Question about Epson Stylus Pro 7600 InkJet Printer
Loading roll paper for an Epson 7600
It keeps telling me to reload paper
Remove paper, blow on the little window to the left of the bottom-right screw inside front cover...there's a sensor in there. I read this somewhere else, and it fixed my loading problems. Good luck!
Posted on Jun 07, 2013
3 Suggested Answers
  • 21 Answers
SOURCE: Reload Paper constantly shows up
This printer is very finicky about paper loading. I see this error most commonly when using auto-cut roll paper. If the paper edge is not cut perfectly straight, and it is not inserted into the printer perfectly strait, it will give you an error. When it does this, you can simply load the paper and press "cut" instead of "pause" when it says "press pause" and it will cut the paper straight. You can also set it to "Roll Paper Manual Cut" and load the paper, then set it back to "Roll Paper Auto Cut."
Posted on Mar 12, 2010
SOURCE: 9600 keeps telling me to RELOAD paper
just flick the paper lever up and down. dont fiddle
Posted on Jan 21, 2009
Error, paper out, when paper is loaded.
check there is the sensor cable is broken or the sensor is faulty.
Oct 12, 2014 | Epson WorkForce WF-2540 All-in-One Inkjet...
Flashing paper and power buttons
This error means jammed paper or a foreign object is blocking print head movement. Turn off the printer, press the adjust lever down to the lowest position, and pull out the jammed paper. Open the cover and remove any jammed or torn paper, or foreign objects. Then do one of the following:
Sheet Feeder: Return the adjust lever to the position. Turn on the printer, reload paper, and press the paper button.
Manual Feed Slot: See page 15 of your manual for loading instructions.
Roll Paper: Cut off the printed portion with scissors, then remove and reload the roll paper
Mar 08, 2014 | Unknown Epson Stylus Photo R2000 Ink Jet...
Using a Epson 7600. I send the job to the
1. The CR Encoder and the T Fence must be free from dust and dirt or any other
foreign matters.
2. The CR Timing Belt must be free from any defects and the belt must be in
proper tension.
3. The carriage must slide smoothly, free from undue load.
4. Measure the resistance value of the CR Motor. (5.8Ω)
5. Execute encoder checking by “Encoder ” in the selfdiagnostics
menu.
6. All the harness must be connected properly and free from short circuit or
broken wire.
Jan 07, 2010 | Epson Stylus Pro 7600 InkJet Printer
Our printer keeps telling us to load paper, although all ready loaded and will not print. even after attempts at reloading then pressing ok or even resetting the machine. Please help, we need it to print!...
please your printer in dumping roll is currently warking if no then changing the dumping roll and dumping pad is add new and the printer select to defold printer is currently ok.
Oct 21, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Maintenance required 0040
Turn off printer
Hold PAPER SOURCE+PAPER FEED+CUT/EJECT buttons at the same time and keep them pressed
Turn on printer
Release buttons
Hidden new menu appears
press DOWN, “CLEAR COUNTERS” option should appear
press RIGHT
press UP, “MAINT TANK” should appear
press RIGHT
press ENTER (CUT/EJECT button)
Turn off printer.
Jul 17, 2009 | Epson Stylus Pro 7600 InkJet Printer
Jun 30, 2009 | Epson Stylus Pro 10000 InkJet Printer
Epson Stylus Pro 7600 - Oversize Printing
Select the proper page size in the page setup dialogue box and again in the various print dialogue box sub menus. Also make sure your printer is selected and you are using the correct drivers.
If all of these things are in place you should get a long list of paper types in the pull down menu when you attempt to print.
May 11, 2009 | Epson Stylus Pro 7600 InkJet Printer
"reload paper" message
Lower paper sensor was completely dusty. Just blowed it and it works.
Apr 15, 2009 | Epson Stylus Pro 7600 InkJet Printer
Jan 16, 2009 | Epson Stylus Pro 9600 InkJet Printer
Epson Stylus Pro 7600 InkJet Printer Logo
105 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
