Question about Cameras
How do i set aperture?
14 MegaPixels
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
What brand and model camera?
Posted on Jan 08, 2013
Where is the aperture ring on d80 Nikon
If you are using an older lens the aperture ring will be close to the camera body when the lens is on the camera. In order to set the aperture with a D80 and older lens you must set the aperture ring to "22" or the highest number on the aperture ring available. For newer lenses there is no aperture ring. You set the aperture by setting the dial on the top left of the D80 to "A" for Aperture Priority. You then set the aperture by rotating the front dial on the right side of the camera under the shutter release button. On older lenses, after setting the aperture ring to the highest number, you then set the aperture in the same manner.
Sep 22, 2014 | Nikon D80 Digital Camera with 18-135mm...
Tip
How does aperture setting affect a photograph?
The aperture is the opening in the lens through which light passes to the image sensor. Changing the aperture setting allows you to control the depth of field of a photograph. When the aperture is opened to a widersetting, (indicated by a lower f-stop number) more light is passed to the imagesensor, creating more shallow depth of field. Closing the aperture (indicatedby a higher f-stop number) allows less light to pass to the image sensor,creating wider depth of field.
NOTE: The aperture setting is one of three primary settings usedto control the overall exposure of a photograph. The other two primary settingsare ISO and shutter speed. Because the three settings work together to produce the overall exposure for a photograph, changingthe aperture setting will require complimentary changes to either the ISO or shutter speed to produce a properly exposed photograph. These changes will bemade automatically by the camera in the Auto, Program, Aperture-priority andShutter-priority modes.
There are two ways tocontrol the aperture setting on the camera:
  • Aperture-priority mode (A) - When shooting in Aperture priority mode (A), you set the aperture value and the camera automatically sets the optimum shutter speed for you.
  • Manual mode (M) - When shooting in Manual mode (M), you control both aperture and shutter speed, which gives you maximum creative control to achieve the exact results you want.
on Jan 08, 2011 | Cameras
Lock lens aperture ring at minimum aperture
Turn the aperture ring on the lens to its minimum setting (largest f/number). If there is an orange slide on or near the ring, slide it so that the aperture ring doesn't turn.
May 02, 2014 | Nikon D3000 10.2 Megapixels SLR Digital...
How do i change the apperture on my lumix g1?
Hi
I hope you're familiar with the Mode Dial, which is the dial with PASM on it. "A" stands for aperture and if you turn to that mode, you can then change the aperture by turning the (jagged) dial in front of your camera, on the hand grip. Here's a pic:8_3_2012_6_21_50_am.jpg
You can also change the aperture in "M", standing for manual mode.
Hope this helps!
May 01, 2010 | Panasonic Lumix DMC-G1K Digital Camera...
My pictures that I take outside are way too bright!
If you have access to the iso menu within the camera,lower the iso...ie iso 100 if possible.
If you have access to manual controls,
Raise the shutter speed and reduce the aperture to F8
If the camera has a reset setting within the menu, reset the camera to factory default....just in case something has been changed.
Nov 06, 2009 | Cameras
I want to set my Samsung s73 camera back to the factory settings.
You Can Change The Size Of The Picture By Clicking The +/- Button And There You Can Select The Size Used In The Memory For The Picture But You Cannot Change The MegaPixels Used Becase MegaPixels Just Mean The Quality Of The Picture
Mar 29, 2009 | Samsung Digimax S73 Digital Camera
What does it mean when FEE is in the view finder
FEE means that your lens is not set to the smallest aperture setting. If you are using your camera's auto-focus mode, the lens must be set to the smallest aperture setting which, on your lens, is probably f22 (the smallest aperture is the largest number). Once you set the lens aperture, you should slide the aperture lock to the locked position. The aperture lock is located just right of your largest setting f3.5. This slider should line up with the orange line. To verify that the latch is engaged, try to change the aperture by rotating the aperture ring. In the locked position, the ring will not turn.
Nov 28, 2008 | Nikon 2880AF F3.3-5.6G Zoom Nikkor,...
Blur on night sports pictures
You are probably going to need a faster lens to get pictures like you want, like around the 1.* range. If you have the ASA at 1600 and aperture at the minimum in Av mode, try and keep the exposure time to 1/focal distance. Such as, if you are shooting 200 mm lens then maximum exposure time is 1/200 second. If you zoom out a bit to 50 mm then it may look better too. You may as well turn the megapixels down too because otherwise you'll just see the blur even more, I'd suggest 3.2 megapixels that will look good in 4x6 photos or on the web. Other than that, try and take pictures where the action is coming at you or going away. Get as close as possible too, so that you don't have to zoom as much. At the H.S. football games I go to it seems like they let anyone down near the field who has a big lens.
Oct 15, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Why do my pictures look too dark?
You may need to use the flash. Make sure the setting is not flash off. If you're using the flash, make sure your subject is within the range of 14 feet for wide angle shots or 11 feet for telephoto shots. Use Image Expert to adjust the picture's brightness and contrast. Try adjusting the camera's exposure or sensitivity settings (use the Manual user mode). If you're taking pictures in the Manual user mode, look for the EV! warning that appears on your LCD screen when you are taking pictures out of the ideal exposure range. If you have trouble setting both the aperture and shutter speed manually, try adjusting the aperture and letting the camera choose the shutter speed with Aperture Priority mode. If you're using the macro mode to take a close-up photo, be sure to provide adequate lighting for your subject. If you're taking a picture at night and you want to light up the background as well as your subject, use the camera's slow synchronized flash mode. If you need more light, attach an optional external flash to the camera's hot shoe.
Sep 12, 2005 | Epson PhotoPC 3000Z Digital Camera
Cameras Logo
12 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
