Question about Car Audio & Video
Philips rc 169 manual - Car Audio & Video
Hi i need a code for my radio 22 RC 465/35S
your code is 6233
ukradiocode@mail.com
Dec 24, 2012 | Car Audio & Video
Philips MCD716
1.Press DVD "OPEN/CLOSE" key (RC (remote Control) or main unit) to open the DVD tray (note:if no disc on tray,then you have not to open it);
2.Press RC "SYSTEM" key to enter DVD system setup menu;
3.Press RC "direction "key to hightlight the forth item "PREFERENCE PAGE" (not entering the sub-item );
4.Press RC numeric key sequentially 811502(enter code, however no display on TV);
5.Press RC "down direction" or "up direction" key to change REGION CODE,"0" is all code.
6.Press RC "OK" key to confirm.
7.Press RC "SYSTEM" key to exit DVD system setup menu
Nov 23, 2008 | Televison & Video
Phillips dect2152
If you bought the base and handset together they should already be registered. If not then the instruction manual is downloadable here: MANUAL
The relevant section is on page 16 - here is a copy:
4 handsets can be registered to the base station. A handset
can only be associated with 1 base station.
�� To register another handset
First enter registration mode by unplugging and
plugging back in the power adapter to the
electricity supply.
Handsets registering / unregistering ( )
�� To unregister the handset you use
enter the RC code*
�� To unregister all the handsets (except the handset you are using)
enter the RC code*
Once the menu is selected, enter the RC* code written under the base and press
to confirm.
Warning : If you wish to associate a non-Philips handset to the DECT 211 or DECT 215 base
stations, make sure that these handsets are GAP compliant otherwise they will not operate properly.
*RC code
(Registration
Code) is
written under
the base.
Warning : Once unregistered, the handset is no longer operational.
Please rate my assistance this should be a fixya!
Mar 29, 2008 | Philips DECT 2151 Cordless Phone
PHLIPS KALA VOX 300 PHONE TUNE IN EXTENSIONS
You have to de-register all your handsets from the old base unit with the old base unit's RC first before then re-registering them with the new base unit with its new (presumably different) RC. See the manual for details on how to do this - other posters have put links such as http://www.viking-direct.co.uk/speciallinks/gb/vkg/source/KALA300range.pdf where you can download the manual.
Jan 18, 2008 | Lands Phones
Car Audio & Video Logo
90 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
