Question about Fluke Networks Fluke LinkRunner Pro LRPRO-KIT Network Multimeter Ext Test Kit
LinkRunner Pro Display is not working
I was using the LinkRunner Pro and it was working fine. I turned around and when I did my fingers accidently hit a button or a series of buttons. Now I get do display. I can turn it on and I know it is on and when I hit the power button the backlight comes on but still no display.
  • 683 Answers
Send back to Fluke for repair
Posted on Dec 24, 2016
Rheem pool heater, M406A, display has failed. It is only partially readable and has a dark spot inside it. Is the replacement part the PC board/controller? Is this a job for a savvy homeowner or call
The display is part of the pc board and it is very easy to replace. It is also fairly expensive part just to read the temp(around $400.00). If the heater works fine except for the display you can get by. Hit the up arrow button about thirty times this will ensure you have max'ed out the temperature at 104 degrees. From there with the down arrow you can count down to the desired temp. The mode button should work normally to turn the heater on or off as desired. This is obviously not the repair but it will buy time until you are prepared to replace it or have a technician out for another call.
Apr 12, 2014 | Rheem Pool & Spa
I have a Toshiba estudio 202L copier. It has been working fine. When I turn it on, I hear it turning on like usual and see the light come on under the paper tray, there are no error messages, display...
try formatting the HDD (make sure you backup templates and address book if you use them.) To format HDD hold 0 and 8 while turning on the copier, when the machine comes ready key in 690 and hit start. It will then display "2 2", hit start again. Wait for it to say please reboot the machine, turn it off and back on. Hopefully this will work but if not, your HDD will need replacing.
Jun 14, 2011 | Toshiba e-Studio 202L Copier
Have a euro-pro 9110 lcd screen lights up cant see the lettering ?
There should be a small round button on the front of the machine just big enough for your finger tip with lines around the outside like the rays of the sun or an eyelet.It should turn with the tip of your finger.Turn it back and forth for the desired light.If this dosent work you have a a bad display screen.
Feb 01, 2011 | Euro-Pro 9120 Computerized Sewing Machine
Possible Duo Pro issue?
duo pro stick failed not to be used
Mar 01, 2010 | Sony Cyber-shot DSC-W120 Digital Camera
Can't see "Setup" screen, or any other screens on t.v. monitor
There should be a tv vcr button on the remote control. What you done was you accidently shut off the VCR function. If you hit that button again the tv vcr button it will come back on.
Aug 11, 2009 | GoVideo Go Video DVD/VCR Combo
Canon A630 screen black
Turns out my husband must have pressed a button by accident. The bottom left button says "disp" for display. Pressing that fixed the screen!
Jun 24, 2009 | Canon PowerShot A630 Digital Camera
Euro-pro iron steam genarator model # ep8001
I have a temporary solution that is working: Use WD-40 around the switch. Spray with the straw that comes with the WD-40. Let stand for a couple days, then turn the whole unit upside down and spray again, and let it stand that way for a couple days. If we could get inside, it could be more of a sure thing, but I had given up on mine and when I accidently hit the switch after siting for the last few days, , it came on!
Now for Sears to try to locate the tool that will open the case.
Apr 17, 2008 | Euro-Pro Steam Generator EP8001 Iron
My Pro-96 Suddenly Doesn't Pick Up Transmissions
on scan mode press (man) for manual then pgm then trunk. screen should read not trunked press mode. if it does say that then press scan, and it should work. but if it doesn't say not trunked then press mode until it does say not trunked, then press scan. should work.
Nov 23, 2007 | Radio Shack Pro-96 Scanner
Display 'video 1' stays on all the time
There is a "Display" button on your Sony remote that turns the display ( Video 1,2,3 etc) off and on , you probably hit it by accident like I did.
Nov 14, 2006 | Sony KP-53V90 53" Rear Projection...
Fluke Networks Fluke LinkRunner Pro LRPRO-KIT Network Multimeter Ext Test Kit Logo
161 people viewed this question
Top Fluke Networks Measuring Tools & Sensors Experts
Vuk B
Trevor Turner
joseph m fucci
joseph m fucci
Level 1 Expert
Are you a Fluke Networks Measuring Tool and Sensor Expert? Answer questions, earn points and help others
