Question about Ricoh Office Equipment & Supplies
Savin c2824 keeps asking to replace black toner
Savin C2824 keeps asking to add black toner. The toner bottle is full. What can be causing this problem?
Set key counter
Go into user tools and turn it off.
Jul 14, 2014 | Savin C4535 C3528 C2824 Toner Set 4 Colors...
Savin C2824 Toner roller marks on blank side of color copies
dust from cartridge builds up inside machine. you can clean it up with a small paint brush and some canned air .
Jun 27, 2012 | Savin Office Equipment & Supplies
Savin c2824 wont print pdf files
If its showing drivers for a different machine then the first step should always be to completely remove and reinstall the drivers for the correct unit.
Mar 02, 2012 | Savin Office Equipment & Supplies
Waste toner is almost full on Savin C9020
The bottom left portion of the display gave the error message:
Waste Toner Bottle 1 Almost Full. Please call service.
They were still able to print, however this message would not go away.
To Fix:
Power down the printer using the normal shutdown method.
Open the top front door.
Remove the cover directly below the 4 toner cartridges.
The removable cover below the toner cartridges is actually the Waste Toner Bottle.
Bring this to the dumpster.
There is a round, clear-plastic tab on the underside of the "bottle". Remove this.
Shake the bottle around over the dumpster. Continue until all the toner has been removed.
Push the clear plastic tab back in place. Wipe off all toner residue before putting it back into the printer.
Put the waste toner bottle back into place. Power on the Savin. Confirm the message no longer appears and that users are able to print.
Feb 08, 2012 | Savin Office Equipment & Supplies
What is the user code for a c2824 model copier?
it is a series of numbers set up by an administrator used to allow access to the copier functions
Nov 29, 2011 | Savin Office Equipment & Supplies
Toner light and message won't go out
Hello sir; You have to replace toner senser, it located at the bottom of developer unit. have any problem please contact us, good luck!
Jul 15, 2010 | Savin Office Equipment & Supplies
Savin Copier 3515
Hmmm.. try this
  1. Open the Front Cover
  2. Lift the large green handle up to its full extent
  3. Press and hold down the green lever to the left of the green handle
  4. Use the green handle to pull out the Toner Tray slightly then release the green lever
  5. Pull out the Toner Tray to its full extent
  6. Push the toner bottle towards the front of the black housing where the green lever is located
  7. Push the green lever down while continuing to hold the toner bottle towards it.
  8. Slide the whole assembly back into the device until it clicks into place
  9. Close the Front Cover
  10. The device should now attempt to Add Toner
  11. If the Add Toner indicator light does not go out repeat
Oct 31, 2008 | Microsoft Office 2003 Basic Edition...
Ricoh 1018d won't add toner after installing toner bottle.
the part numbers are different for each toner from ricoh, Lanier, Savin and Gestetner. From what I recall is the bottles are different, check the old bottle vs new. Also if the machine had run very low you may have to open and close the fron cover several times, this intiates a toner feed program.
www.p4photel.com
http://www.websitetoolbox.com/tool/mb/copierquestions
Feb 26, 2008 | Ricoh Aficio 1018D All-In-One Laser...
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
