Question about Xerox Phaser 7750DN Laser Printer
Can I just recharge my "Developer Housing Unit", or do I need to replace the whole thing? I found whereyou can buy the "recharger powder" for $85 but the complete developer housing unit is around $300
Let me explain my entire scenario.... My printer stopped working because it said on my LCD screen.... (ATC Cyan sensor..error code 14) I recently searched and found the service manual for my xerox 7750DN printer and it says to access the "Service Diagnostics" mode which I did and reset the error code. This allowed me to once again be able print with the printer but my Cyan is still messed up. The manual says to change the Engine Control Board or....change the Engine Control Board and the developer housing unit. I've changed the engine control board (at a very high cost...arrrgggg) and the cyan is still printing blotchy/messed up.
    Habit-Forming:
    New Friend:
  • 9 Answers
Yes you can "recharge" the developer. It involves removing the cyan developer assembly and replacing the cyan developer powder.
Posted on Apr 14, 2017
Loud toner error
The machine does not use the toner directly from the bottle, it goes thorught a developer chamber filled with developer powder. Then the toner is charged and can "jump" over to the latent image of the drum.
In this developer chamber, there are some small gears (2-3 tiny gears) that may be worn out. Some developer may have entered the "gearbox", and the deveoper powder is very abrasive.
The teeth of the gears will eventually stop to contact and mesh up. The internal parts of the developer changer stops to revolve, and there is no toner mixed with the developer.
You can see that there is a build up of toner, but it does not enter the developer unit. These gears have to be replaced, and I allways change the developer powder at the same time.
mp 2000 developer gears-2rhlv5r3sdqqpeuzs0ozcjtp-5-0.jpg These gears must be replaced it they are worn. The image shows a brand new part that contains the gears.
mp2000 developer toner input side-2rhlv5r3sdqqpeuzs0ozcjtp-5-1.jpg This is the side of the developer unit where toner enters the developer unit. With defective gears, the developer unit can not pull toner inside of the unit, and the toner builds up in front of the unit.
The gears are cheap, but will often result in the need of new developer powder - and that is expensive.
If print quality does not have to be too good, one can use the old powder and save money. Some of the powder is lost during use, and leaks. There may be some dust in the developer too.
In order to get high quality several parts may need to be replaced.
It is quick and easy to change these gears, just a bit dirty job.
Jun 24, 2017 | Ricoh Office Equipment & Supplies
C252 developer recharge
replace the developer for the color indicated replace the image unit,
Apr 26, 2014 | Konica Minolta Office Equipment & Supplies
Error 14 scanner
That sensor is located in the developer housing. You can either replace the sensor, or replace the developer housing, which comes with the sensor. Either way, you will need to go into diagnostics and set the value of the new ATC sensor after replacement. (You will need to replace the developer powder if you get a new developer housing)
Sep 19, 2013 | Xerox Phaser 7700 Laser Printer
Rm6252 refrigerator
cooland [freon] is not yellow it a gas tipe and most state you need a licent to buy it.
Feb 21, 2012 | Refrigerators
How to change developer beads
I have the complete 9 page instructions with images if you want I can e-mail them to you. Here is a snippet explaining just the portion of the beads. (email me at itsallnoise2me@gmail.com for complete instructions). Also, if you purchase the developer beads from iteminc.com they will include the instructions " 1. Place the developer housing assembly (new or used) to be recharged on a drop cloth. Caution During this procedure, the developer housing assembly must be kept level at all times. To prevent toner spillage, it is recommended that the developer housing assembly be fully supported level by laying it on something like a large piece of cloth, paper towels or styrofoam hollowed out for the developer housing assembly to lie on. If new, remove the protective cover over the magnetic roller. Do not touch the magnetic roller. Note The wires are routed under and behind the right snap tab. 2. Release the snap tabs at each end of the developer housing assembly and remove the assembly cover. 3. Agitate the package of developer mix and then cut it open. Carefully pour the entire contents of developer mix as evenly as possible over the two augers. Do not let the developer mix accumulate heavily on the roller. Keep the developer housing assembly level. 4. Reinstall the cover making sure that the rear tabs are all engaged in their respective slots while positioning the wire harness under the snap tab. Press firmly until you hear a positive "snap" sound for each tab indicating each snap tab is securely fastened. 5. Tear off the ATC sensor perforated tag. Do NOT remove the ATC sensor label from the developer housing.Peel off the protective backing, and adhere the label to the appropriate or corresponding Imaging Unit Plate. Make sure the ATC sensor tag label can be located if needed later. 6. Record the number for entering into NVRAM in the next step. 7. Perform the ATC Sensor Setup procedure."
Sep 13, 2011 | Xerox Phaser 7750DN Laser Printer
Batteries are not recharging. Where can I get replacements for Model EL1000 Pronto Vac?
Let me say this; The battery replacement for the Electrolux is not a owner level replacement procedure. However, you can replace the 4 original EMX1600sS batteries . The battery model is Tenergy 2/3A Size Rechargeable Battery 1.2V 1600mAh NiMH W/ Tabs Those are a little smaller than the originals but with the same capacity of 1600mAh and can be easily found in the web. Anything under those specs should work. These types of battery's will cost about $15.00 on the web. The battery's are in the hand held unit bottom or back side area, you access them by taking out all the screws in the back side of the hand unit.
Jan 15, 2011 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Need to recharge my mrl aed 20 batteries
It depends on how long it has been stored. I found that some batteries will not recharge after sitting for months. In my opinion, I would just replace them
May 12, 2010 | Welch Allyn Basic Aed 20 with Non...
Will accept calls can hear other party but anable to hear me .non rechargable have been mistakenly used
The units microphone is not working because of this issue with a non rechargable used this happens when oyu go and charge it, causes a backflow into the phones logistics making it unusable so you would need to ether buy a new handset or replace the whole unit.
Nov 10, 2009 | Philips Kala 6523 Cordless Phone
I am looking to purchase a AR-M455N, are there known problems?
Thats a very good copier which is fast and can be networked. Problems are those with other copiers so no need to worry.
Nov 10, 2009 | Sharp AR-M455N Copier
Xerox Phaser 7750DN Laser Printer Logo
53 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
