Question about Frigidaire FTF530FS Front Load Washer
Used washer/dryer Frigidaire ftf530es/feq332es Problems?
I have to purchase a new washer & dryer. My friend has the above pair of Frigidaires for sale. Purchased in 2005 not used for the last year, stored in a garage. She says she has had no problems with them. Are they ok to buy used? What are the service issues? Can they stack on each other? I saw a few things in this form posed about the washer nothing about the dryer. New they seem to be anywhere from 550.00 to 800.00 each. Whats a fair used price? Any help will be greatly appreciated.
SOURCE: directions on stacking dryer on washer
get a stacking kit from your local appliance strore that sells frigidaire. they ARE EASY TO STACK WITH THE KIT.
Posted on Nov 16, 2007
  • 156 Answers
SOURCE: Purchasing a stackable dryer that fits on Kenmore/Frigidaire 417.44102300 washer
there still models out there from sears that go on the same way as the old one trust me i know 4 a fact
Posted on Mar 06, 2008
  • 876 Answers
SOURCE: need new washer to stack on my dryer!
measure your dryer carefully and check with the dealer where you wish to purchase a machine, regarding
the stacking kit. It may work. They are general standard sized. Don't ry to gerry rig anything or you may have big problems. In your case I recommend using a well known SMALL appliance store that does theri own installations, so they will bring what they may need, but if yours works, they can still use it.Good Luck
Posted on Aug 13, 2008
  • 750 Answers
SOURCE: stacking a frigidaire washer and dryer
This stacking part is all you need. It is a white plastic bracket that attaches from the rear of the two appliances. And it should have come with instruction too.
Posted on Dec 05, 2008
  • 61 Answers
SOURCE: Stacking Frigidaire Washer Dryers
no you do not need to put them on rollers. yes it would make it easier to service them but rollers would not be stable enough to keep the washr from shaking in spin cycle.
Posted on Jan 23, 2009
Ftf530es knocks during spin cycle
Good Afternoon Amy,
I understand that your Frigidaire washer, model# FTF530ES, knocks during the spin cycle. I also see that the drum moves from front to back and not up and down. I suggest making sure that your washer is level from front to back, side to side, and from corner to corner. If after leveling you washer, the drum is still moving from front to back, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your washer and determine why the drum is moving from front to back. Hope this is helpful.
-Best Regards-
May 15, 2014 | Frigidaire FTF530FS Front Load Washer
Good Morning Friend,
I understand that your Frigidaire washer, model# FTF530ES, is having trouble with the drum rocking back and forth, from front to back. I suggest making sure that your washer is level. I would check from front to back, side to side, as well as from corner to corner. If you have leveled your appliance and are still noticing the drum rocking from front to back I would suggest contacting your local authorized technician. Hope this is helpful.
-Best Regards-
I have a Frigidaire front loading washer, model FTF530FS3. The dryer that is stacked on top of it just quit. I have discovered that the new model of the dryer for this type, now called Affinity is slightly...
I would bet the manufacturer has an adapter for just this kind of problem. I did an installation on a stacked unit with a similar situation and there was an offset angle piece that attached the base of the dryer to the top of the washer. The front had a molded plastic piece to allow the dryer to rest on the front of the washer. Hope this helps
Oct 18, 2013 | Frigidaire FEQ332E Electric Dryer
Frigidaire FEQ332ES tumbles but does not heat up. Replaced the thermostat, did not solve the problem.
check ur breaker see if something is tripped dryer willl run on 120 but needs 240 to heat..
check ur element and also a thermal fuse, there might also be another thermosat that could be bad.
if gas check the ignitor, fuse, and thermostats
Feb 05, 2010 | Frigidaire FEQ332E Electric Dryer
Dryer problems
either the rear bearing or the idler is worn, my thoughts would be the rear bearing.
Sep 22, 2008 | Frigidaire FEQ332E Electric Dryer
Clothes Dryer in need of repair
if you look inside the drum can you see 3 screws? if you are mssing 2 then it will klunk.
Aug 06, 2008 | Frigidaire FEQ332E Electric Dryer
Ftf530Es;Frigidaire front load washer
did you check the filter? If the filter is plugged in the least bit it won't allow machine to spin at high speeds
Mar 08, 2008 | Frigidaire GLTF1670A Front Load Washer
Changing four prong dryer to three prong outlet
use the ground on the machine.....There are 3 wires on the terminal block if you notice there is a grounding strap off the center post this will act as your ground to the machine back in your panel box the center post leads to ground anyway the other 2 are hot leads (240vac) use the 3 post you will be fine. you will be grounded let me know if you have any problems
Feb 19, 2008 | Frigidaire FEQ332E Electric Dryer
Stacking Instructions
You will need a stacking kit 5303937141 to stack them, Feel free to ask for any more advice.
Nov 24, 2007 | Frigidaire FEQ332E Electric Dryer
Frigidaire FTF530FS Front Load Washer Logo
154 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
