Question about NEC-Mitsubishi Nec Display Solutions MultiSync LCD4610 46 in. HDTV-Ready Television
Replace screen I am trying to relace a screen on a 52 inch Mitsubishi T.V. and cannot get the old one off. Any ideas would be appreciated. Thank You Rick Hatfield
    Novelist:
  • 192 Answers
Without a model number the following may not be correct, but, since most rear projection televisions (Not DLP or LCD) are: Pull off the speaker grill. There is two sets of wires coming from the screen going to the inside of the set through the access door (4 screws). Sometimes the plugs for these wires are on the outside of the access door and sometimes they are inside of it. Follow the wires. Unplug them. Usually 5 screws are attached to the bottom of the screen, remove them. Slide the screen up a bit and pull foward. Screen is removed. Look at the way the screens are attached to each other and assemble them in that same exact way. If you don't then the picture will be dark. Normally screens have a sticker on them in one of the corners, put the screen back with the sticker in the same place. When replacing screens, use as clean as enviorment as possible. Pet hair getting in between them will show when the set is turned on. We use surgical gloves when touching screens since getting finger prints off of them is nearly impossible. This job can be done by one person, but, it is best done with two people. This concludes my tutorial on screen replacement.
Posted on Jul 01, 2007
Need help with mitsubishi tv lamp relacement - it says replacement - the tv is only 4 years old - how do I know I have to replace the lamo
There is usually a hours lamp counter somewhere in the menu. When you push your luck, the lamp use too much, then draw much more current, then after a while the ballast broke and it cost around 4-500$. (when there available). Let us know if you find the hour counter!
Oct 09, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD 52525 blue screen on all inputs
Hi and welcome to fixya, it is the colour wheel problem,,,,,,,,,this is common problem please check it ...it may be also cathode ray tube... thank u.........
Jun 03, 2009 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525
You have a bad DM Board. You need to replace it. Changing the capacitors will not cure the problem. Completely replace the entire board
May 26, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Tried to replace bulb
Is this the part number you are using?
Mitsubishi 915P020010 Lamp
maybe you need to replace lamp ballast
Mitsubishi 939P978010 Pwb-pwr Lamp Rmd (V26/26++/vk26)
Apr 05, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Blinking green timer light on mitsubishi wd 52525
disconnect the connector for the front switch control board. Try turning it on with the remote. If it works replace that board, also look for bad caps on the small signal board. they're 1000Mf 16v
Mar 22, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Spot on the screen
This problem is covered by Mitsubishi even out of warranty.
Jan 14, 2009 | Mitsubishi LT-52144 52 in. LCD HDTV
52 inch Hitachi rear projection HDTV. No picture. Just vertical colored lines.
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 15, 2017 | Mitsubishi WD-52525 52" Rear Projection...
RCA 52-inch (rear projection) big screen television
Your are welcome. Just fyi, you can post comments to problems even after a solution is posted. FixYa then notifies the expert of the new comment.
Thank you for your appreciation!
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
Mitsubishi WD-52628 52" Inputs look like old cable scrambled channels
Change the 1000uf @16v capacitors on the FMT board that should solve your problem. You will most likely found that they have swelled. Let me know if you need further info.
Apr 04, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Purple and Blue Spots on Screen on Mitsubishi WD52527 52 Inch HDTV
It could be only dust building up and it needs a good cleaning or it could be the DMD board is going bad and needs to be replaced.
Mar 23, 2008 | Mitsubishi WD52527 52" Projection HDTV
Open Questions:
NEC-Mitsubishi Nec Display Solutions MultiSync LCD4610 46 in. HDTV-Ready Television Logo
446 people viewed this question
Top NEC-Mitsubishi Televison & Video Experts
Marvin
Marvin
Are you a NEC-Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
