Question about GE Profile WPRE6100G Top Load Washer
Ge profile wpreg100g will not agitate will not spin
The washer will not agitate or spin. When moving the agitator by hand, it will move in one direction, but will not move in the other direction. I believe this eliminates a few problems.
  • karen resto Jan 08, 2013
    SO: we have discovered that there should be a blinking light that would give you codes to problems. Our light was not on at all. After testing the fuse with an ohm meter, we found it is not the fuse. Do we assume it is the motor? (Before the LED light check, we checked the magnetic switch which had connectivity. It did not appear to be an agitator problem, so we moved on and found out about the LED. Any other suggestions? At $200 for a new motor, we are ready to junk it and just get a new machine.
step7dad
SOURCE: GE Washer Model WJSR2080V3WW Agitates, Pumps, but will not Spin
I solved the mystery of the non spinning washing machine by GE. I pulled the agitator off and to my horror was a broken " hub". This the part in the middle of the basket under the agitator. The transmission shaft comes up through the center of it. Any way, it was severely broken and wedged in so it would not spin. Not sure if this is the only problem but I am going to buy a new machine. I can not get it unbolted to replace the hub and don't want to **** around with it. THANKS.
Posted on Jan 26, 2009
kram26
  • 544 Answers
SOURCE: washer will not agitate or spin
HI,
you can view this site to have some ideas about your agitator problem.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes
any further question let me know.
thanks,
Posted on Mar 29, 2009
SOURCE: GE profile washing machine won't agitate it spins out, drains,
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
Posted on Apr 15, 2009
mgprice
  • 744 Answers
SOURCE: GE washer GNSR2140A0WW wont spin/agitate but fills and drains
Hello, your problem is going to be with the lids switch, in this machine it is going to be a magnetic contact. You can confirm this my pulling the front panel off and accessing the wireing to the lids switch, If you have electrical knowledge bypass the lid switch using a wire nut and run the machine. If all is ok make sure you relpace the lid switch since it is there for a reason. If you have any other questions or concerns please feel free to comment again. Good Luck!!!
Posted on Jul 19, 2009
hiltonjug
  • 612 Answers
SOURCE: ge profile washer WPSR3100W1WW won't agitate
I see this pretty regular. You have a bad transmission. This is very common with the older GE's. To replace the transmission will run around $340 / $400. Not sure about your area. Just be glad you got this much use out of it, you are one of the very few that have. From 1998 till 2007 I owned my on repair company where I did GE's warranty work in my area for them. During that time period. When I found a GE washer under warranty doing what you are describing. GE would warranty the whole machine. They would have me destroy the machine after I would deliver the customer a band new one. GE knows they had a bad transmission and it cost them a lot of money. It was cheaper for them to replace the washer than have me repair it. The transmission list price was $298.00 back then. A word of advice, when you replace it. Buy a Whirlpool, Kenmore, Maytag. These brands hold up the best. I have the least service calls for Whirlpool and Kenmore. Both are made by the same people. Kenmore is made for Sears. Good Luck.
Please rate this solution if helpful. Thanks
Posted on Aug 21, 2009
Will not spin or agitate
did the washer cause the flood? you could have got water into the motor if it was above a few inches deep. do you hear the motor working, and no agitator movement? will it fill ? or is it just dead?
Nov 10, 2013 | GE Profile WPRE6100G Top Load Washer
GE washer WPRE6100G0WT not agitating or spinning
Depends on how old the machine is. It might me a transmission problem
Jul 25, 2012 | GE Profile WPRE6100G Top Load Washer
GE Profile WPRE6100G tub spins while washing
My parent's Hotpoint did the same thing!! The brake on the bottom of the tub is not engaging! It needs replaced!!
May 15, 2012 | GE Profile WPRE6100G Top Load Washer
Washer keeps spinning. doesn't move to next cycle
It sounds like the agitator , air bell or transmission is failing. Since the unit spins the belt & motor is ok. I recommend removing & inspecting the agitator & air bell. If they are not stripped out then you have a transmission failure.
Or, start the washer at the beginning of a cycle set to the lowest water level. After the unit fills it should be agitating stop the washer. Open the lid & try moving the agitator, if the agitator will not move it is good & no need to remove for inspection. You have a bad transmission. If the agitator moves easily then we know that the agitator or air bell is stripped out & will need to be inspected for confirmation before replacing.
Hope this helps.
Thanks for using Fixya.
Dec 09, 2009 | GE Spacemaker Washer and Dryer Electric...
1.5 year old ge profile washing machine will not agitate or spin
Timer seems to have gone bad. Manually move the timer to make the dryer spin. If you get it to spin and drain then it's your timer.
Jul 01, 2009 | GE WDSR2080D Top Load Washer
Washer will not agitate or spin
HI,
thanks,
Mar 29, 2009 | GE Profile WPRE6100G Top Load Washer
Ge washer won't agitate
If the washer won't agitate at all, but the motor and belts are turning,
then you may have drive coupling or transmission issues. In this case, it
is well worthwhile to have a technician check the machine to verify this.
Sometimes, the base of your agitator can strip out, especially from
overloading. In such a case, the splines are damaged inside the agitator,
and can be seen after the agitator is removed.
If you can hear the motor running, and the water is moving a little bit, but not like normal where the clothes are being worked around you might just have worn out agitator dogs. This is a really easy 15 minute do it yourself fix, and the parts are less than $10 and widely available. Here is a how to article - http://zenfixit.com/repairs/appliance-repair/washing-machine-agitator-clutch-repair/
Feb 01, 2009 | GE Profile WPRE6100G Top Load Washer
Jan 25, 2009 | GE Washing Machines
GE Profile WPRE6100G Top Load Washer Logo
21 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
