Question about Jensen Vm9224 Car Video Player
How do i access the hidden menu on the Jensen VM9224 model that comes WITHOUT a remote?
I am aware that i can just ground the parking brake wire but the harness for that is currently damaged and not connected so all i can do now is just listen to music.
3 Suggested Answers
j_del
  • 1586 Answers
SOURCE: JENSEN VM9311TS DO I HAVE TO HOOK THE BRAKE WIRE UP AT ALL?
There isn't any code that I know of. Most DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On mine, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Posted on Aug 01, 2008
  • 32 Answers
SOURCE: parking brake on a phase linear uv8
pulll the unit out there will be a wire marked park brake or most likly pink (remeber coming from the head unit ) next splice it in to the black wire or to a ground
Posted on Jun 03, 2009
This question is still unanswered to this day, Does anyone know for POSITIVE how to cure the parking brake issue on the Jensen VM9224BT?
The Pink wire is negatively switched wire in the green plug, this should be cut and it should function all the time it's on.
So when you put the brake on it grounds that wire and shuts the screen off (safety)
If that doesn't work it will be switched by applied 12v.
I haven't looked at what other solutions say, that's just what I see from the diagram
http://audiovox2.info/docs/common/VM9224BT/VM9224BT_IM.pdf
any problems get back to me and i'll try to help out.
May 09, 2012 | Jensen Vm9224 Car Video Player
My jensen vm9324 plays dvds but the monitor does not come on, it has the warning screen
Your "Emergency Parking" wire is disconnected. You need to connect it to your parking brake, or you can also connect it to Parking switch if you have automatic transmission. You can play video only when parked
There is a workaround though...
Warning: In most states in US law bill bans drivers from operating televisions and video screens in their line of vision while the vehicle is moving.
Due to the law you can use this workaround at your own risk:
1. You can just ground the parking brake wire to your radio, and you are done.
OR
2. You can adjust factory settings
  • Go to""Setup", and then to "Screen" menu
  • with your remote press 543210, this will show a hidden menu
  • now set the parking brake menu from "off" to "on".and exit the menu
  • NOTE: disconnecting the car battery will reset the code to default "off" state.
MPB
Jan 23, 2011 | Audiovox Jensen VM9324 2 DIN 6.2"...
Video willnot play
there is a brake overide option in the serive menu that you can enable that will allow you to view videos while in motion. without having to connect the parking brake wire of the screen. just follow these directions
you will need the remote control2.gif to do so.
1.turn the radio on and select the setup menu.
2. while in the setup menu, use the remote and press 5-4-3-2-1-0, this should access another service menu.
3. from there, you will see a brake override option.
4. and your done.. hope this helps
Sep 13, 2009 | Jensen VM9510 Car DVD Player
Parking brake disable model jensen 9511ts
on the jensens, there is a way to disable the parking brake without having to put a switch on the parking brake wire. the catch is that you will need the remote control to get into the service menu. follow these steps
if for any reason yours doesnt offer this option. you can always put a switch on the ebrake wire of the screen.
1. use a 2 wire toggle and wire one side the ground and the other to the parking brake wire on the jensen. then do the pattern on the switch instead of using your ebrake.
Aug 28, 2009 | Jensen Car Audio & Video
Bypass the parking brake on the vm9022
Jul 16, 2008 | Jensen VM9510 Car DVD Player
JENSON VM9512 CODES FOR BRAKE BYPASS
turn on the player, start the radio option, go into the setup menu, tap the language tab, ON THE REMOTE press "stop, stop, 5,4,3,2,1" This will bring up the secret menu, you do not need to connect the pink wire
Mar 10, 2008 | Audiovox VM9512 Car DVD Player
Jensen in dash dvd monitors
jensen double din dvd monitor it a uv8020 model to bypass the e brake or parking brake
Dec 19, 2007 | Jensen VM9510 Car DVD Player
I need toby past e brake
on your remote control press 1 2 3 4 and then press and hold the number five until the hidden menu appears
there is an option to by pass the brake
David
Dec 07, 2007 | Jensen VM9510 Car DVD Player
How do i bypass the parking brake switch in order for my video to play
isn\'t there a way to bypass the parking brake so my video plays anytime i want
Dec 15, 2006 | Jensen VM9510 Car DVD Player
Jensen Vm9224 Car Video Player Logo
44 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
