Question about RoadPro AC/DC Power Inverter 2000/5000w
Can't get power to my RoadPro 1500 DC to AC Power Inverter
I have a RoadPro 1500 DC to AC Power Inverter in my tractor trailer and have become very dependent on it. It came with the truck I bought and worked fine for approximately 3 months. Now when I try to turn it on all I get is the red fault light. Can you suggest a cure? Thanks! Dave
  • Anonymous Mar 20, 2014
    when I plug it into my truck and turn it on the red light flashes while green light stays lit
    Problem Solver:
  • 9 Answers
I have had this same problem with several power inverters over time. The problem is usually one of three things.
Those starting with the simplest.
1. Too much current being drawn on the inverter.
Solution (Check appliances that are plugged in and make sure they are not drawing more than 1200 watts. If they are unplug the appliance that is using the most current and get an inverter that is more suited to your power needs.)
2. Some power inverters have fuses built on to them. Sometimes multiple fuses. Sometimes, one fuse may burn out leaving one intact. When this happens even small items draw too much current and over load the inverter.
Solution (Replace the fuses)
3. Improper installation. Inverters draw a lot of current. You must use the propper wire size for the inverter. I would recomend at least an eight guage wire directly fused and hooked directly to the battery. Of course like with all things the bigger the wire the better the flow of electricity.
If it is not one of those things stop into a truck stop electronics shop and have the person diagnose it.
Hope that helps.
Posted on Jan 21, 2009
What is the brown wire and blue wire for the power cord on roadpro100w
I would guess the blue is POSITIVE, and goes to the tip of the lighter plug. However, get a voltmeter and check...
Cheers.
Dec 21, 2017 | RoadPro Road Pro AC / DC Power Inverter...
THE RED FAULT LIGT IS ON AND IS ONLY WORKING AT PART POWER.
it has grounded out on you inside of your converter,Replace it.
Jan 21, 2011 | RoadPro 1500 Watt DC to AC Inverter
Getting fault light, what can I do? road pro 1500 watt inverter
Check the Following:
  1. Ground from inverter to frame is intact
  2. Positive leads are intact and clean
  3. Negative leads are intact and clean.
I hope this of help to you please rate if the answer is of any help. If I can help any further will be glad to. Good Luck and have a great weekend.
Apr 03, 2010 | RoadPro AC/DC Power Inverter 2000/5000w
Trying to find out what gauge of wire i need for a 1500 watt roadpro inverter to wire to batteries of a semi
At 12 volts DC it will pull 125 amps at full load of 1500 Watts.This requires at least #2 copper AWG
Jul 15, 2009 | RoadPro Electronics - Others
Green and red light are blinking on roadpro 300 power inverter
if the inverter is working and the fan is just starting and stopping the fan must be bad, but if it is not supplying power the inverter control is bad
May 11, 2009 | RoadPro AC/DC Power Inverter 80/100w
RoadPro AC/DC Power Inverter 2000/5000w Logo
618 people viewed this question
Top RoadPro Electronics - Others Experts
Craig Butler
Craig Butler
jdthefixer
Are you a RoadPro Electronics - Other Expert? Answer questions, earn points and help others
