Question about SmartDisk 250GB SMARTDISK CROSSFIRE EXT Hard Drive
Can't copy large files onto my external harddrive
When i try to copy large files (7+GB) i get an error message telling me the file is too large for the destination file system. There is over 200GB of free space on the hard drive, so space is not the issue. Thanks.
  • SmartDisk Master
  • 27,725 Answers
What format is the external drive ?
you might need to split the file with rar
I recently downloaded win 8 5gb had it split with rar into 2 files downloaded with IDM trial
The FAT32 format does not support single files larger than 5GB, so if you have a file larger than 5GB you cannot put it on your FAT32 thumb drive. Most thumb drives and other portable media devices use FAT32 format, so this setback makes large files less portable, and that just won't do. Get around this problem by compressing the of the file or by splitting the file up into multiple pieces.
Create a folder for your RAR file and insert a copy of the original file into this folder. RARing a file separates it into multiple pieces, so creating a file specifically for your RAR file will keep the files together allowing you to move one folder to your FAT32 device instead of having to locate and move multiple files. Right click the large file that you want to put on a FAT32 device. Select "Add to archive" from the menu that appears to the side. Select "RAR" from the "Archive Format" located to the left of the menu. Click the arrow next to "Split by volume, bytes," and select "CD 700: 700mb." This will create a new file for every 700mbs, meaning your your one large file will be separated into many 700mb files that can be put back together as a single file later. Click "OK." Put the folder, containing your newly separated files, onto your FAT32 device after WinRAR has finished separating the file. b> Zip File b> Right click the large file you want to put on a FAT32 device. Select "Add to archive" from the menu that appears to the side of the file. Click "OK" on the next menu. This menu allows you to customize the compression settings. The only option you need to change is the "RAR" selection to "ZIP" in the "Archive Format." The rest of the default settings will work fine, so there's no need to change anything else. The zipped file will appear in the same folder as the original. Delete the copy of the original large file from the folder and put your newly compressed file on your FAT32 device after the file has completely compressed. The time it takes for the file to finish compressing depends on the of the file. Hope this helps. http://www.all-freeware.com/getfreeware.html?pid=109090&mirror=1
b>
Posted on Jan 09, 2013
3 Suggested Answers
SOURCE: Smartdisk PB40 reports 0.8 Gb space, Windows Vista reports 37,2 G
once you have deleted the SmartDisk folders, try going to the desktop and dumping the "recycle bin" there as well
Posted on Mar 04, 2010
  • 72 Answers
SOURCE: My SmartDisk FireLite external hard drive is
I believe some virus caught your computer. If you can't find you're files try this.
-Go to that hard disk.
-In the menu bar look for tools.
-Folder option
-In the folder option window click view
-look for hidden files and folders
-In the 2 radio buttons click show hidden files and folders
-click apply.
If this is correct there is a way to remove those hidden things.
-Select the file or folder you wish to not hide.
-right click and look for properties
-unchecked hidden files and apply
hope this helps. Thank you for using Fixya!
Posted on Apr 19, 2011
7.9 gb file too large for empty 16 gb flash drive
U probalby is using windows XP or something like that wich can only format ur pendrive as "FAT" file system wich have max 4GB capacity per file, in order to fix your problem you need an external software for formating ur pendrive or use win 7 if you have win 7 just backup your data and format the pendriver and where it says " File system" will come with "FAT" as standard just click and select "NTFS" format it and be happy^^
Nov 12, 2012 | Computers & Internet
File size limit for Buffalo HD 250 GB Hard Drive backup
The file is too large meaning that the size of that SINGLE file is too large. Your hard disk is probably formatted to a FAT32 file system, this results in a maximum of 4gb PER FILE maximum transfer. What you could do is archive it into a few parts using winrar and then moving it onto the disk, and when you need the file just extract the archive. Your problem isn't the total free space, it's the size of that file chunk.
Nov 03, 2012 | Buffalo Technology 250GB USB SATA 2.0 HD...
