fort® Single-control...
No water flow in kitchen sink
Sorry to say, you will need to replace that faucet, and also when you are shopping for a replacement, inquire about a rosette to cover the hole left by the voided sprayer.
Good luck...
Feb 24, 2009 | Home
Kitchen Faucet Replacement
Option 1 ; Cap off the sprayer.  Option 2 ; Relocate the air gap as high as possible under the sink but then you have no drain under it in case it backflows (it is really a vacuum breaker ,  one way check valve) Option 3: Take back the faucet and get one of those that the spout is also the sprayer.
Jan 30, 2009 | Danze D316440RBT Fairmont Two Handle Wall...
Kitchen spray not working completely.
Make sure the sprayer is clean of debris. IF YOU HAVE HARD WATER, soak in CLR overnight. If sprayer is clear then its the diverter which is more indepth thru the stem.
Phil
Oct 22, 2008 | Delta 2402 Classic Single Handle Kitchen...
Plumbing Logo
24 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
