Do you mean that it wont turn on at all or that it will not boot into Windows.
Try the following ...
Remove the battery and leave the power supply plugged in and try.
Borrow/buy a new/generic power supply see if thats the issue - no power
If you mean windows wont boot successfully you may need to find someone to reinstall Windows on your laptop from the recovery disks/partition
SOURCE: how do i restore to
If you do not have a restore disc order one before doing this so important. Go to the Toshiba support page at Click Here their products all come with a downloadable restore disc or you can order one for your computer. I hope that this assisted you. Thanks for using FixYa! John
SOURCE: My drop down function key
if this function works on on-screen keyboard then it has nothing to do on your software or operating system, your keyboard is the problem. Your can spray it with a contact cleaner or if that doesn't work at all you can replace the keyboard with a new one.
SOURCE: Can I Download toshiba satellite C660 driver?
Here is the link.
http://www.all-driver.com/notebook-driver/toshiba-satellite-c660-drivers.html
you can download all the drivers you need for you laptop for Windows XP and Windows 7 Operating System.
Goodluck Hope i help you. Please rate my solution. Thanks.
SOURCE: Satellite C660-2DL won't turn on
Toshiba Satellite PC Notebook will not turn ON:---For this problem click the link below:---http://howtobyme.blogspot.in/2012/02/toshiba-satellite-notebook.html
---------This will help.Thanks.
Hi There,
There are currently no easy ways to update a bios through linux at all - including live cd's. Your best bet is to make a bios update USB stick (or floppy depending on the age of the computer)
Here's a link to those instructions:
http://www.biosflash.com/e/bios-boot-usb-stick.htm
Alternatively, speaking from my own experience with a similar situation, you can take the hard drive out, use it in place of the usb stick, boot from it, update your bios, and go from there.
Testimonial: "Matt, exactly what I have been searching for, I am well advanced in years so will take me a while to configure this, I found the update OK but was a problem choosing the utility. WELL DONE & MANY THANKS Jim"