I'm Windows XP... I can copy many files to the Verbatim. But when I try to copy a 1GB+ file, the copy craps out. I Googled and found some Microsoft problem when copying 1GB+ files to external drives, but...
The usual limit is exactly 2GB, not 1GB.
It's a limitation of the file-system used for the directory of the disk-drive, when formatted according to the 'FAT32' specifications.
So, copy all the files currently on the Verbatim to your disk-drive.
Then, "reformat" the external (not the "internal") disk-drive, using the 'NTFS' file-system. This file-system has a maximum-file-size limitation for one file that is _much_ larger than the capacity of your Verbatim.
Then, copy all the "saved" files back onto the Verbatim.
Finally, copy your "large" files onto the Verbatim.
Sep 30, 2010 | Verbatim 500GB USB Desktop 500 GB Hard...
Copied files to a folder on portable harddrive
1. Try creating another folder and coping the content from the original to the new folder on the USB drive.
You may have stopped the coping process inadvertently during the copy process.
Apr 07, 2010 | Toshiba 120GB USB 2.0 Portable External...
Copied files disappeared as soon as they were copied over
Did you try to copy one picture file to your mini harddrive then change it properties to archieve only? After that you can rotate it freely without that annoying message.
If that does not go as expected. Could be virus infection. Both your miniharddrive and your computer is infected. Some do it by changing it properties to read only then hide it.
You should first start disinfecting. The files can be view by clicking tools in My computer then set to view hidden files then start exploring your minihard drive. Some infection only affects picture files.
Just for the thought.
Apr 13, 2009 | Maxtor 160GB OneTouch III Mini USB 2.0...
Cannot copy large files onto my WD passport
Your drive is probably in FAT32 format.  FAT32 has a 4GB file limit that is why your 5GB movie isn't saving.  You will have to format the drive in Mac OS file format (HFS) using Disk Utility.
Unfortunately once its in Mac format the drive will not be recognized by windows PCs.  What I do is have a program called macdrive installed on my windows computers so that they can access mac format hard drives.
i hope this helps!
Nov 13, 2008 | Western Digital Passport WDXML800UE...
221 GB Free on MyBook - Error states not enough space for backup
It may be due to the file system.  If formated as FAT32 files larger than 4gb may not transfer.  Try reformatting as NTFS to fix the problem.
Sep 21, 2008 | Western Digital 250GB MyBook External USB...
Lacie 320 GB Hard Drive acting as if full when it's not.
Simplest solution: back up the data on the drive and repartition it (which will wipe it). Otherwise it sounds like it could be a problem with the file tree or structure of the drive, the configuration files could be corrupt, some program could have stored temporary files in a hidden place that cannot be deleted without making the program delete them, etc. If you are on a mac, spotlight Disk Utility and use it to repartition. If you are on a PC use the search thing from the start menu and find a program called disk management (or something similar to that, you'll know it when you see it.) external drives are annoying. i kick mine into the wall periodically for good measure.
Mar 22, 2008 | LaCie (300950) 400 GB Hard Drive
Free space availabilities
Is it formatted as FAT32? If so, it doesn't support files larger than 4GB.
Backup the files you have on it, then reformat as NTFS.
Jan 16, 2008 | Freecom (24358) 160 GB Network Hard Drive
Open Questions:
Toshiba Laptop doesn't start up. Black screen [Solved] -Dataalign Toshiba as a brand has continued living up to the expectations of its customer for nearly three decades now, by maintaining the high quality of its products with the help of delivering a combination of useful software and attractive hardware in a package, which is required for providing the needed technological expertise. With laptops becoming an indispensable and integral parts of our lives, it is important that companies today equip their laptops with all the advanced technologies along with a sleek and stylish design for that attractive feature that would add to its plus point. Our Toshiba technical support team members are available all the time on our Toshiba Support number +1 888 784-9316 and are highly adequate in resolving issues related to Toshiba printers. The fact that everyone today knows about Toshiba Support brand and most people who have tried Toshiba products like them, makes them one of the most reliable in case of printers especially. Toshiba makes business portable laptops, with highly durable features of being sturdy and long- lasting for use in all walks of life. Most laptop owners would agree to the fact that Toshiba products are designed to provide quality portable solutions and highly acclaimed for their bullet-proof build value. But with time, users might face issues with Toshiba Customer Care like any other laptop band and these issues can be prevented from causing any severe damage to the laptop by accessing resolution from our technically specialized team members, who are available on our +1 888 784-9316. Issues faced by Toshiba customers: Toshiba Backup BIOS update issues Slow Performance Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Windows 10 upgrade issues Computer Tune-up Issues Virus Removal Issues Data Backup, Transfer and retention issues All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact- +1 888 784-9316.
