Question about Muddy Fox Cycling
I bought new handlebar for muddy fox turbulence, too big.the bars 31.8 what size stem to sort me out
4 Suggested Answers
voodoomox
  • 1689 Answers
SOURCE: Can't tighten the handlebar stem.
hi lynduck,
are you using a threadless steam or a threaded one?
like this one in the picture.
http://www.sheldonbrown.com/images/headset-threadless.jpg
if so, spacers should be on the right spot and the pinch botls should be tights. top cap should not be moveable and this will make sure your front end turns lightly. apply light axle grease to make it smooth.
regards,
voodoo
Posted on Apr 19, 2009
  • 6 Answers
SOURCE: I cannot adjust the height of the handlebars on the 20" Mongoose
some bikes u cant only the seats can adjuct
Posted on Jul 20, 2009
Coachphil
  • 347 Answers
SOURCE: I would like to raise
Hey joe - Sounds like you have a classic stuck stem. Here are a couple things to try.
1 - Loosen the stem through the top bolt so the wedge is loose, but not removed. The give the top of the stem a good hit or two with a plastic mallet. That should break the bond between the steerer and the stem. If that does not work...
2 - Use liquid Wrench and drip around the stem so it seeps in-between the stem and steerer. Let sit a while then try the plastic mallet again.
sometimes you will need to work the stem back and forth a bit by using the handlebars as leverage and bracing the front wheel between your knees.
If neither of these get your stem loose, then it's time to take into a bike shop.
BTW - stems have a maximum insertion/ extension. There is a line of max extenstion that should be on the shaft when you get it removed. If you discover that the stem will not raise your handlebars enough, then you can get a replacement stem with a higher shaft and greater angle to lift the bars up.
Posted on Nov 18, 2010
Schwinn 12 Roadster trike-handlebar does not fit into fork steer. Handlebar & fork have approx. same circumference, so can't slide it in. Is the handlebar defective & needs to be replaced? Thanks!
I assume you mean the handlebar stem does not fit into the fork steerer. Approximately the same diameter is not good enough. The stem has to be the correct size for the fork. The two most likely sizes are 22.2mm and .833 inches (21.15mm). Most stems have the size stamped near the bottom. There's a good chance your trike has a .833 steerer. Stems for that size are still available.
Jan 25, 2018 | Schwinn Cycling
Raising handlebars on schwinn ditch 2.0 dn
The above answer is incorrect. The Ditch has what is called a "threadless" fork/stem setup. One cannot raise the stem at all unless there are spacers above it. Raising the stem is also not the only option. A stem with a shorter "reach" may be sufficient. Google "threadless stem riser" to see options for raising the stem. Following is a video with the procedure.
Jun 09, 2016 | Schwinn Cycling
Adjust handle bar height ?
looking at some pictures of this model, most appear to be using an "Aheadset" style handlebar stem, there is not any way to raise this type of stem. Your alternative is to go online or to a local bike shop and purchase a new stem that will fit your fork and handlebar that has a higher pitch angle to it, or a compatible adjustable stem that pivots. Expect to pay $25-$50 or more for a new handlebar stem, not including labor to install.
Apr 06, 2016 | Marin Belvedere Commuter Road Bike
How do you raise the handlebars?
That depends on what sort of headset you have. the most common these days is a straight fork with a clamping stem that retains the fork, keeps the steering bearings properly loaded and that the handlebars attach to. You can get some that allow you to change the height, but if yours if fixed then likely the only thing you can do without parts is to flip the quill over. Depending on the stem you have and how it is currently mounted this might not gain you any height. As you can see from the picture, in this case flipping the stem over will lower the handlebars
25815371-zv4th55h254xa4tiaa1soakf-2-2.jpg An adjustable unit allows you to change the height of handlebars to suit your size.
Aug 09, 2015 | Gary Fisher Napa
Raise handlebars on mountain bicycle
This will depend on what sort of stem you have. Most mountain bikes these days use a clamping style stem that simply grips the steerer tube on the fork. Some will have limited adjustment in that they may have a stack of 2 or 3 spacers that you can place either over the stem or below the stem. This does not give much adjustment. On my wife's bike the stem is actually adjustable similair to this: MEC 110mm Adjustable Stem Mountain Equipment Co op
and might be a good option for this bike.
Sep 18, 2014 | Huffy Granite 26 Women's Mountain Bike
How to raise handle bars on 20 inch bmx muddy fox
By adjusting the 7 degree reversible headset and adding or subtracting spacers to the rotational bar (attached to front fork)
hope this helps.
Jun 20, 2014 | Muddy Fox Cycling
I have a Bianchi Strada hybrid. I want to raise the handle bars. What size stem riser should I get? Is this the right way to do this?
http://www.sheldonbrown.com/handsup.html
A major limitation is the steerer tube length. No matter how many times you cut a steerer tube it won't get longer.
Getting Riser Bars or simply flipping the stem over or getting one with a different rise and reach might give you the added height you need. If you LIKE the handlebars, the stem is the best and least-invasive option as most new ones come with front loaders (detachable front caps) that allow replacement without stripping components off one side of the handlebar. In minutes a Bicycle Shop could swap any number of them onto your bike for you to try.
Sep 23, 2011 | Bianchi Strada
Cannot tighten handlebars they move up and down and left to right
Surf for this "adjust threadless stem bike" and find videos.
Jul 16, 2011 | Muddy Fox Ascent
Just bought a Mongoose Spear (26"). How do I raise the handlebars?
Getting Riser Bars or simply flipping the stem over or getting one with a different rise and reach might give you the added height you need. If you LIKE the handlebars, the stem is the best option as most new ones come with front loaders (detachable front caps) that allow replacement without stripping components off one side of the handlebar. In minutes a Bicycle Shop could swap any number of them onto your bike for you to try.
I would recommend you get used to the position that yields a careful compromise between aerodynamics and uprightness when needed.
Apr 29, 2011 | Mongoose Spear 26 Inch Men's Bike
Cycling Logo
48 people viewed this question
Top Muddy Fox Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Muddy Fox Cycling Expert? Answer questions, earn points and help others