Jun 23, 2018 | Toshiba Computers & Internet
Can I hold DHHS accountable for the burden they put upon me? If not, is there someone that can be held accountable? What can I logically and honestly do to remedy this prob. I explained my prob below! I was getting QMB part of Mainecare and my spouse at the time we were dating but living together was getting the QI part of Mainecare. We are both disabled and only get SSDI. However being honest and do our best to always do the right thing we go to DHHS office on Griffin RD in Bangor, ME within a month of us getting married where the worker we saw tells us we don't qualify for anything but the min of FS and both Q1 part of Mainecare and serious voice tells us to divorce. I have made a few trips within last months to same DHHS. One sends us to Eastern Area of Aging to see if there were secondaries we can get. This past Monday hubby and I went to our appt with Eastern Area of Aging & was told they strongly believe I could get spousal exclusion also warning it could mean my hubby loses help but because it was a volunteer a newer one at that she couldn't tell me definitely cause she didn't know the formula as she still learning; tells us to go back to DHHS to ask about spousal exclusion. So I go back to DHHS this past Thurs and got a worker with more smarts, heart with approx 10 yrs working for DHHS tells me I qualify for spousal exclusion and took the time to answer all my questions. I told her I had QMB till hubby and I married June 2016 & shared with her what the DHHS worker told us when hubby and I went in to show marriage certificate to update the change. She looked at me with shocked eyes and dropped jaw in bewilderment. Then says I would of never lost it as I would of qualified for spousal exclusion from the day we married. And had it been her that we got when we were being honest wouldn't have only told me about spousal exclusion but would of applied me as she could see I have major medical problems that is too much a financial burden for my hubby and I. She also told me I was to submit all unpaid bills even if monthly making payments were being made. I thought I was only to submit bills I paid in full or on a payment plan. So started Thurs night on a Medical Bills Tracker to go through all the medical bills and sort things out. I haven't even put a dent in the pile and see I'm responsible for just over 6K I'm predicting once done I could be closer, if not over, 10K. In collections is currently 1K but once done with pile amount in collections could be closer to 2K or more. So the mess has impacted my credit and if things were done by professionals I wouldn't be losing my hair stressing over my medical bills and how it declines my credit. I know I'm in a small group that actually pay their medical bills any and all bills to be honest! I am disabled and get SSDI. Worked 1992-2013 a lot of times working 2 jobs! Dr in 2013 practically dragged me out of work as was just diagnosed with Hep C, CKD Stage 3 & liver disease! I also have depression disorder, panic attacks, anxiety disorder! So even this incompetent DHHS worker putting extra financial burden on me unnecessarily affects those things. I am trying to do the right thing but get kicked down by the very people that are paid to help me. What are my rights and can I fix this at a faster pace then not even fixed it by the day I die?
Jun 23, 2018 | Major Computers & Internet
See all SmartDisk 250GB SMARTDISK CROSSFIRE EXT Hard Drive Questions
SmartDisk 250GB SMARTDISK CROSSFIRE EXT Hard Drive Logo
355 people viewed this question
Top SmartDisk Computers & Internet Experts
Sunday Ojelabi
Sunday Ojelabi
 Ian Kayhan
Ian Kayhan
Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
